*Official* 2017 TCL P-Series (55P607) Owners Thread (No Price Talk) - Page 74 - AVS Forum | Home Theater Discussions And Reviews
 4318Likes
post #2191 of 6352 Old 08-14-2017, 12:18 PM
Quoted: 1137 Post(s)
Liked: 982
Originally Posted by walk View Post
This is about the TCL S405 (43" model here) but thought I'd ask.
When viewing Blu rays from a PS3 sometimes the picture gets very blurry on motion, almost like extreme compression artifacts. If you pause the disc and look at a still frame, everything looks perfect. But in motion it's terrible. There is color banding/sparkling too.
The only solution I found was to turn on "game" mode for that input. This is fine, but it does say "less lag but worse picture". Of course the picture looks fine, but I'm wondering if I'm missing anything?
The PS3 is a launch-day unit, but the software is up to date. The HDMI cable is known to be good. Obviously (?) the picture is getting to the TCL just fine since it's good in "game" mode. Using HDMI input #2 on the tv (not the ARC HDMI #1).
I tried every setting on both the TV (HDMI mode 2.0, 1.4 etc) and on the PS3 (Bluray output YUV, RGB, Superwhite on/off, Deep color etc)
Any thoughts? This tv has no motion enhancements so I'm a little confused what's going on ...
I haven't seen anything wrong with streaming videos (Netflix, Youtube etc) even 4k stuff looks good. There is no "game" mode on streaming inputs... So far I don't have a cable box hooked up but will sometime soon..
The P60x also suffers from something similar (so does my M55-C2), so perhaps the S405 shares the same issue. When Noise Reduction is turned on it can cause blurring and ghosting. Try to turn that off, if it's available, and see if it helps. When you turn on Game Mode, you basically cancel most of the image processing the TV does, including noise reduction.
theboomr likes this.
LG 65B7 | T95N with CoreELEC | Vizio SB3851-D0 | Calibration + Settings (TBD)
Vizio M60-D1 | T95M with LibreELEC | Calibration + Settings
Dell UP2516D | Le Potato with CoreELEC (Development/testing platform)
Vizio M55-C2 (Ex) | Calibration + Settings
The Coolest is offline
post #2192 of 6352 Old 08-14-2017, 12:55 PM
Quoted: 351 Post(s)
Liked: 226
As The Coolest said, your issue sounds the same as the P607 issue that is caused by the Noise Reduction feature. However, I don't think you have access to those settings on the S405; for the p series the setting is located in the Expert Picture Settings in the Roku mobile app.
theboomr is offline
post #2193 of 6352 Old 08-14-2017, 02:32 PM
movd's Avatar
Quoted: 151 Post(s)
Liked: 81
You can access the noise reduction setting on the S405 the same way in the mobile app.
Vizio P55-C1 | Denon AVR-X1200W
[5] DefTech ProMonitor 1000s | ProCenter 2000 | SR-8040BPs [.1] SVS PB1000 [.2] Micca R-8C
Nvidia Shield | Zidoo X9S | Popcorn Hour VTEN
movd is offline
post #2194 of 6352 Old 08-14-2017, 02:41 PM
jyqureshi's Avatar
Quoted: 164 Post(s)
Liked: 76
Originally Posted by Pres2play View Post
I used my son's iPhone to test the Roku WB and CMS feature and it has the same problems. The select arrows for the stimulus levels seem stuck or do not respond.
Also changed the router and upgraded to faster plan, but that didn't help.
I will contact Roku and see what's happening with the controls.
I've never had this problem but I've been using Android 7.1.1 on two different phones...I never had the expert settings give me any trouble. BTW, my TV is wired to the network.
jyqureshi is offline
post #2195 of 6352 Old 08-14-2017, 04:43 PM
Pres2play's Avatar
Quoted: 877 Post(s)
Liked: 393
I'm only having trouble with the arrow buttons in the WB setup. Did you try those two buttons specifically?
If I press the right arrow button several times, for example, it will go from 100%, 90%, 80% and, then, stop, as if frozen.
The support tech said it could be signal interference with other wireless devices. Waiting for them to get back to me.
I'll try the cable connection and see if that helps.
Pres2play is offline
post #2196 of 6352 Old 08-14-2017, 05:14 PM
iChristopher's Avatar
Quoted: 72 Post(s)
Liked: 39
Originally Posted by abcekids View Post
Redmere cables are directional. Any chance it was plugged in backwards? I might or might not be speaking from experience.
Sent from my LGLS775 using Tapatalk
I checked it before swapping it. Don't know what the issue was. It only would find the PS4 on hdmi 1.4
Note: This post may contain misspellings, grammatical errors, disorganized sentence structure, or may entirely lack a coherent theme but it will only add to the overall beauty of my message.
iChristopher is offline
post #2197 of 6352 Old 08-14-2017, 05:15 PM
Quoted: 72 Post(s)
Liked: 39
I'm using cnet settings, which look ok. Anyone have settings they'd like to share. I'm doing mostly DIRECTV viewing at 1080i. Thanks guys.
post #2198 of 6352 Old 08-14-2017, 05:27 PM
henhowc's Avatar
Quoted: 223 Post(s)
Liked: 120
any word on them fixing the sharpness bug when switching to hdr?
henhowc is offline
post #2199 of 6352 Old 08-14-2017, 05:51 PM
Liked: 0
I just purchased a PS4 and Horizon Zero Dawn looks amazing!
Do you play in HDR or SDR? If you play in HDR do you mind sharing your settings?
Sirmezmerize is offline
post #2200 of 6352 Old 08-14-2017, 05:52 PM
walk's Avatar
thanks, I thought I turned all that stuff off, but will check again.
I haven't been able to get the Roku app to work, but it may be because the tv is only connected to public Xfinity wifi (still waiting for internet to be installed at new house).
walk is offline
post #2201 of 6352 Old 08-14-2017, 07:41 PM
Pres2play's Avatar
Quoted: 877 Post(s)
Liked: 393
I picked up the PS4 Pro yesterday and everything is on Auto right now in the console. The only thing I did, on the TV, is change dimming from Off to High in Game mode, and select HDMI input 2.0
post #2202 of 6352 Old 08-14-2017, 07:58 PM
Antarius's Avatar
Quoted: 145 Post(s)
Liked: 80
That is noise reduction. Use roku app to turn it off. If app says it is off and you are still seeing it, enable noise reduction and then turn it off again.
Antarius is offline
post #2203 of 6352 Old 08-14-2017, 08:15 PM
jyqureshi's Avatar
Quoted: 164 Post(s)
Liked: 76
I never had this problem, while calibrating I went from 5% to 100% without ever encountering this issue. Went from 100% to 5% when entering values from an existing calibration.
It could be wifi lag, see if your neighborhood wifi channel is crowded (use inSSIDer free version to analyze your area's channel congestion).
Hope this helps.
post #2204 of 6352 Old 08-14-2017, 08:26 PM
jyqureshi's Avatar
Quoted: 164 Post(s)
Liked: 76
See if you like my settings...
post #2205 of 6352 Old 08-14-2017, 08:29 PM
Verick's Avatar
Originally Posted by crashnburn_in View Post
Can anyone please check for Croma Sub Sampling 4:4:4 ?
When labeled computer, 4:4:4 and rgb display without sub sampling.
Verick is offline
post #2206 of 6352 Old 08-14-2017, 09:31 PM
Pres2play's Avatar
Quoted: 877 Post(s)
Liked: 393
Hope this helps.
Thanks, I'll check into that. Maybe even contact my cable provider.
Oh, man...never had to do this before, but it could be something as simple as me moving my router for better signal. I'll check this when I get home.
post #2207 of 6352 Old 08-14-2017, 10:26 PM
Capek's Avatar
Quoted: 24 Post(s)
The Roku app does seem a bit buggy. Every time I open it, I get the error message stating "Roku service is not currently available, continue anyway?" I always continue anyway, and everything seems to work just fine. Never had any issues on the expert settings menu at least.
Capek is offline
post #2208 of 6352 Old 08-14-2017, 10:31 PM
hdtv00's Avatar
Quoted: 277 Post(s)
Liked: 154
It says you can play things off a external drive but it never pops up or can't find option to go to the drive at all. It's a WD external that's powered through the usb and doesn't have external power. Is that the issue maybe. Drive works on anything else I plug it into, xbox or another samsung ks8000.
Marantz 7702MKII/Outlaw 7140 65" 4k Samsung KS8000
i7 4770K/16 gig 2133/970's SLI 840 PRO SSD
Paradigm Studio v3 100/570/20's/470's/2200 Sub
hdtv00 is offline
post #2209 of 6352 Old 08-14-2017, 11:23 PM
Quoted: 72 Post(s)
Liked: 39
looks great!! Whats your sharpness set at? Also, whats your picture size?
post #2210 of 6352 Old 08-14-2017, 11:51 PM
Quoted: 351 Post(s)
Liked: 226
Unfortunately this TV appears to not have enough power going to the USB port to support external hard drives. It can do flash drives but not hard drives, for the most part. If you can get one of those split USB cords that also goes to a power outlet (or a wall USB charger maybe?) that might work.
theboomr is offline
post #2211 of 6352 Old 08-15-2017, 03:38 AM
crawlgsx's Avatar
Quoted: 128 Post(s)
Liked: 85
The tv is extremely fussy. I tried an external ssd (no power required) and I didn't work. Tried a LaCie external ssd it worked fine. Tried 2 different 128gb usb3.0 drives one worked one didn't.
Media playback was also hit or miss.
Chris D.
LG C9 OLED - XBOX One X
crawlgsx is offline
post #2212 of 6352 Old 08-15-2017, 06:34 AM
Quoted: 91 Post(s)
Liked: 25
I'm still looking for someone to post their gaming settings for picture.I used CNET's settings and it was all white washed when playing Destiny on the PS4. I couldn't concentrate on head shots as well. Ultimately I decided to use the "Sports" mode and the white cloudy glare went away. I also turned "game mode" on and turned the color down to 55 from like 60 or something. That's all I did, the sports mode has a more "blue" tent which I like coming from my Panasonic Plasma. Other than that I haven't seen any "general" settings that I really like. For example, in Destiny when loading into a PVP match, usually you can see the boots and legs clearly of all players but in CNET's movie mode settings their legs and feet were too dark and the blacks seemed crushed.
Let me know your thoughts.
Fivez is offline
post #2213 of 6352 Old 08-15-2017, 08:33 AM
afrogt's Avatar
Quoted: 2201 Post(s)
Liked: 1459
just purchased a P605 from Best Buy last night. Will be getting in delivered on Thursday evening. Looking forward to my first 4K TV.
Afro GT
afrogt is offline
post #2214 of 6352 Old 08-15-2017, 08:44 AM
jyqureshi's Avatar
Quoted: 164 Post(s)
Liked: 76
...Maybe even contact my cable provider.
Your issue is with your home network, not your internet connection... hope you figure it out though
post #2215 of 6352 Old 08-15-2017, 08:49 AM
Dan Hitchman's Avatar
Quoted: 4692 Post(s)
Liked: 2732
Now, you need an Oppo 203!
dharmaboy likes this.
Listen up, studios! Dolby Atmos Lite™ print-outs must stop!!
Dan Hitchman is offline
post #2216 of 6352 Old 08-15-2017, 10:19 AM
Liked: 0
Bump! I really want to play in HDR but maybe I have a bad taste because SDR looks so much better for me
post #2217 of 6352 Old 08-15-2017, 10:33 AM
afrogt's Avatar
Liked: 1459
Nah, no Oppo 203. this is where this hobby can get rally expensive if you stay on AVS too long. I contemplated a LG 65UH7700 as a local dealer had it for great price, plus it had HDR 10 and Dolby Vision but since it was an IPS panel it was not recommended in a dark room. The size would have been a nice upgrade but rtings.com didn't give it a great review. So I passed and picked up the TCL instead. I think I made the right choice.
bigapp likes this.
Afro GT
afrogt is offline
post #2218 of 6352 Old 08-15-2017, 10:35 AM
persiannight's Avatar
Quoted: 46 Post(s)
Liked: 31
Make sure you adjust the HDR Brightness option in the game as well. Makes a BIG difference.
persiannight is offline
post #2219 of 6352 Old 08-15-2017, 10:37 AM
Liked: 2732
Well, it's either the Oppo (a really good universal disc transport) or the LG (a cheaper, flimsier basic disc player with streaming apps) for Dolby Vision support as far as UHD Blu-ray players go. The LG should have an update soon.
The TCL is excellent in Dolby Vision mode as the dynamic HDR metadata coupled with tone mapping algorithms customized for this TV, help compensate for the display's budget panel deficiencies. Despicable Me 1 & 2 on UHD disc looked spectacular. I have the Oppo.
post #2220 of 6352 Old 08-15-2017, 10:46 AM
linkgx1's Avatar
Quoted: 59 Post(s)
Liked: 25
Ok, now I need a 4k BR player with DV support. For under $200 but that doesn't seem possible yet.
bigapp and theboomr like this.
linkgx1 is offline
Reply LCD Flat Panel Displays
