2018 Sony XBR 900F owners thread (No Price Talk) - Page 113 - AVS Forum | Home Theater Discussions And Reviews
 4256Likes
post #3361 of 9390 Old 10-04-2018, 11:09 AM
Keabrown79's Avatar
Quoted: 132 Post(s)
Liked: 32
Originally Posted by Cheddarhead View Post
All 4 ports pass HDR and DV at 30FPS 4:2:2, only ports 3 & 4 pass HDR and DV at 50/60FPS 4:4:4 so your fire TV and switch should be just fine using port 1&4.
External devices must support the low-latency DV profile necessary to work with 900f and other Sony DV TVs. ATV, Sony x700, Oppo 203 and a few other devices support the necessary DV profile.
Thanks for the response... I was worried I wouldn't get full HDR10 support out of my consoles.... do we know if the apple tv 4k or new fire stick 4k qualify for the dolby vision pass-though? I hear terrible things about native apps so I want to use them as little as possible.... I'm seeing good things about screen uniformity, I just worry about vertical banding... it drives me a bit crazy.
Keabrown79 is offline
post #3362 of 9390 Old 10-04-2018, 11:13 AM
Quoted: 334 Post(s)
Liked: 267
The ATV 4K is compliant with the "low-latency" DV profile, don't think the fire TV is. Personally I like the internal apps, especially if you tweak Android TV by disabling Samba and the Sony Shelf YMMV.
FYI pass-through is different than a device that supports DV decoding.
Current system:
Sony 75X900e/Sony STR-DN-1080, CS-3/CS-8/CS5
Sony X800 4K blu-ray player/Dish Hopper3
Roku 4 Premier/Sony PS-4
Cheddarhead is offline
post #3363 of 9390 Old 10-04-2018, 11:16 AM
Keabrown79's Avatar
Quoted: 132 Post(s)
Liked: 32
Gotcha! got caught up on terminology. After returning my Vizio P quantum... it comes back to this or q6fn as I mostly game on it I have to make a call about which set is gonna give me the least uniformity issues lol.
post #3364 of 9390 Old 10-04-2018, 11:17 AM
SightSeeker1's Avatar
Quoted: 106 Post(s)
Liked: 63
So standard PS4 can do 1080p HDR through 1 and 4 ports? What exactly is necessary to hook to the high speed ports besides a HTPC? Would a UHD player need to be?
SightSeeker1 is offline
post #3365 of 9390 Old 10-04-2018, 11:22 AM
Keabrown79's Avatar
Quoted: 132 Post(s)
Liked: 32
Oh yeah... I wonder what would happen if a ps4 pro game was at 60fps and HDR enabled but you didn't have it in port 1 or 4
post #3366 of 9390 Old 10-04-2018, 11:23 AM
Anderegg's Avatar
Quoted: 475 Post(s)
Liked: 271
Funny I was just reading the rtings settings before I stopped in the thread as I get my 900f tomorrow. They mention the settings in the review.
If you click the "here" link it goes into some more detail.
I am familiar with the rtings site, unfortunately, the CineMotion settings, when activated, cause MAJOR frame stuttering and frame skipping on common channels such as NBC and NatGeo the worse. I am feeding 60i converted to 60p to a TV and the CineMotion settings all specify they are for IP Interlace to Progressive conversions, which I assume means a sat/cable TV box hooked up to the TV sending actual interlaced signals.
Rtings seems to say that the True Cinema feature is simply a form of BFI to make the framerate look a little better between frames.
Paul
Anderegg is offline
post #3367 of 9390 Old 10-04-2018, 11:24 AM
Quoted: 106 Post(s)
Liked: 63
Half the frames would be thrown out?
post #3368 of 9390 Old 10-04-2018, 11:31 AM
UHD Addict
aaronwt's Avatar
Quoted: 9115 Post(s)
Liked: 5851
The new FireTv 4K stick is supposed to be compliant with Dolby Vision Profile 5( the low latency profile).And is supposed to be compliant with two other DV profiles.
53TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #3369 of 9390 Old 10-04-2018, 12:02 PM
chiptouz's Avatar
Quoted: 271 Post(s)
Liked: 318
Can anyone tell me how to set the x900f to upscale the feed it is getting? For my cable box I am sending the display a 1080i signal. When I click on info the tv says 1080i. I thought I read on the forum that it is better to let the tv upscale. I can’t find a setting to set a specific resolution.
My Movie Library - and still growing!
Family Room: Sony XBR-85x900F + Denon 4520ci + Oppo 203, Speakers: LCR: DIYSG Elusive 1099's, S(R+RS) Polk TC60i, Sub: 2x LTD02 Designed UM18-22 Subs w/Nx6000d
Considering: DIYSG Volt10v2 for FH and Surrounds; Denon AVR X6500h
chiptouz is online now
post #3370 of 9390 Old 10-04-2018, 12:05 PM
spear's Avatar
Quoted: 72 Post(s)
Liked: 76
It sounds like CineMotion performs reverse 3:2 pulldown which doesn't just apply to interlaced content (see the 3:2 pulldown section in http://www.hdtvprimer.com/issues/what_is_atsc.html -- it describes what's done for both progressive and interlaced displays). So I'd assume CineMotion also works to remove judder on 24p content telecined on a 60p input (eg. ABC and Fox).
The descriptions of the Medium and High settings of CineMotion say they perform additional frame compensation. With these settings on Rtings' 24p judder test clip, I do see some artifacts at the top of the screen similar to when I increase the Smoothness slider (Motionflow = Custom). On the other hand, setting Motionflow to True Cinema appears to disable this compensation, regardless of CineMotion setting. What is your setting for Motionflow and CineMotion when you see problems with NBC and NatGeo?
According to this article (https://www.sony.co.uk/electronics/s...icles/00107660) Motionflow uses three techniques: frame interpolation (Smoothness slider), BFI via backlight strobing (Clearness slider), and "image blur reduction" (not sure how this is controlled). I think setting Motionflow to True Cinema *disables* interpolation and BFI. Not sure about the blur reduction.
Personally, I use Motionflow = Custom (Smoothness = Min, Clearness = 1 to enable X-Motion Clarity zone-based BFI) and CineMotion= Low on non-game content.
spear is offline
post #3371 of 9390 Old 10-04-2018, 12:54 PM
Quoted: 334 Post(s)
Liked: 267
A 4K TV always upscales any feed it receives to 4K unless it is already 4K, if it didn't the picture would not fill the frame. The 1080i indication is what the TV is receiving from the external device. Bottom-line you have it configured correctly for the TV to be doing the upscaling. Enjoy.
CAmm805 likes this.
Current system:
post #3372 of 9390 Old 10-04-2018, 12:56 PM
Quoted: 48 Post(s)
Liked: 8
Your TV automatically upscales to 4k any lower resolution signals it receives.
The TV info is telling you that the TV is being fed a 1080i signal from the cable box.
So your TV is doing the upscaling to 4k which is good.
CAmm805 likes this.
wilson44 is offline
post #3373 of 9390 Old 10-04-2018, 12:57 PM
Quoted: 334 Post(s)
Liked: 267
Thank you for the info, Good to know. I pretty much stay away from the Amazon proprietary hardware for personal reasons.
Current system:
post #3374 of 9390 Old 10-04-2018, 05:14 PM
Ricoflashback's Avatar
Quoted: 1787 Post(s)
Liked: 1264
Hockey is back! Incredible picture via Comcast and NBCSN from Madison Square Garden. If must be the MSG feed.
Incredibly bright and clear picture with great color saturation.
Home Theater Setup
SONY 75X900F & 49X900E, BenQ W1080ST, Denon X5200 & Emotiva XPA-3
AudioSource 100VS, OPPO 103 & Samsung K8500, 9.1.4 Setup - Speakers - Studio 60's,
V.2 (FL/FR), CC-690 (C), V.5, ADP 590 V.5 (SS), MilleniaOne 2.0 (BS) - Velodyne 810 Sub,
Cornered Audio (FH/RH), Definitive Technology (Front Wides)
Ricoflashback is offline
post #3375 of 9390 Old 10-04-2018, 05:25 PM
chiptouz's Avatar
Quoted: 271 Post(s)
Liked: 318
@Cheddarhead , @wilson44 thank you both for the responses.
post #3376 of 9390 Old 10-05-2018, 09:45 AM
Liked: 1264
There are some setting options based on your cable or satellite provider. For satellite (Directv - I'm not sure about DISH) - I believe you can set the output to "Native" - - which is the best setting you can get as you receive the original signal (720p or 1080i) from your source.
Cable - at least Comcast Cable - is a little different. Non 4K "boxes" do not have a "Native" option. It's either 720p or 1080i or "upscaling" to 1080p by the Comcast STB.
I recommend that you DO NOT upscale from Comcast to 1080p AND you also try the 720p setting. That will down convert 1080i signals to 720p but prevent upscaling from 720p to 1080i for non 1080i sources. I've tried it both ways with Comcast and believe the 720p setting provides the clearest picture, IMHO.
Home Theater Setup
post #3377 of 9390 Old 10-05-2018, 10:14 AM
Quoted: 106 Post(s)
Liked: 63
Well I don't think anyone will complain about these results. Just a couple tics on the 2pt and bam.
Just need to work out the HTPC stutter issues. 23Hz seems to be the best for movies. Anyone know the settings to keep the frame drops under control on the TV?
post #3378 of 9390 Old 10-05-2018, 10:51 AM
LeeSoFl's Avatar
Quoted: 522 Post(s)
Liked: 444
I have the xg1v4 and agree that leaving Comcast's box at "best" bypasses the much better upscaling capability of Sony televisions.
I'm using 720p at the box for both the Z9D and the 900F. Don't count on the difference being dramatic, and might almost be imperceptible.
Comcast reps on the other hand, would never be able to grasp that concept. Don't bother trying.
Ricoflashback likes this.
LeeSoFl is offline
post #3379 of 9390 Old 10-05-2018, 10:59 AM
Liked: 1264
Well said! Comcast would probably reply - - "I'm not sure about that, but would you like to upgrade your STB to our new 4K box! Imagine an incredible 4K picture on ALL of your channels! You'll be amazed! Can we start with your order now?"
aaronwt, bmcleod and MikeTV69 like this.
Home Theater Setup
post #3380 of 9390 Old 10-05-2018, 12:30 PM
Anderegg's Avatar
Quoted: 475 Post(s)
Liked: 271
Does your GPU go up to 119Hz? If you have Nvidia card, you create a CUSTOM resolution of 1080x1920 119Hz, which is the native refresh rate of the X900F panel, and also exactly 5x 23Hz (24p)...basically, bye bye judder. :-)
The TV doesn't report itself as a 120Hz panel to the PC, but as rtings.com shows int he specs, it will only accept this as a "forced" resolution.
Paul
Anderegg is offline
post #3381 of 9390 Old 10-05-2018, 12:49 PM
Quoted: 106 Post(s)
Liked: 63
Paul
What about for 4k? 3840 x 2160?
I am using Nvidia and it says 3840 x 2160 119hz tested successfully and would I like to save but it doesn't save. This is a GT 1030.
post #3382 of 9390 Old 10-05-2018, 12:59 PM
Anderegg's Avatar
Quoted: 475 Post(s)
Liked: 271
Sony dolby vision color space error?
So I am watching Jack Ryan Season 1 episode 5 on Amazon in Dolby Vision, lots of desert scenes and pretty much every shot even indoor scenes I am getting horribly orange faces...basically, it's like Donald Trump in every shot! All my settings are off, so no live color or anything, and I am calibrated. I went to manual color space and toggled through the REC709, DCI and BT2020...BT2020 was auto selected, but DCI seems to be the setting that looks CORRECT> Faces are not orange, and match the SDR 4k version. I think DV is using DCI color space and not BT2020, or the DCI within BT2020 is incorrectly mapped. It really is a night and day difference when you manually switch this to DCI. I suggest someone pull up Jack Ryan S1E5 switch between DCI and BT2020 (auto) and report if they see the same incorrect color space.
All my self made 4K video files are in 29.97Hz, so I don't know, but I would avoid upscaling with a GPU unless you are running Mad or something. Make sure all your motion and noise reduction functions are off, those can cause stutter sputter issues.
Anderegg is offline
post #3383 of 9390 Old 10-05-2018, 01:10 PM
LeeSoFl's Avatar
Quoted: 522 Post(s)
Liked: 444
Would someone with Neflix check this please?
Went to watch the final episode (#8) of season 5 of Arrested Development.
All I get for English audio is "English with Audio Description" or Spanish.
There is no English 5.1 original.
Netflix which co-produces the show told me.... wait for it.... it was a licensing issue. ba-dum.
Forty-eight episode over 5 seasons, and the finale has an English only licensing issue?
Would someone please see if they're getting that episode with clean English 5.1?
Thank you.
LeeSoFl is offline
post #3384 of 9390 Old 10-05-2018, 01:26 PM
Anderegg's Avatar
Quoted: 475 Post(s)
Liked: 271
I found this in a Dolby Vision white paper...looks like I am correct that the Sony implementation of Dolby Vision may not be correctly extracting the DCI (P3) primaries from the BT2020 container on this series. I am now watching the Season 2 1st episode of Man in the High Castle, and it appears to be correctly displaying it's color space with BT2020, so this may be an issue we need to manually switch color space on certain DV titles.
"Additionally, for Dolby Vision systems, P3 color gamut information is sent using the BT.2020 container"
Reference from: https://www.dolby.com/us/en/technolo...les-levels.pdf
Anderegg is offline
post #3385 of 9390 Old 10-05-2018, 01:30 PM
Anderegg's Avatar
Quoted: 475 Post(s)
Liked: 271
I see...on my X900F built in Netlfix app
English - Audio Description
English - Audio Description (5.1)
Spanish
Spanish (5.1)
Thank you.
Anderegg is offline
post #3386 of 9390 Old 10-05-2018, 01:47 PM
LeeSoFl's Avatar
Quoted: 522 Post(s)
Liked: 444
Spanish
Spanish (5.1)
Thank you. Netflix also said it could be the Sony app on their models, but I'm getting no straight English on their iphone app.
LeeSoFl is offline
post #3387 of 9390 Old 10-05-2018, 03:39 PM
denpom's Avatar
Quoted: 1325 Post(s)
Liked: 1180
has anybody directly compared 900F to 2018 Q7?
denpom is offline
post #3388 of 9390 Old 10-05-2018, 05:34 PM
Glenee's Avatar
Quoted: 327 Post(s)
Liked: 343
What were those couple of tics on the 2pt ? What mode were you using ?
Nothing's Impossible if you don't have to do it yourself ! Glenee
Glenee is offline
post #3389 of 9390 Old 10-05-2018, 06:25 PM
Quoted: 106 Post(s)
Liked: 63
So I pretty much started with the rtings settings outside of any of the grayscale settings. I didn't touch those before the calibration just so I could see how it was by default.
I did notice the slightest green push that this fixed.
SDR or HDR had no major effect on final results. It stayed green the whole scale.
picture custom
brightness 3 (or whatever fits your room best)
local dimming high
x-tended dynamic range high
color 50
Expert 1
All clarity and motion off
2pt
Max
-2
-2
0
0
-1
post #3390 of 9390 Old 10-06-2018, 10:16 AM
Liked: 0
Bought the 55inch 900f yesterday & almost ready to return it.
There's no media tab in the home screen? So I have to unplug & replug in my USB stick everytime I wanna use it? My TV from 2008 was more advanced - this has to be a mistake on my end, there's really no way to navigate to the USB? Input shows hdmi ports but I can't select the USB port? How the hell did this happen?!
HeyHeyHey1 is offline
Reply LCD Flat Panel Displays
brightness , contrast , hdr , Sony , wifi , x900f , x900f appletv dolbyvision
