Advice Needed: 65" HDR or 70" non-HDR - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By BHof
post #1 of 7 Old 02-22-2018, 06:39 AM - Thread Starter
Liked: 1
Question Advice Needed: 65" HDR or 70" non-HDR
Hello all,
I'm a newb to this site, and was hoping to get some advice (I'll keep it short-ish):
Currently re-doing my basement, and so I'm finally getting a 4K tv. It will be used for equal parts movies, video games (XBox One, not the X), and sports (football and hockey). We'll be sitting about 9-10 ft from the screen.
I have been pricing out TV's (pretty much just looking at Samsung, LG, and Sony) and realized that 70" 4K tv's with true HDR are out of my price range (looking to spend $1,500 max). However, 70" tv's with "fake" HDR (HDR compatible or Active HDR) are within my range. Alternatively, I could get a 65" with true HDR and stay within my budget.
So my question is - should I go with the better quality, or the bigger size? Is there a huge discrepancy between HDR and non-HDR? Thanks in advance for your opinions/advice!
PS - My wife has essentially vetoed 75", as she says its too big for the viewing distance, plus I had concerns about playing video games on 75".
BHof is offline
post #2 of 7 Old 02-22-2018, 06:53 AM
j4894's Avatar
Quoted: 101 Post(s)
Liked: 48
In my opinion, if you plan on watching a lot of 4k bluray movies than HDR is worth it. HDR done right is probably the biggest advantage of 4k movies over HD, not just for the highlights but the expanded color. In the end it's your preference but I personally think you'd might notice the improvements of HDR more than 5 inches of screen.
LG 65EF9500 OLED / Def Tech 8060st / Def Tech 8040cs / SVS PC-2000 pro (x2) / Denon S710W / ATV4K / Sony UBP-X800 4k
j4894 is offline
post #3 of 7 Old 02-22-2018, 07:19 AM
tim3320070's Avatar
Quoted: 74 Post(s)
Liked: 51
During the olympics, Dish Network had a 4K HDR channel, sometimes HDR would not kick in unless I changed channels back and forth- once it kicked in, the improvement was dramatic. This is on an OLED. HDR is a must, not getting it is a waste of money IMO.
tim3320070 is offline
post #4 of 7 Old 02-22-2018, 07:29 AM
Javelin's Avatar
Quoted: 103 Post(s)
Liked: 90
If you can extend your budget a couple hundred more i recommend the Sony 65 X900E. It's a really solid TV with a great picture!
It's on sale now for 1700 at BB. You can drop down to the 65 X850E for 1100 on sale but the picture won't be nearly as good the 900.
And yes, you should get HDR now. You'll regret it later if you don't!
Javelin is offline
post #5 of 7 Old 02-22-2018, 08:13 AM
pbz06's Avatar
Quoted: 1598 Post(s)
Liked: 1389
There's really no point in "upgrading" if you're not really upgrading. Might as well save up a little more and do it right, even if it's a lower end HDR TV. But at that size, your options are limited with that budget.
HDR makes a big difference when done properly, especially in a lot of the newer video games.
Sony XBR-77A9G / Panasonic DP-UB9000 / Marantz SR7011 / SVS PB-4000 / Def Tech 9060 Series
pbz06 is online now
post #6 of 7 Old 02-22-2018, 10:19 AM - Thread Starter
Liked: 1
Thanks everyone, seems pretty unanimous to go with the 65" HDR, I appreciate the feedback.
Now I'll just have to spend time comparing models - from researching the forums the Sony XBR65X900E appears to be the top choice. Apparently that's gotten as low as $1,500 on Amazon in the past couple months, so I'll keep on eye on that. My other 2 options currently are the LG 65SJ8500 and the Samsung UN65MU9000. Probably will go with the Sony as it's be best reviewed by both consumers and websites, but at least keeping my options open.
Thank you all again for the help!
pbz06 likes this.
BHof is offline
post #7 of 7 Old 02-22-2018, 10:35 AM
rlindo's Avatar
Quoted: 984 Post(s)
Liked: 887
As others have said, definitely the 65" with HDR as based on my experience, that's really the key thing when it comes to UHD and hdr in games is great so if/when you eventually get a One S or One X or either PS4 (guessing you have the original Xbox One), you'll have HDR goodness in an increasing amount of games.
I also agree with the others about the 900E as it seems like the best option in that price range. I am having my parents get a 75" 900E (or maybe the F) for their main floor remodel when it is done. Very excited to be able to test it out.
Oh and welcome to the forum!
rlindo is offline
Reply LCD Flat Panel Displays
4k 65 , 4k 70 , hdr , uhd
