TCL 65" 6-Series 4K HDR TV First Look & Review - Page 237 - AVS Forum | Home Theater Discussions And Reviews
 3702Likes
post #7081 of 7234 Old 09-11-2019, 06:24 AM
jizaref1's Avatar
TCL6 or sony??
Local Costco running a huge one week deal on a Sony set. So if price were exactly the same, would you still buy the TCL 55 R613 at the store, or a Sony 55 X850G?
jizaref1 is offline
post #7082 of 7234 Old 09-11-2019, 06:28 AM
Quoted: 37 Post(s)
Liked: 34
I'm pretty sure the 850 is an IPS panel, so still the TCL, no doubt. At least for me. Dark room performance matters.
Now if it were the 950G, it'd be a tighter decision.
aaronwt and theboomr like this.
TwayneP is offline
post #7083 of 7234 Old 09-11-2019, 06:44 AM
jizaref1's Avatar
I thought VA worse for off angle but otherwise equal to IPS. You think VA better?
What about the supposed uniformity or quality inconsistencies on the TCL - is that something worth worrying about?
Also interface Roku vs Sony Android - comparable for typical Netflix and Amazon apps?
jizaref1 is offline
post #7084 of 7234 Old 09-11-2019, 06:54 AM
Quoted: 144 Post(s)
Liked: 43
Originally Posted by aaronwt View Post
Originally Posted by Scottt1174 View Post
HDR you should se it to the following:
HDR- Dark
TV Brightness- Brighter
Backlight-100
Brightness-50
Contrast-100
Sharpness-5-20 anything in between
Tint-0
Color- 45-60 depending if you want want more pop.
These are my settings anyway.
I can't do the Brighter setting. It's way too bright for me in a light controlled room. With HDR normal I had TV Brightness set on Darker. And with HDR Dark I typically had it set to Dark. And bumped it TV Brightness up to Normal last night.
Sharpness I have on 20, which is the default and doesn't seem to add any sharpening. While below 20 seems to de-sharpen it.
And for the color, I recently changed it from 48 to 50, for my Game systems. WHich I use my second receiver output to go to another HDMI input on the TV. So it's always set to Game mode.
For regular HDR viewing, from my main receiver output, WHich goes to the ARC input, I recently changed color from 45 to 48. WHen I put it back on HDR Dark When I was using Normal HDR I had it set to 45.
Well that's ok. Whatever looks good for your environment. Yeah the sharp settings is wierd on this tv. Usually sharp you set to 0 but default is 20. I have mine on 20. If you set to below 20 not sure if it de-sharpens anything, maybe it does. You are using "Movie" mode correct? I use "Movie" mode when watching movies but I use "Normal" mode when playing on my Xbox X. It just brings out the colors better.
Scottt1174 is offline
post #7085 of 7234 Old 09-11-2019, 06:57 AM
Quoted: 37 Post(s)
Liked: 34
VA is better for overall picture quality. It delivers much deeper blacks/far better contrast, particularity in a dark room. IPS panels do have better viewing angles but their blacks appear very grey. Most people do prefer a VA panel, even at the sacrifice of viewing angles.
As far as screen uniformity issues with TCL, you may run into those, yes. But with Costco, you can easily exchange it. You may just get a good panel though, it's just as likely. Sony does have it's share of uniformity issues as well, so you're really open to it with any LCD TV. But TCL, Vizio and Hisense are more prone to it, it seems. In this case, I'd still go for the TCL as I wouldn't even consider any IPS panel myself. Ever.
Sony X850G - https://i.rtings.com/images/reviews/...mity-large.jpg
TCL R6 - https://i.rtings.com/images/reviews/...mity-large.jpg
The Roku interface is, I'd say about equal to Android. It's down to personal preference. Some would say the Roku interface is the best on the market because it's so snappy and versatile. It's very good! Some would say LG's is the best. Honestly most of the smart platforms in TV's are good and get the job done, aside from Vizio's, which is a bit lackluster.
TwayneP is offline
post #7086 of 7234 Old 09-11-2019, 07:26 AM
Quoted: 14 Post(s)
Liked: 5
Originally Posted by Dr.Shankenstein View Post
I am using HDR Bright on my display.
I have settled on:
contrast:50
Brightness:100
HDR Brightness:1100
Tons of shadow detail, whites don't clip allowing for great bright detail and hdr pops.
Sent from my LG-G710 using Tapatalk
On this brighter setting you’re not losing detail in the clouds? When I turned on hdr dark and dropped the hdr brightness setting I found a ton of detail around a tiny little sun that I was missing.
Dr.Shankenstein likes this.
nathan ocegueda is offline
post #7087 of 7234 Old 09-11-2019, 07:30 AM
Dr.Shankenstein's Avatar
Quoted: 739 Post(s)
Liked: 661
If you adjust while in game hold down the space bar or A button on the Xbox One it will pull up the current in game screen.
In my case anything higher than 1100 would remove the depth of clouds and the sun would just be a bright blob in the sky.
Dr.Shankenstein is offline
post #7088 of 7234 Old 09-11-2019, 10:39 AM
mjconnor10's Avatar
Quoted: 34 Post(s)
Just went to Costco, and they have a bunch of 55" and 65" models available. TCL must be making room for the new ones.
aaronwt likes this.
mjconnor10 is online now
post #7089 of 7234 Old 09-11-2019, 11:18 AM
Quoted: 14 Post(s)
Liked: 5
Oh maybe that’s what I need to try. I’ve been adjusting from the pause menu vs in the game
post #7090 of 7234 Old 09-11-2019, 01:57 PM
rjhseven's Avatar
Quoted: 614 Post(s)
Liked: 101
I recently saw a post on the 65 R615 about blooming(?) in dark scenes and poster mentioned the fix for it. Can’t find it. I’m watching too much TV right now due to health issues and the TCL is in my dark (by design) MBR. Any help would be appreciated. Fairly sure I’m using Rtings servings tweaked a bit because I like a brighter TV than many.
Memphis Tiger Fan-Sports enthusiast
rjhseven is offline
post #7091 of 7234 Old 09-11-2019, 02:38 PM
davcole's Avatar
Quoted: 127 Post(s)
Liked: 94
Question:
Was watching some 4k videos on my Firestick. One video started off SDR, then it kicked into HDR. I find that odd, so I pressed Select, to see the HDMI input, it said HLG HDR.
Uhh... when was this device updated to HLG, or is this some weird glitch?
If it does really do HLG, what apps work with it?
Sent from my GM1915 using Tapatalk
davcole is offline
post #7092 of 7234 Old 09-12-2019, 09:43 AM
Quoted: 14 Post(s)
Liked: 5
Just got an update. 9.1 . 4917 I believe.
Anyone using this. ?
mark62 likes this.
post #7093 of 7234 Old 09-12-2019, 03:50 PM
Liked: 0
Just got this too. Not sure what's changed that's different and I can't find any release notes, either.
Sent from my Pixel 2 XL using Tapatalk
jaydubbs74 is offline
post #7094 of 7234 Old 09-12-2019, 04:18 PM
UHD Addict
aaronwt's Avatar
Quoted: 9309 Post(s)
Liked: 5991
Originally Posted by davcole View Post
Question:
The most recent update enabled HLG HDR.
Last time I checked, I had not received it yet.
53TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #7095 of 7234 Old 09-12-2019, 06:30 PM
Quoted: 144 Post(s)
Liked: 43
Question:
HLG-HDR isnt available on the TCL R 6 series. I asked TCL today on Twitter . I dont know what you guys are seeing that your getting HLG-HDR.
post #7096 of 7234 Old 09-12-2019, 06:41 PM
UHD Addict
aaronwt's Avatar
Liked: 5991
I don't have it on mine yet since I have not received the last update. So I only get SDR from HLG content. But other people in this thread have posted info or pictures showing them getting HLG HDR from appropriate HLG HDR content.
I would also take what they post on twitter with a grain of salt. It wouldn't be the first time they posted something wrong about the TV.
And also with HLG HDR, the only way I would be able to view it on my 6 series setup is by connecting a device directly to my TV. Since my Onkyo receiver will not pass HLG HDR. Altough DV and HDR10 is passed through. If I ever get the new firmware I will test with some of my HLG HDR files.
Sent from my Tab S 10.5
post #7097 of 7234 Old 09-12-2019, 07:10 PM
Quoted: 144 Post(s)
Liked: 43
This came from a TCL rep. I have the new update and I don't have it. They are probably using Sky because Sky can show HLG-HDR
post #7098 of 7234 Old 09-12-2019, 08:08 PM
davcole's Avatar
Quoted: 127 Post(s)
Liked: 94
What I can tell you is this. Was watching clips on YouTube, under Stats For Nerds, it list as HLG, when watching from the Firestick 4k. I press the selected button on the Roku remote, which tells me 60hz and HD as HLG HDR.
davcole is offline
post #7099 of 7234 Old 09-12-2019, 09:25 PM
UHD Addict
aaronwt's Avatar
Liked: 5991
I can get HLG HDR from FiOS UHD broadcasts I have recorded. Plus I have HLG HDR test files.
post #7100 of 7234 Old 09-13-2019, 09:34 AM
Quoted: 144 Post(s)
Liked: 43
I hope your right but who needs HLG its strictly used for broadcasting and mostly used in the UK. Does it really matter if you can watch a YouTube video in HLG. NO not really..lol
post #7101 of 7234 Old 09-13-2019, 09:54 AM
UHD Addict
aaronwt's Avatar
Liked: 5991
US ATSC 3.0 broadcasts will use HLG for HDR.
And current US cable and Satellite UHD HDR broadcasts are also using HLG.
As far as Youtube, if the video only has HLG HDR, then I would need an HLG capable TV to be able to watch it properly. Because I would certainly rather watch a Youtube video in HDR than in SDR. And without an HLG capable TV, it will be in SDR.
post #7102 of 7234 Old 09-15-2019, 08:50 PM
Bob A (SD)'s Avatar
Quoted: 36 Post(s)
Liked: 41
My 65R615 updated on the 12th. And my 49S515 on the 13th.
-=[Bob]=-
TCL 65" 65R615, 49" 49S515, 32" L32HDF11TA
My systems
Bob A (SD) is offline
post #7103 of 7234 Old 09-16-2019, 06:10 AM
Ben23's Avatar
Quoted: 233 Post(s)
Liked: 532
Forgive me if this has been discussed. I went back a few pages and didn't see anything. A couple things.
1. Using the internal Netflix app, first trying to stream Stranger Things a couple weeks ago. Just opening the show page navigation screen (play, more episodes, etc) crashed/restarted the TV three times. Other shows played fine. Eventually, after 10-15 mins it played fine. Then last night the same thing happened with The Spy. This time I restarted my modem, and that seemed to fix it, but who knows? Once it actually plays and doesn't crash, it's flawless. Buffers in like two seconds and plays full resolution seamlessly. Don't know if it's the TV, Netflix, or my network. My network pings at 200+ MB download normally, but I fear it may be hiccuping.
2. Seem to be having more frequent issues with the TV automatically picking up the sound signal (CEC/ARC). Having to turn it off and on too frequently to reestablish the link. All cables are premium certified from monoprice and securely connected. I do not suspect it's the Onkyo given how buggy the TV has been lately. I have not changed anything with the setup.
Ben23 is online now
post #7104 of 7234 Old 09-16-2019, 10:11 AM
solarrdadd's Avatar
Quoted: 294 Post(s)
Liked: 185
ben, are you wireless or wired?
are your issues limited to Netflix only? if not, what other apps are you having issues with?
do you have any devices connected directly to either input 1 or 2 and if so, are you having any ARC issues with them?
also, include your OS version and the last time you updated it or it was updated automatically.
TCL-65R615, 55P605 DV/HDR10 & 49S405 HDR10, Philips BDP7501, BPD7502 UHD Players
Oppo BDP-105D, 105, 93, Marantz AV7702MKII, NR1607. Xbox One S
Emotiva XPA5,UPA2, UPA200 & Mini X Amps
Speakers, Polk SDA-2, Monitor 10A & 5A, Axiom M80,
VP180, QS8, M2, QS4, ATMOS 7.1.4 & 5.1.2 NYGiants!
solarrdadd is online now
post #7105 of 7234 Old 09-16-2019, 12:15 PM
Ben23's Avatar
Quoted: 233 Post(s)
Liked: 532
Wired
Yeah, Just Netflix and only those two shows had issues, and The Spy played correctly the first time (Friday night I think) but crashed last night.
Got the PS4 in input 1, no issues.
Will have to check tonight on the software. Honestly just answering those questions, it really seems to point to Netflix. Just wondering if anyone has heard about issues or had similar ones.
Ben23 is online now
post #7106 of 7234 Old 09-16-2019, 12:18 PM
solarrdadd's Avatar
Quoted: 294 Post(s)
Liked: 185
try installing Netflix on your PS4 and see if it happens then. mind you, the build and version of Netflix is probably very different between platforms, but, give it a try anyway.
I think your issue is pointing towards the version of Netflix on your TCL tv and Not the TCL tv itself.
Ben23 likes this.
post #7107 of 7234 Old 09-16-2019, 01:46 PM
vlad335's Avatar
Quoted: 88 Post(s)
Liked: 43
Which is better? I have a Samsung KS8000 65" right now and I am seeing the prices of the 65R617 at BB and am intrigued. I could take the van over and buy it right now. I could add some more cash and go up to a 75" which would be amazing in my living room.
Is the TCL 6 series a better TV? I am mainly interested in the FALD and Dolby Vision which my Samsung wont do.
I have an older Vizio in my bedroom which is FALD and there is something about the picture quality that tops my KS8000. Granted the Samsung is brighter and more vivid and does HDR but I think the Vizio is more accurate and has warmer colors.
vlad335 is online now
post #7108 of 7234 Old 09-16-2019, 01:51 PM
solarrdadd's Avatar
Quoted: 294 Post(s)
Liked: 185
I put this "Samsung KS8000 65" vs TCL 65R617" in google and got 27,200 hits.
post #7109 of 7234 Old 09-16-2019, 02:06 PM
vlad335's Avatar
Quoted: 88 Post(s)
Liked: 43
Wow! Yeah, there's tons of hits with people questioning the same as myself. Honestly didn't think of this and thought it was kind of an obscure question.
post #7110 of 7234 Old 09-16-2019, 04:55 PM
Quoted: 12 Post(s)
Liked: 0
Audio problems
Have just been setting up my new 65 TCL. Coming from a Vizio M65
I have an older Yamaha AVR - no HDMI. From my optical ports on the AVR I have the Cable port going to my cable box and the DTV port going to the TCL optical port
Watching cable, I get 5.1 where applicable when the AVR is set to Cable. When it is set to DTV I still get sound but it is only 2 channel
Watching the apps like Netflix on the TCL, I get HDR video but i do not get any 5.1 audio on any program (whether it is HD or HDR or DV) and the AVR must be set to DTV ie no sound when the AVR is set to Cable
I used to get 5.1 watching netflix through the app on my Vizio.
Any suggestions pls?? This is not my strong suit!
Also do I understand correctly that the only way I can control my volume on the AVR and change channels etc is thorugh a universal remote? No way to get the existing Roku remote to funtion in this capacity?
Many thanks!
vern7425 is offline
Reply LCD Flat Panel Displays
6-series , tcl
