TCL 65" 6-Series 4K HDR TV First Look & Review - Page 216 - AVS Forum | Home Theater Discussions And Reviews
 3964Likes
post #6451 of 7993 Old 06-16-2019, 03:38 PM
NuSoardGraphite's Avatar
Quoted: 543 Post(s)
Liked: 494
Originally Posted by rjhseven View Post
Has anyone had to buy a replacement remote WITH HEADPHONE JACK or contact TCL for replacement? I’m hearing impaired (which so many make jokes about or treat it as insignificant but minor things to some are important to us) and the headphone jack is a must for me. Can’t locate one so I contacted Roku and their response was that the remotes they sell are not compatible with TVs. TIA
If you have a smartphone, download the Roku app and use your smartphone. There is a setting in the app where it will cast the audio to the phone and output it through your headphones (or the smartphone speakers, but why would anyone do that)
Stand tall and shake the heavens...
NuSoardGraphite is offline
post #6452 of 7993 Old 06-16-2019, 03:42 PM
Quoted: 16 Post(s)
Liked: 0
Originally Posted by Bob A (SD) View Post
As far as I know the 2018 and 2019 65R615/617 are the same.
OK, thanks!
I'm currently torn between the 55" and 65" model.
the thing is most of my content as in 95% of it is 1080p, and I'm worried that 1080p being upscaled to 4k will deliver a worse picture vs 1080p being displayed on a 1080p native set
Which is why I was thinking maybe it's a better idea to go with the 55"
I currently sit about 12 feet away from 60" Panasonic S60 plasma for movies, and certain video game geners. They say you need to be siting about 8 feet away eye distance wise for optimal viewing of 1080p which is way too close for comfort unless it's for certain video games like first person games and racers foe example. What I'm saying is 4k is absolutely useless to me at this point. and it will always be useless for both movies and certain video game genres from where I'm sitting.
Donny84 is offline
post #6453 of 7993 Old 06-16-2019, 03:53 PM
Bob A (SD)'s Avatar
Quoted: 64 Post(s)
Liked: 53
Originally Posted by Donny84 View Post
OK, thanks!
Frankly I think your fears are unfounded. I sit further away than you and find my 65" just great with OTA 720 to 1080 stuff as well as up to 4K media from streaming sources.
I don't have a Blu-Ray 4K player but find my standard blu-ray deck is delivering SD DVD upscaled images that just blow away what I was getting on my old set.
-=[Bob]=-
TCL 65" 65R615, 49" 49S515, 32" L32HDF11TA
My systems
Bob A (SD) is offline
post #6454 of 7993 Old 06-16-2019, 04:03 PM
Quoted: 543 Post(s)
Liked: 494
Originally Posted by Mr.Nobody View Post
Had to decide whether to exchange it or not very soon.
I think the uniformity overall is OK, not stellar, the main bothering points for me are two dark spots (about 1/4 inch in diameter) in the center of the screen. I noticed those in the hockey DSE test video and now I can see it even in the regular content when there is gray background at that location. Also I can see brandings in the gradient color pixs although the solid color pix looked OK to me. The vignetting at all four corners, with the bottom left corner being a little standout was new to me, coming from a 49 inch LG crappy UJ6200.
I had my fair expectation as I got this in a pretty good deal, just want to make sure what I got was outside the normal range. Thanks a lot.
uniformity looks okay to me. some banding and dark corners, which is normal. Green looked the worst, but overall not bad. Where did you get those test patterns?
post #6455 of 7993 Old 06-16-2019, 04:06 PM
Quoted: 16 Post(s)
Liked: 0
I guess it depends on the TV scaler? I just want 1080p content to look crisp and clear like it would on a 1080p native set.
The 65" would only cost me less than $350 CAD vs the 55"
Also do you use local dimming in order to gain better blacks? Are there any compromises when doing so like an dimmer picture/dim whites etc?
Donny84 is offline
post #6456 of 7993 Old 06-16-2019, 04:16 PM
Bob A (SD)'s Avatar
Quoted: 64 Post(s)
Liked: 53
I've been quite satisfied with the R617 settings recommended by RTINGS.com. As far as local dimming goes:
"In the Advanced picture settings, we set the Local contrast off for the calibration process, but for regular use, you should set it to High (Local contrast is TCL's local dimming option). If you find that the screen luminance changes too much by itself depending what is displayed on the screen, you can set it to be less strong or simply turn it off."
I suspect it will depend on your viewing room environment.
-=[Bob]=-
My systems
post #6457 of 7993 Old 06-16-2019, 06:15 PM
rjhseven's Avatar
Quoted: 639 Post(s)
Liked: 103
Because Apple has capped the volume on the Roku smartphones app (the apps themselves have much lower volume than satellite/cable/others anyway as several have agreed) so I can’t hear the app programming using iPhone app. Roku remote has not had volume capped or if it has, it is much higher.
Memphis Tiger Fan-Sports enthusiast
rjhseven is offline
post #6458 of 7993 Old 06-16-2019, 08:03 PM
Quoted: 16 Post(s)
Liked: 0
Thanks again!
But, how are the blacks levels/contrast when local contrast is set to off? Rtngs scored it with an 8.9, based on a 5182:1 reading but with local contrast set to high they managed to get 6052:1.
The local contrast mode itself scored a 6.0 which doesn't seem all that impressive. They said their was clouding around moving objects or something but at least it doesn't sacrifice mush brightness. I mean the brightness overall on this panel seems more than enough as it is.
Donny84 is offline
post #6459 of 7993 Old 06-16-2019, 08:37 PM
Bob A (SD)'s Avatar
Quoted: 64 Post(s)
Liked: 53
Thanks again!
Donny,
I toyed with things 2 weeks ago when I first got the TV. Set the configuration to RTINGS recommendations and haven't looked back. Why turn the contrast off when it works set on HIGH as recommended? I tend to be rather pragmatic and found the results very pleasing for me and those who also viewed the set. Blacks are great. Haven't seen any "clouding." All the scores in the world mean jack squat to me if I like what I see.
You are obviously much more of a techie than I am and if you absolutely need some kind of confirmation or assurance for what you seek you'll have to find someone else. Sorry. Being redundant this set, configured as said, "floats my boat!"
-=[Bob]=-
My systems
post #6460 of 7993 Old 06-17-2019, 05:21 AM
UHD Addict
aaronwt's Avatar
Quoted: 9817 Post(s)
Liked: 6485
Originally Posted by quovadis123 View Post
Tcl is now the second largest producer of tv's worldwide. I wonder who the first is?
https://www.tcl.com/pk/en/news/TCL-e...h-in-2018.html
Should be Samsung. I know they used to be.
Sent from my Galaxy S10
57TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #6461 of 7993 Old 06-17-2019, 05:25 AM
UHD Addict
aaronwt's Avatar
Liked: 6485
Whoops, spelling typos,
Responsive*
Detectable*
Oh and I was just wondering is this year's TCL 6 series(R617) and 5 series exactly the same as the 2018 models? Or will there be a difference in pq ect? The 2019 6 is up for sale on amazon BTW.
Rtngs reviewed the 2019 TCL 4 series and said the black levels and contrast ratio were superb, beating out last year's 6 series and that input lag across the board was only 13ms. Unfortunately it's a very dim display at only 177 nits max and doesn't support wide color gamut. Total deal breaker
That is the native contrast ratio. So it must be a new panel. If they can combine that panel with FALD, it should really loom superb. But even though that has a better native contrast ratio tha the 6 series, it doesnt have local dimming. So I would still take the 6 series over the 4 series.
post #6462 of 7993 Old 06-17-2019, 05:55 AM
UHD Addict
aaronwt's Avatar
Liked: 6485
At what point did you folks toss your TCL 65" TV box and packing?
Right away?
After the 15 day (Best Buy) return period expired?
Other?
I waited until after my 45 day return period with Best Buy.
post #6463 of 7993 Old 06-17-2019, 05:57 AM
UHD Addict
aaronwt's Avatar
Liked: 6485
OK, thanks!
Definitely not worse on the 6 series set.
post #6464 of 7993 Old 06-17-2019, 07:48 AM
WRXpilot's Avatar
Quoted: 181 Post(s)
Liked: 171
It's also worth remembering that RTings (and most others) take their contrast ratio measurements on an ANSI checkerboard test pattern. These are not friendly with FALD, or at least don't let them show the full extent of their contrast improvement, because the black boxes are usually smaller than will allow zones to fully turn off, and are right next to 100% full white boxes. So not much 'dimming' kicks in at all.
Most content is not like that, which is why local dimming provides a much better visual impact on real content than those numbers would imply, even without hundreds and hundreds of zones.
clskinsfan likes this.
WRXpilot is offline
post #6465 of 7993 Old 06-17-2019, 08:14 AM
Dave in Green's Avatar
Quoted: 4006 Post(s)
Liked: 3175
On any device where there are multiple settings options to choose from that each offers a different balance of pros and cons I like to experiment with each to let my own eyes tell me which pros appear most important to me and which cons I can most easily tolerate. I find this works better for me than simply going by published test results or the opinions of other users whose personal preferences might be different from mine.
Dave in Green is offline
post #6466 of 7993 Old 06-17-2019, 11:31 AM
Bob A (SD)'s Avatar
Quoted: 64 Post(s)
Liked: 53
Agreed which is why I toyed with all the options before trying the RTING settings. Turns out I/we preferred the later.
-=[Bob]=-
My systems
post #6467 of 7993 Old 06-17-2019, 03:20 PM
clskinsfan's Avatar
Quoted: 17 Post(s)
Liked: 27
I honestly believe that every LCD panel is different. Hence someone elses settings could be absolutely worthless for your screen anyways. Plus I agree with you both that I want my TV to look the way I want it to look. I have professionally calibrated my PJ's in the past. And my personal opinion is they were always too dark for my liking. I ordered a 65 inch 6 series last week. The scheduled delivery date is the 23rd. So I have that itch to get my hands on it and start tinkering around with the picture.
clskinsfan is offline
post #6468 of 7993 Old 06-18-2019, 04:56 AM
dynalmadman's Avatar
I know I am not saying anything new here, but I took delivery of the TV yesterday. Took about 30 mins to unpack, set it in place and connect everything. Didn't have much to connect. Cable box and Vizio sound bar.
Powered on and WOW! This TV is spectacular. About 10 days ago, the 10 year old 42" LG finally gave up the ghost. In the interim, we used a 24" LG while searching for the replacement. I really wanted to go with LG, but the similarly priced model didn't review well, especially in a moderately dark room. So we bought the TCL and at least initially, we are blown away. I guess we watched 720p for so long, we weren't prepared for this. Incredible. I did the rtings settings real quick and I think we are happy. We aren't video geeks and like the look of the TV now just fine. ARC worked great and the sound bar powers on and off with the TV and the sound is pretty sweet.
We only watch the cable box TV shows and Netflix, Amazon prime and Plex.
My only question is about the expended warranty. My window is 12 days to purchase it. $150 for 4 more years. The general reviews of the best buy warranty are horrendously bad. I'd like to hear some opinions for you guys on that topic.
Thank you, it's good to be back here,
Michael
Ben23 likes this.
dynalmadman is offline
post #6469 of 7993 Old 06-18-2019, 05:10 AM
UHD Addict
aaronwt's Avatar
Liked: 6485
I get the Best Buy extended warranty with all my TVs I buy from them. But There are certainly other warranty options that are cheaper.
Although I've never had to use a TV extended warranty from BestBuy. But I've had good results from other BestBuy products I purchased extended warranties on. That had to be replaced or fixed.
dynalmadman likes this.
post #6470 of 7993 Old 06-18-2019, 08:20 AM
Quoted: 323 Post(s)
Liked: 91
Michael
i got the squaretrade warranty directly from costco. $65 for 3 years
mariogonzalezzz is offline
post #6471 of 7993 Old 06-18-2019, 08:52 AM
Bob Coxner's Avatar
Quoted: 156 Post(s)
Liked: 179
https://www.statista.com/statistics/...manufacturers/
Going by market share:
Samsung 16.6%
TCL 11.6
LG 11.3
Hisense 7.0
Skyworth 6.0
Sony 4.8
Sharp 3.7
Others 39
Lo, how the mighty have fallen. Some of us are old enough to remember when Sony totally dominated.
aaronwt likes this.
DirecTV since 1999
Genie DVR
Bob Coxner is offline
post #6472 of 7993 Old 06-18-2019, 10:49 AM
Liked: 3175
Originally Posted by Bob Coxner View Post
… Some of us are old enough to remember when Sony totally dominated.
And some of us are old enough to remember when American brands dominated, long before latecomer Sony showed up in 1960.
giomania and Matt2026 like this.
post #6473 of 7993 Old 06-18-2019, 12:05 PM
Bob Coxner's Avatar
Quoted: 156 Post(s)
Liked: 179
That would make an interesting discussion. Who did dominate?
Admiral? Magnavox (before being bought by Phillips)? DuMont? GE? Muntz? Motorola? RCA?
It probably depends on what era a person is most familiar with. For me, it would probably be Magnavox or RCA. If you're really ancient it might DuMont or Muntz.
Dave in Green likes this.
DirecTV since 1999
Genie DVR
post #6474 of 7993 Old 06-18-2019, 01:12 PM
clskinsfan's Avatar
Quoted: 17 Post(s)
Liked: 27
Samsung 16.6%
TCL 11.6
LG 11.3
Hisense 7.0
Skyworth 6.0
Sony 4.8
Sharp 3.7
Others 39
Sony still makes great TV's. They just need to price them competitively and they would dominate the market again. People have a hard time paying 2 or 3 times the price for something unless they are truly seeing a difference. As good as the Sony TV's are. They are not 3 times better than the "budget" TV's.
giomania likes this.
post #6475 of 7993 Old 06-18-2019, 02:32 PM
Matt2026's Avatar
Quoted: 1042 Post(s)
Liked: 28213
Mom & dad's first TV was a 1951 Admiral. I had a Sylvania B&W in the early '60s.
[Added] Westinghouse was another early producer.[More] "Television Manufacturers in USA Marketplace
From 1939 until today, there have been over 220 television set manufacturers that made sets in & for the USA market. The list below shows the major TV manufacturers. "
Matt2026 is online now
post #6476 of 7993 Old 06-18-2019, 06:04 PM
Bob A (SD)'s Avatar
Quoted: 64 Post(s)
Liked: 53
Michael,
Glad you too have found this set eye opening. I recounted my "journey" in earlier posts about a week and a half ago.
As for warranties, I looked but was really put off by Best Buy's so I passed. Part of the decision was also based on my positive experience with a 2010 TCL model that is still functioning quite well.
-=[Bob]=-
My systems
post #6477 of 7993 Old 06-18-2019, 07:04 PM
Jeff5347's Avatar
Quoted: 94 Post(s)
Liked: 24
What's up guys. I am in the market for another TV. Around xmas time I purchased a sony 900f 65 inch for my living room and love everything about the TV. We are moving now and i will be setting up the downstairs area in to a HT room. I would love for my 65 to go there but feel the room needs just a smidge bigger like 75 in. I've been teetering between getting the tcl 615 or a vizio p75 f1. I have watched and read as many reviews I can find and I see good reviews for both and bad reviews for both. I'm starting to get dizzy from all the reviews. I know the tcl still has screen uniformity issues and is that still a shot in the dark on getting a good one? Has anyone had a vizio p ( not quantum) to compare to the TCL? If you guys aren't keen on either what one would you recommend for a comparable TV in the 1500 area
Def thanks
Sent from my SM-N950U using Tapatalk
Jeff5347 is offline
post #6478 of 7993 Old 06-19-2019, 07:40 AM
Quoted: 16 Post(s)
Liked: 0
You're saying the 2019 6 series might be a new panel? I should contact CNET and see if that's true or not. If it is I'll just hold until reviews pop up. Maybe this year they improved black levels and reduced input lag
Donny84 is offline
post #6479 of 7993 Old 06-19-2019, 08:56 AM
CFC
CFC's Avatar
Quoted: 62 Post(s)
Liked: 32
Def thanks
I own both a 65R617 and a Vizio P75-F1. I like them both quite a bit.
I use the TCL in the family room, while I have the Vizio in my media room.
I think the FALD is a little better on the TCL, with a bit less blooming, and the Roku interface is miles ahead better than the current Vizio SmartCast.
Motion is a bit better on the Vizio, and it has 2 additional HDMI inputs. Black level is really great as well, though hard to compare with TCL since I'm in a completely light controlled environment vs. the wide open family room.
Judging by forum responses, it seems like the uniformity issues are about the same for each. Perhaps I got lucky, or maybe I'm not very sensitive to it, but both my sets are solid on that front.
I think you'll be happy with either.
CFC
Signature goes here
CFC is offline
post #6480 of 7993 Old 06-19-2019, 10:23 AM
CaptinCrunch's Avatar
Quoted: 354 Post(s)
Liked: 314
This just landed 1 hour ago
Sony 75X900F / MediaLight Quad 6500K
Sony X800
Denon X4400H / Outlaw 5000 (5.2.4 Atmos) AIRCOM T9
Klipsch RF-82 II, Klipsch RC-62 II, Klipsch RS-52 II, Klipsch RP-500SA
SVS PB-3000 x2
CaptinCrunch is offline
Reply LCD Flat Panel Displays
6-series , tcl
