Can you pick out the best and the worst upscaling? - AVS Forum | Home Theater Discussions And Reviews
 8Likes
  • 1 Post By SiGGy
  • 1 Post By Brazle
  • 1 Post By js950
  • 1 Post By js950
  • 1 Post By SiGGy
  • 1 Post By rtn5000
  • 1 Post By SiGGy
  • 1 Post By js950
post #1 of 22 Old 06-21-2018, 07:07 AM - Thread Starter
mpgxsvcd's Avatar
Quoted: 2958 Post(s)
Liked: 2617
Question Can you pick out the best and the worst upscaling?
Simple test. Can you pick out the best and the worst upscaling? Let's see if you can determine how these TVs were rated for upscaling. Just list the numbers next to each picture in order from best to worst for upscaling.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
ID:	2418816   Click image for larger version
ID:	2418818   Click image for larger version
ID:	2418820   Click image for larger version
ID:	2418822   Click image for larger version
ID:	2418826   Click image for larger version
ID:	2418828   Click image for larger version
ID:	2418830   Click image for larger version
ID:	2418832   Click image for larger version
ID:	2418836   Click image for larger version
ID:	2418838   Click image for larger version
mpgxsvcd is offline
post #2 of 22 Old 06-21-2018, 07:32 AM
js950's Avatar
Quoted: 420 Post(s)
Liked: 287
js950 is offline
post #3 of 22 Old 06-21-2018, 07:55 AM
SiGGy's Avatar
Quoted: 497 Post(s)
Liked: 412
Any of them that don't show the stair stepping and lost details are of the "better".
However, it would be best to have the original raw image in there as well (cropped the same)... without having the original/raw image you can't know what details were dropped/smeared/altered... right? This is kind a crap comparison without it IMO.
SiGGy is offline
post #4 of 22 Old 06-21-2018, 08:16 AM - Thread Starter
mpgxsvcd's Avatar
Liked: 2617
Question
Originally Posted by js950 View Post
Here is an even simpler example. Which one of these looks soft too you? Which one has more artifacts? Which one do you prefer?
8.
13.
12.
ID:	2418852   Click image for larger version
ID:	2418854   Click image for larger version
mpgxsvcd is offline
post #5 of 22 Old 06-21-2018, 08:27 AM - Thread Starter
mpgxsvcd's Avatar
Liked: 2617
Wink
That is a direct 1:1 crop of the native image. Nothing is changed. This is a valid comparison.
So do you prefer the haloing of some images over the stair step? Both are scaling artifacts.
There is also the issue that 480p is underdefined. 720x480 is technically DVD's 480p. However, that isn't 16:9 so there has to be some scaling from the source no matter what. 853.3x480 is the theoretical 16:9 480p but that is an impossible resolution. Therefore, 854x480 is often used instead.
The performance of the display could depend on whether it is fed 854x480 or 720x480. Some TVs might scale one resolution better than others. Ultimately, all variants should be tested under the same conditions.
mpgxsvcd is offline
post #6 of 22 Old 06-21-2018, 08:41 AM
SiGGy's Avatar
Quoted: 497 Post(s)
Liked: 412
Which is 1:1 crop of the native?
Um, no my point is it would be best to see the native image to compare. Displaying it on the screen it's not in it's native anymore. i.e. Provide a image/frame raw from the video source not a screenshot of it. There is no master here...
I'm not sure which I prefer; I haven't seen what the original/master looks like... is kinda what I'm trying to convey.
As well I can't put them side by side and have to use my memory to cross compare them all... PIA
mpgxsvcd likes this.
SiGGy is offline
post #7 of 22 Old 06-21-2018, 08:52 AM
Brazle's Avatar
Quoted: 159 Post(s)
Liked: 196
I was going to say that 3, 5 and 9 look best to me, but I will give the ordering a shot.
Best to worst
3
5
9
11
12
7
10
13
8
1
2
6
4
8.
13. Looks soft.
12. Has more artifacts.
I prefer 8 or 13.
Thanks for the fun game!
HT setup: Vizio 50" 4K | Xbox & PS3 | Pioneer Elite VSX-94TX | Bose 701 towers (V1) | JBL S Center | Def Tech Reference SuperCube & DIY Nearfield cabinet ported UM18 dual ported PA380 ULF+MBM
Brazle is offline
post #8 of 22 Old 06-21-2018, 09:05 AM - Thread Starter
mpgxsvcd's Avatar
Liked: 2617
Red face
Thank you for the responses. I will post what displays the pictures are from once a few more people make their assessments.
mpgxsvcd is offline
post #9 of 22 Old 06-21-2018, 09:13 AM - Thread Starter
mpgxsvcd's Avatar
Liked: 2617
Red face
The point of the test is to examine the differences between the displays all showing the same source with equivalent settings. The images are pictures of the screens for each display with the same source.
I have cropped the image down so that it can be seen on this page but the images are not altered from how the original source images looked. They are just cropped to illustrate the differences between the displays. At normal sitting distances the differences would be extremely hard to differentiate. However, magnified like this the differences become much more apparent.
Try to put them in groups. It doesn’t really matter which one is 7th or 8th. It matters more which ones you think are in the top 3rd, middle 3rd, and bottom 3rd. Just go down the list and say I like these 3 or four the best, then these 3 or 4 next, and the others get the last few places.
mpgxsvcd is offline
post #10 of 22 Old 06-21-2018, 10:36 AM
SiGGy's Avatar
Quoted: 497 Post(s)
Liked: 412
yes, it's obvious to me what the point of this is... and you can cross compare although it's a PIA. And I have.
However, You still don't get what I was saying, you haven't provided the original image/source in raw format to compare. So we could see what the image was before the TV displayed it... you could provide a JPG/PNG from the orignal source material cropped to the same section.
I certainly have images which I prefer out of the bunch, but to make an actual decision of which is *best*. Meaning which is doing the better job I'd need to compare to the original frame being displayed on my monitor...
At this point ,maybe #5 . Hard to say I can't get all of them on the screen at once... even when zoomed out.
#11 (from original post) looks like it's from a TCL panel.
SiGGy is offline
post #11 of 22 Old 06-21-2018, 10:56 AM
js950's Avatar
Quoted: 420 Post(s)
Liked: 287
I'm sorry about the rolled eyes but I have a hard time knowing which of those would look best at a proper seating position without some previous experience at this. I suspect a softer image at that distance may look better though not so at a distance.
js950 is offline
post #12 of 22 Old 06-21-2018, 12:05 PM - Thread Starter
mpgxsvcd's Avatar
Liked: 2617
Wink
These are crops of the RTINGS test images. I believe they post all of their test materials but I can't find the link right now. Maybe they took that link down?
mpgxsvcd is offline
post #13 of 22 Old 06-21-2018, 12:08 PM - Thread Starter
mpgxsvcd's Avatar
Liked: 2617
Red face
Yes that is accurate.
mpgxsvcd is offline
post #14 of 22 Old 06-21-2018, 12:10 PM - Thread Starter
mpgxsvcd's Avatar
Liked: 2617
I suspect you will be surprised what #5 is from.
mpgxsvcd is offline
post #15 of 22 Old 06-21-2018, 12:24 PM
js950's Avatar
Quoted: 420 Post(s)
Liked: 287
#2 looks good to me but like I said it mat be different at a distance.
js950 is offline
post #16 of 22 Old 06-21-2018, 12:57 PM
SiGGy's Avatar
Quoted: 497 Post(s)
Liked: 412
probably so!
#3 is quite good too comparing only the up-scaling. However the sub-pixel structure is remarkably different than the others. Makes me think it's 1:1 or a 1080p panel but hard to say without the original source to compare with.
SiGGy is offline
post #17 of 22 Old 06-21-2018, 01:07 PM - Thread Starter
mpgxsvcd's Avatar
Liked: 2617
probably so!
Again, another accurate assessment. That one is a 1080p display. It is interesting that 1080p displays typically can display 480p better than 4k displays can.
mpgxsvcd is offline
post #18 of 22 Old 06-21-2018, 01:26 PM
rtn5000's Avatar
Quoted: 84 Post(s)
Liked: 78
It's all a blur to me :P
Good idea for this little test!
rtn5000 is offline
post #19 of 22 Old 06-21-2018, 01:34 PM
SiGGy's Avatar
Quoted: 497 Post(s)
Liked: 412
I was self studying sub-pixel structures 2 years ago for some MVA LCD and OLED panels. So I can recognize some of the patterns right away; the TCL stood out because I was just looking at it last week. Not a fan of their 8 bit panel implementation /w FRC; I wish they would make a native 10bit panel like Vizio P
SiGGy is offline
post #20 of 22 Old 06-25-2018, 08:24 AM - Thread Starter
mpgxsvcd's Avatar
Liked: 2617
Here is a list of the displays used for each of the pictures.
1st post(13 displays)
1. Sony AE1 OLED
2. LG C8 OLED
3. Vizio 2017 D-Series-1080p
4. Vizio 2017 E-Series
5. Hisense H8C
6. Vizio 2016 P-series
7. Vizio 2017 P-series
8. Vizio 2018 P-series
9. Samsung Q8FN
10. Samsung Q9FN
11. TCL r617
12. Sony x900f
13. Sony x940e
2nd post(3 displays)
8. Vizio 2017 P-series
13. TCL r617
12. Samsung Q9FN
mpgxsvcd is offline
post #21 of 22 Old 06-25-2018, 11:48 AM
Quoted: 310 Post(s)
Liked: 172
There is always better upscaling with lower resolution displays. There's less data that needs to be made up from "480 to 1080" than "480 to 4k".
The best upscaling TVs 480 content, from best to worst would be: 480, 720, 1080, 4k.
A 480 CRT will display the 480 content with the least amount of artifacts, due to no upscaling. The 2nd best would be the 720 display, due to the least amount of upscaling.
move4ward is offline
post #22 of 22 Old 06-26-2018, 05:44 AM
js950's Avatar
Quoted: 420 Post(s)
Liked: 287
I had picked the C8. I find it interesting that the 900f, which I also liked, looks better to me than the 940e when it supposedly has the same processor. One reason I liked the C8 was that it didn't have as much darkening around the white ropes which some displays use as a contrast enhancer and that it looked smooth without being soft. Not as punchy as the ae1 but less etched as well. At a distance, who knows? If someone told me that those ropes had obvious winding that should be noticeably visible, I may have gone with 1 or 12. Looks like LGs new processing is paying off. I think 8 looks pretty good as far as pixel res and that display was noted for looking soft at this res. It does seem like it's contrast should be better so maybe that's the noticeable characteristic. (hunches shoulders)
Judging from responses here including mine which may be luck or wrong, LOL, it's a crap shoot at this level of magnification unless you know to look for and how it pertains to normal viewing distances.
js950 is offline
Reply LCD Flat Panel Displays
