82” Samsung Q6FN versus 75” Sony 900F? - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 2 Post By seggers
  • 1 Post By Bill-99
  • 1 Post By Bill-99
post #1 of 22 Old 07-16-2018, 05:14 PM - Thread Starter
todd1010's Avatar
Quoted: 114 Post(s)
I’m considering a larger tv for a media room. I’ve considered but don’t think I can do a projector because of a few issues with the room, so that is out.
So these two TVs are in the running. I’m a fan of the Sony tvs as I have two other 4K TVs in the house already.
I’m bias to the Sony but I’d like a larger tv but the 85” 900F is $5299, and I don’t like that at all. The Samsung is close to that size but almost equal in price by a couple hundred more bucks.
I’ve never owned a Samsung, so I don’t know much about their quality.
What do you think?
Receiver : Pioneer Elite SC-LX701
Main & Center Speakers : Phase Technology PC 3.5, & Surrounds
Amplifiers : Emotiva UPA-1 Monoblocks, SVS SB3000 Subwoofer
MonsterPower HTS5100, Harmony Elite Remote
TV & Sources: Sony 75” 900F, Bluesound Node 2, Xbox One & Apple TV4K
todd1010 is offline
post #2 of 22 Old 07-16-2018, 07:00 PM
Quoted: 564 Post(s)
Liked: 106
82 inch is 7 more then the 75inch
Sony=fald screen/Dolby vision
Samsung=7inch bigger/edge lit/
Both are the same brightness pretty much
ultraflexed is offline
post #3 of 22 Old 07-16-2018, 07:37 PM
VA_DaveB's Avatar
Quoted: 1362 Post(s)
Liked: 646
The 900F is a much better TV, so it's the usual size vs. quality. Pick one!
Regarding brightness, the meaningful measurement is the HDR Real Scene Peak Brightness where the 900F is considerably brighter - 524 cd/m2 for the Q6FN compared to 894 cd/m2 for the 900F.
VA_DaveB is online now
post #4 of 22 Old 07-19-2018, 04:49 AM
seggers's Avatar
Quoted: 180 Post(s)
Liked: 140
If you're going to compare a 82 to the 75, why not go to the 85 Sony instead?
Seggers
Blitzdog and nathanddrews like this.
Sony XBR-85X900F, Oppo 203 UHD, Denon X6300H, Emotiva UPA5 (triggered), Wharfedale Pacific Evo 40s, CS, 10s, PC DX12 sub, Def Tech A60 Atmos tops, the internet and a Nvidia Shield. There's also a Wii, but we don't talk about that...
seggers is offline
post #5 of 22 Old 08-07-2018, 03:55 PM
6athome's Avatar
Quoted: 640 Post(s)
Liked: 174
I remember reading on these forums, someone bought a 85 inch LG passive 3D TV for 16,000.00 and that was edgelit. I just seen a 85 inch Sony 900F for a little over 5,000.00,what a bargain.
6athome is offline
post #6 of 22 Old 08-07-2018, 04:00 PM
SnellTHX's Avatar
Quoted: 557 Post(s)
Liked: 414
Must have been back in 2013-14, when 85" was a ridiculously huge screen and when 4K was brand new...
SnellTHX is online now
post #7 of 22 Old 08-07-2018, 04:04 PM
6athome's Avatar
Quoted: 640 Post(s)
Liked: 174
I think you are right with that! I remember the lust for 3D that big, after reading the comment on the TV.
6athome is offline
post #8 of 22 Old 08-07-2018, 07:45 PM
johnnyknoxsvill's Avatar
Quoted: 138 Post(s)
Liked: 48
I would check out the LCD Flat Panel Great Found Deals! page and you might be shocked on the Sony 85"
johnnyknoxsvill is offline
post #9 of 22 Old 08-08-2018, 04:44 AM
yosh7's Avatar
Quoted: 187 Post(s)
Liked: 194
What if you are a gamer? I thought I saw the latency for 4K gaming on the Sony was great but not so good for 1080? Makes me think the Samsung may be a better gaming TV?
yosh7 is offline
post #10 of 22 Old 08-08-2018, 05:35 AM
nathanddrews's Avatar
Quoted: 617 Post(s)
Liked: 627
Generally speaking, doubling the frame rate will halve the input lag, even with these two TVs. Input lag between the 900F and Q6FN is ~1 frame (16ms at 60Hz, 8ms at 120Hz). Overall, both are still slower than a dedicated computer monitor. However, the Q6FN line supports FreeSync which means that when connected to a compatible PC (AMD GPU) or Xbone S/X, the refresh rate will dynamically adjust to match the framerate, eliminating stutter and tearing. That alone places it miles ahead of the 900F.
nathanddrews is offline
post #11 of 22 Old 08-08-2018, 09:25 AM
Bill-99's Avatar
Quoted: 820 Post(s)
Liked: 505
There are a couple of items that seem to not get all that much air time in TV comparisons.
Upscaling. This is perhaps more important than it might seem. While it's currently possible to stream 4K or watch it on 4K UHD disks, there's an ocean of content that will be less than 4K for a long time… perhaps until ATSC 3.0 rolls out and broadcast and streaming of 4k content become the norm. The timeline on that is pretty soft and it could take a decade or more since there's no mandate driving it. At the very least, the TV selected should have upscaling that you believe will be good enough for the period of time you own it.
HDR. Format wars make this is such a roll of the dice right now. Will Dolby Vision achieve sufficient market penetration to justify it being a high priority choice? That's not clear. Amazon and NetFlix made announcements getting behind HDR10+ but how much content will that mean? That's not clear, either. It would be great to be able to buy a TV with HDR10, HDR10+, Dolby Vision and HLG support but that's not an option between these two sets. So, you're betting on a winner and hoping you don't get the next Betamax.
Obsolescence. Neither set has HDMI 2.1 or ATSC 3.0 support. Also, MicroLED is coming (maybe). These technologies hold a great deal of promise but it also means neither TV is "future proof". OTOH, what TV is these days?
Just one more upgrade and things will be perfect.
Bill-99 is offline
post #12 of 22 Old 08-08-2018, 10:57 AM
mrpickem's Avatar
Quoted: 329 Post(s)
Liked: 199
I am an owner of the 75" 900F and have been for about 2 months. I really like the PQ, styling, connectivity and the sound is ok. The Android OS can be a little trying at time, because it is pretty slow. I tried using the built in apps but have since went back to nvidia shield for my streams. Therefor I am not really in the menu very often at all. I disabled wifi and the set perform very well. Brightness, sharpness, motion are all very good. Dolby Vision seems to be broke or at least most sources I have tried are all too dark no matter how you tweak the settings. The HDR is solid, I have tried ATV, nvidia as well as on-board apps and all give basically same result as far as DolbyVision and HDR. I would definitely recommend the TV, but it is not a flagship like was first advertised. I watch in a brightly lit room a lot and there is no issue with glare or brightness. I watch plenty of sports and motion is handled very well. You would probably would have to step up to a Q8FN to match it with Sammy.
I would have rather had a 75" Z9F but not at near twice the price.
mrpickem is offline
post #13 of 22 Old 08-09-2018, 05:47 AM
Bill-99's Avatar
Quoted: 820 Post(s)
Liked: 505
^It's disappointing that menu speed in the 900F series is bad, and it doesn't have to be that way. The NVidia Shield is very zippy and it's Android based. Sony messed this up.
May or may not be a deal breaker for potential buyers.
Bill-99 is offline
post #14 of 22 Old 08-09-2018, 07:16 AM
bigmixx's Avatar
Quoted: 266 Post(s)
Liked: 121
I picked up a 65 inch 900F on Saturday and I've already become extremely annoyed with the slowness of the interface. Makes no sense why this TV is so slow just trying to maneuver around to different apps/menus. It's a major shortcoming on an otherwise great TV.
bigmixx is offline
post #15 of 22 Old 08-14-2018, 03:11 PM
kauaidoug's Avatar
Quoted: 56 Post(s)
I bought a 55x900E last Black Friday and I love it after a LOT of research since I had no access to a Sony or TCLP605. The only thing that I didn't like with the Sony was how slow it was on the menu etc. I found a youtube site about that issue, followed the instructions to get rid of some stuff and it was much better to where I don't think about it. I am assuming the same could be done with the F but I really like my Sony, ok, I love it.
kauaidoug is offline
post #16 of 22 Old 08-16-2018, 05:19 AM
Quoted: 14 Post(s)
Liked: 9
[QUOTE=kauaidoug;56642004]I bought a 55x900E last Black Friday and I love it after a LOT of research since I had no access to a Sony or TCLP605. The only thing that I didn't like with the Sony was how slow it was on the menu etc. I found a youtube site about that issue, followed the instructions to get rid of some stuff and it was much better to where I don't think about it. I am assuming the same could be done with the F but I really like my Sony, ok, I love it.[/QUOTE
This is the website for speeding up Sony Tvs.
goldenager70 is offline
post #17 of 22 Old 08-16-2018, 10:32 AM
palehorse's Avatar
Are there any large TVs that support all four of those formats?
palehorse is offline
post #18 of 22 Old 08-16-2018, 11:35 AM
Bill-99's Avatar
Quoted: 820 Post(s)
Liked: 505
^I'm not aware of any at the moment. But it seems kind of inevitable to me that some manufacturer will view this as a competitive advantage and start offering it.
palehorse likes this.
Bill-99 is offline
post #19 of 22 Old 08-16-2018, 06:49 PM
palehorse's Avatar
I hope you're right.
In the mean time, do you happen to know which ones support 3 of the 4? (Preferably DV, HDR10, and HGL)
post #20 of 22 Old 08-16-2018, 07:07 PM
Bill-99's Avatar
Quoted: 820 Post(s)
Liked: 505
LG seems to support DV, HDR10 and HLG. Samsung does not support DV. Sony... Sometimes all 3. Best to check any set of interest carefully.
Sent from my Pixel 2 using Tapatalk
Bill-99 is offline
post #21 of 22 Old 08-19-2018, 05:49 PM
kelliot's Avatar
I just replaced my projector with a Samsung UN82NU8000. I couldn't be happier. Black level is low enough. Its a bright room and the TV is bright enough. The reflections are OK on a bright day, but spec'ed as good or better than the Sony. My price was great, enough said, no price talk.
I'm convinced there is a lot of marketing in perceived TV quality.
Ken Elliott
kelliot is offline
post #22 of 22 Old 11-18-2018, 06:37 PM
d3miller's Avatar
Liked: 4
I was having the same debate. Looks like the 75” 900F can be had now for ~$2800. I got the 82” Q6FN for $2600. I figured I would appreciate the extra ~20% size (I think I did that math right, taking surface area into account instead of diagonal inches) over the enhanced picture quality in the Sony. It’s going in a dark room with no windows. I’m curious what the OP went with. I’ll update this thread after the TV arrives (about 10 days) and will let y’all know how I like it!
d3miller is offline
Reply LCD Flat Panel Displays
