*Official* 2017 TCL P-Series (55P607) Owners Thread (No Price Talk) - Page 209 - AVS Forum | Home Theater Discussions And Reviews
 4309Likes
post #6241 of 6307 Old 03-26-2019, 07:42 PM
HisSvt2's Avatar
Quoted: 53 Post(s)
this update has an issue when HDR content kicks in the screen is dark on Xbox One X going to dash and back to game fixes it and on my 4K bluray player switching input and back corrects it I've never had this issue till this update. I hope TCL does something fast this is garbage.
HisSvt2 is offline
post #6242 of 6307 Old 03-27-2019, 11:53 AM
awp
awp's Avatar
Quoted: 30 Post(s)
Yeah, I’m having Dolby Vision issues with my Apple TV 4K as well. Getting occasional green screens. Also had it happen once on my Xbox One X. They definitely screwed something up with the update.
Is it possible to downgrade via a USB stick?
awp is offline
post #6243 of 6307 Old 03-27-2019, 01:12 PM
bguzman's Avatar
Quoted: 137 Post(s)
Liked: 815
My 605 auto updated and now I have no Atmos through ARC. WTF How can I revert back to the previous firmware?
HT TCL 55P605, Mitsubishi HC6500, Oppo UDP-203, Panasonic LX1000, Firestick 4K, ATV4K, Onkyo TX-NR787, DefTech, Klipsch, Martin Logan, SVS @ 5.2.4 Atmos
Stereo Sansui SR-4050, Dual 1219, Oppo UDP 203, Emotiva PT-100, Be One Audio MA100, Polk Monitor 10, SVS SB1000
bguzman is offline
post #6244 of 6307 Old 03-27-2019, 02:50 PM
solarrdadd's Avatar
Quoted: 252 Post(s)
Liked: 170
Sorry to hear that Guz. Mine has updated to 9.0 but I'm getting ATMOS. My audio is set to "auto detect" (for ARC) with tv speakers disabled.
All apps that support ATMOS stream it like before. I do notice Prime ATMOS is rather crackly since the upgrade. Have you tried checking the Dolby Access app? I get ATMOS & DV when playing clips via that.
Check your tv settings bud. When I first turned mine on I got no sound at all and the tv speakers were enabled. I went back to the home page, then went back into settings and they were disabled and everything worked fine after that. Just tested it again with the Dolby app and ATMOS/DV going strong.
TCL-65R615, 55P605 DV/HDR10 & 49S405 HDR10, Philips BDP7501, BPD7502 UHD Players
Oppo BDP-105D, 105, 93, Marantz AV7702MKII, NR1607. Xbox One S
Emotiva XPA5,UPA2, UPA200 & Mini X Amps
Speakers, Polk SDA-2, Monitor 10A & 5A, Axiom M80,
VP180, QS8, M2, QS4, ATMOS 7.1.4 & 5.1.2 NYGiants!
solarrdadd is offline
post #6245 of 6307 Old 03-27-2019, 04:47 PM
bguzman's Avatar
Quoted: 137 Post(s)
Liked: 815
Hey there SD,
Nice to hear from you. Thanks for the advice I’ll check it out. This happened when I turned the TV on this morning before work and I didn’t have much time to do much except “freak out” and it was time to hit the salt mines.
solarrdadd likes this.
bguzman is offline
post #6246 of 6307 Old 03-27-2019, 04:54 PM
helvetica bold's Avatar
Quoted: 1596 Post(s)
Liked: 968
My TV didn’t get the update so should I disconnect from my network to prevent it from happening?
LG65C9, XBOX ONE X, PS4PRO, APPLE 4K, SONY STRDN1070, TAKE CLASSIC 5.1
helvetica bold is online now
post #6247 of 6307 Old 03-27-2019, 05:31 PM
solarrdadd's Avatar
Quoted: 252 Post(s)
Liked: 170
if you don't want the update then i would say yes (unless there is a way to disable auto updating) however, if you use your tv for streaming then your gonna have to make some hard choices.
post #6248 of 6307 Old 03-27-2019, 05:35 PM
Liked: 968
Thanks. So the new update has some serious issues? HDR gaming will be compromised?
post #6249 of 6307 Old 03-27-2019, 05:45 PM
HisSvt2's Avatar
Quoted: 53 Post(s)
I fully restarted my TV a reboot and i never use the sleep mode TV was working perfectly all day today after that with all my Apps and my Xbox One X and PS4 Pro.
helvetica bold likes this.
HisSvt2 is offline
post #6250 of 6307 Old 03-27-2019, 05:52 PM
Liked: 968
Funny enough I came home from work and my TV updated. So far it seems fine...
post #6251 of 6307 Old 03-27-2019, 06:27 PM
Liked: 968
I received OS 9 but my Xbox One X doesn’t allow for Dolby Vision. I thought that was part of the update.
post #6252 of 6307 Old 03-27-2019, 06:34 PM
HisSvt2's Avatar
Quoted: 53 Post(s)
I keep seeing TCL 4 5 6 series no mention of the P on Xbox reddit page. Are you running straight into the TV or thru a receiver?
HisSvt2 is offline
post #6253 of 6307 Old 03-27-2019, 06:40 PM
Liked: 968
AH, good call. I forgot I’m running Thur my receiver and it doesn’t support DV. On a side note HDR10 is very dim now. Will plugging directly into the TV solve the dim HDR issue??
post #6254 of 6307 Old 03-27-2019, 06:43 PM
HisSvt2's Avatar
Quoted: 53 Post(s)
when i had that happen going back to xbox dash then back into game fixed it but i did a full tv restart today and that has not happened since and I've been in and out of Destiny 2 which has HDR several times today.
HisSvt2 is offline
post #6255 of 6307 Old 03-27-2019, 07:04 PM
solarrdadd's Avatar
Quoted: 252 Post(s)
Liked: 170
my 55P607 is in the bedroom and i don't have an Xbox in there. everything connected to the receiver and/or directly to the tv are still working just like they were before the update. looks good, sounds good, HDR/DV/ATMOS from all apps look and sound great.
post #6256 of 6307 Old 03-27-2019, 07:19 PM
bguzman's Avatar
Quoted: 137 Post(s)
Liked: 815
Well I guess I got two updates last night, my TV and my ATV4K. TV is fine after going through the audio settings, thanks solardadd, and yet I lost Dolby Vision going through my receiver when using the ATV4K. It seems like it is always something these days. Hope they fix it soon.
bguzman is offline
post #6257 of 6307 Old 03-27-2019, 07:37 PM
Liked: 968
Auto low latency mode is now supported on the TCL. That’s a surprise.
post #6258 of 6307 Old 03-27-2019, 08:22 PM
HisSvt2's Avatar
Quoted: 53 Post(s)
I bypassed my receiver (No Dolby Vision but has HDR10) and sure enough Xbox One X showed all supported features auto low latency Dolby Vision and HDR10. 2017 TCL P605
helvetica bold and solarrdadd like this.
HisSvt2 is offline
post #6259 of 6307 Old 03-27-2019, 08:59 PM
Liked: 968
Thanks! A full TV restart consists of unplugging the TV?
post #6260 of 6307 Old 03-28-2019, 05:30 AM
HisSvt2's Avatar
Quoted: 53 Post(s)
Restart using the restart option in the Roku menu it does a full reboot. I also don't use quick start mode never have.
HisSvt2 is offline
post #6261 of 6307 Old 03-30-2019, 04:13 AM
crcostel's Avatar
Quoted: 99 Post(s)
Liked: 42
Noticed the update this morning. Tv seems fine, One S recognized DV and Low Latency. No screen issues yet.
crcostel is offline
post #6262 of 6307 Old 03-31-2019, 07:41 AM
rolltide1017's Avatar
Quoted: 493 Post(s)
Liked: 491
Anyone else with an Apple TV 4K have DV problems after updating to the ATV to tvOS 12.2?
Here is my issue.
I have my ATV set to 4K SDR with match range on. DV content will play and DV engages correctly but, when stopping playback and when DV disengages, I get just a black screen. I have to hit the Home button on my TCL TV remote and then choose the input of the ATV to get the picture back.
Wish I could go back to the previous version because everything was working perfectly fine and none of the new features are important to me. Learned my lesson, I’ll never update immediately again.
lucasawalker likes this.
PSN ID: CrimsonNagus
XBL GT: Crimson Nagus
rolltide1017 is offline
post #6263 of 6307 Old 03-31-2019, 07:53 AM
Liked: 0
Here is my issue.
Same issues here. Can’t even get Dolby Vision or Atmos to work anymore. Worked perfectly before update. Tried everything but nothing works.
lucasawalker is offline
post #6264 of 6307 Old 03-31-2019, 04:51 PM
Liked: 1
I noticed recently when I switch to a different hdmi input on the P607 It usually takes a few seconds for the local dimming too kick on? Kind of hard to explain but the screen will be slightly grey then hit deep black. Was curious if this is normal and if anyone else has any similar issues.
Fuller Boy is offline
post #6265 of 6307 Old 03-31-2019, 05:07 PM
Dan Hitchman's Avatar
Quoted: 4467 Post(s)
Liked: 2520
Ah, the joys of cheap TV's.
Listen up, studios! Dolby Atmos Lite™ print-outs must stop!!
Dan Hitchman is offline
post #6266 of 6307 Old 03-31-2019, 06:02 PM
solarrdadd's Avatar
Quoted: 252 Post(s)
Liked: 170
what you didn't say is what is connected to that input and what it's doing, i.e. a UHD player playing a UHD HDR/DV disc or something like that.
mine changes with no issues and displays exactly what is on the other input as it is.
post #6267 of 6307 Old 03-31-2019, 08:03 PM
Liked: 1
I apologize. It is the PlayStation Pro that is connected to the hdmi input that has a slight local dimming lag to it. The local dimming works fine. It just takes a few seconds too kick in once I select the input. Just wasn’t sure if that is normal or a defect of the product.
post #6268 of 6307 Old 03-31-2019, 08:21 PM
bguzman's Avatar
Quoted: 137 Post(s)
Liked: 815
Thanks for clearing that up, all's well that ends well. I guess "Dan" will have to find joy somewhere else.
bguzman is offline
post #6269 of 6307 Old 03-31-2019, 10:49 PM
bguzman's Avatar
Quoted: 137 Post(s)
Liked: 815
Now I don't know what to think. Check out what I posted in the Onkyo thread.
https://www.avsforum.com/forum/90-re...l#post57835716
bguzman is offline
post #6270 of 6307 Old 04-01-2019, 12:10 PM
Liked: 1
Nevermind. It seems switching the input to hdmi 2.0 seems to have corrected the issue
Reply LCD Flat Panel Displays
