Official Sony Master Series Z9F 75/65” Owners Thread (2018/2019) - Page 102 - AVS Forum | Home Theater Discussions And Reviews
 4137Likes
post #3031 of 5661 Old 10-23-2018, 11:17 AM
woppy101's Avatar
Quoted: 45 Post(s)
I do see a thick vertical line on the shot of the ocean on the top right tv
woppy101 is offline
post #3032 of 5661 Old 10-23-2018, 11:34 AM
JD23's Avatar
Quoted: 558 Post(s)
Liked: 328
Originally Posted by travisamc View Post
Input lag on the Z9F may not be as quick as the Q9FN but it’s still fast. The fact that 1080p doesn’t take a hit is a major selling point for gamers like me, too.
Even if a game on the Xbox One X is not rendered in 4k, the console will upscale and output in 4k, as is the case with the PS4 Pro. The lower input lag of the Z9F for 1080p is certainly beneficial, but not critical if you are gaming mostly on consoles that output in 4k. My x930e has roughly the same input lag as the Z9D and I actually haven't played a single game on it yet that was not upscaled to 4k by the PS4 Pro.
JD23 is offline
post #3033 of 5661 Old 10-23-2018, 03:36 PM
Pres2play's Avatar
Quoted: 877 Post(s)
Liked: 393
Thank you for mentioning this. I want to say that I think the line you see is a shadow effect from a 75" Samsung OLED (oops! LG) display hanging in the corner, right next to the Z9F. It's perpendicular to the Z9F, as seen in the last image, and it's mounted at almost the same height as the Z9F. I say this because other images don't show this darkened area taken from a slightly different angle. But it may also indicate a dimming issue with the set. I will have return to the store and check this again. Thanks!
PS... the store lights can be seen on the TV in the bottom left
Pres2play is offline
post #3034 of 5661 Old 10-23-2018, 03:56 PM
Pres2play's Avatar
Quoted: 877 Post(s)
Liked: 393
One other thing I want to mention that stood out to me while watching this particular movie, that does not show up in the images I posted, is the noise in the bright sky scenes. All the sets seem to have trouble with it, except the Z9F. It was solid all the time.
And I'm not talking about battle noise. ha-ha.
shoman94 likes this.
post #3035 of 5661 Old 10-23-2018, 07:42 PM
helvetica bold's Avatar
Quoted: 1724 Post(s)
Liked: 1078
I finally watched some HDR game footage on the Z9F, specifically Battlefront 2, Gears 4 and Battlefield 1. Ive never seen such intense HDR! I didnt noticed any issues with contrast regarding gaming. My only concern is that the Z9F is too bright for a dark room, lol.
helvetica bold is online now
post #3036 of 5661 Old 10-23-2018, 11:24 PM
sgupta's Avatar
Quoted: 250 Post(s)
Liked: 168
Real-world reports continue to impress me and make me think I'll be ordering one of these when they become available (hoping it's okay to post here as while I'm not yet an owner, I'm a serious prospective buyer).
thomasfxlt likes this.
sgupta is offline
post #3037 of 5661 Old 10-24-2018, 02:29 AM
Astennu's Avatar
Quoted: 144 Post(s)
Liked: 43
For the people that say the XF900 does better / performs similar to the ZF9:
55XF900
65ZF9
The pictures above are overexposed to clearly show the effect. Its not that bad in reality (Source dutch site: https://www.homecinemamagazine.nl)
I can imagine the 75" doing a lot better with its 288 zones vs 104.
HT Setup: Sony 75X940E - Denon X4400W 5.2.4: - SVS Ultra Bookshelf (Front) - SVS Ultra Center - SVS Prime Bookshelf (surround) - 4x Jamo S622 (Height) - Dual SVS PC2000 Sub's
Astennu is offline
post #3038 of 5661 Old 10-24-2018, 04:52 AM - Thread Starter
thomasfxlt's Avatar
Quoted: 3322 Post(s)
Liked: 6165
So I’ve been experimenting with the HUE Play lights that I received on Monday. I started a separate thread and have posted a few pics. There’s definitely benefit using these with the Z9F. A little bias light goes a long way for 2 reasons. 1. Adding a little backlight ambient makes the intense HDR a little less startling on your eyes. 2. Any perception of flashlighting in the cinema bars is significantly diminished in low APL scenes. I used these for 2 evenings now and I’m definitely going to keep them.
There is no present way to dynamically vary the light intensity with scene luminance (unless you’re driving your content from a PC which can run the HUE sync app). What I’m choosing to do is to set the lights up about 5% from the lowest setting. At this level, they’re only perceptible at the lowest APL scenes. I think ideally, you’d use these at nearly the lowest setting for low APL and boost to about 5% for everything else. It would be great if at some point those could be integrated with some type of remote photo-sensor where you could set a threshold range based on screen output (at a specific color temp).
I can’t really comment on this vs other solutions other than to say that the ability to tune your color allows for you to compensate for your room influences. Also, the color is simply a fun way to add some dynamics to your room ambiance. I’ll probably use the color for sports and entertaining.
Discussion here: https://www.avsforum.com/forum/166-l...-displays.html
SONY Z9F LCD Master Series Owners Thread
Vizio 2016 P series FAQ, general info and Help
Sony Z9F 75, Vizio P75C1 UHD/HDR/DV, Pioneer Elite SC-95, Samsung UHD Bluray K8500, AppleTV 4K, CC Ultra
thomasfxlt is offline
post #3039 of 5661 Old 10-24-2018, 05:03 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6165
55XF900
65ZF9
I’m a 75 owner and I’ll simply add that the dimming on mine is exceptional. Gravity may be one of the best ways to test for dimming and bloom performance. It’s really great. I’m finding I like black level set to about 47-48 on this display. I think 50 is just is a bit elevated IMO.
AustinJerry, davehale and shoman94 like this.
post #3040 of 5661 Old 10-24-2018, 06:14 AM
Quoted: 90 Post(s)
Liked: 38
I have to say after being chastised here for being critical on this set I am warming to it now after having seen it in person and am actually seriously contemplating buying the 75" now.
Thomas is the only one who has given an in depth review of the 75". I would rather wait for more owners to post reviews and actually be able to see the 75" on display before pulling the trigger.
I too am looking at bias lighting. My preference would be a dim grey 6500k constant light for night time viewing. I think that would go a long way to addressing fears I would have on elevated black bars when watching movies at night. Based on where I live the Z9F costs almost half a Q9FN for the 75" size and I think there are many things this set does better than that set. All else being equal I would have gone for a 77C8 but it would be more than double the cost of a Z9F.
Yes I am not an owner but serious potential buyer too. I can't wait to see a 75" properly and eagerly awaiting Vincent Teoh's review too.
Marco Giubin is offline
post #3041 of 5661 Old 10-24-2018, 06:26 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 11295 Post(s)
Liked: 6700
I suggest you also consider the Ideal-Lume bias lighting by Cinemaquest (https://www.cinemaquestinc.com/ideal_lume.htm). The lamps are 6500K white with an adjustable baffle to control the lighting intensity.
MISTRV likes this.
AustinJerry is online now
post #3042 of 5661 Old 10-24-2018, 06:33 AM
Astennu's Avatar
Quoted: 144 Post(s)
Liked: 43
Same here. After the DV update on my 940E im now using black level 49 and sometimes 47 (depending on the content). Never needed that before but ok this works to get the blacks black again.
I might try a Hue light still got two E27 lights to make a test setup. If it works well i can mount those or get Hue Play. For the current implementation that Sony used after DV updates it might be the trick to make the bars look more black. (to bad its a downgrade for the 940E in that regard. Never needed things like that when the TV was new with older firmware. Black bars where not that active)
But since to many people and the press are complaining about the black bars i think sony will try to fix this in the future. If they can fix that the Sony FALD LCD tv's will be Phenomenal.
Astennu is offline
post #3043 of 5661 Old 10-24-2018, 07:13 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6668 Post(s)
Liked: 6656
Originally Posted by BlueChris View Post
Like my zd9 when apps load the local dimming is off no matter what the menu says. It's observed almost 3 years now in all Sony with android.
I wish they would fix that already
BlueChris likes this.
Cleveland Plasma is online now
post #3044 of 5661 Old 10-24-2018, 07:28 AM
BlueChris's Avatar
Quoted: 516 Post(s)
Liked: 286
Well it's more psychological than a real problem.
Cheddarhead likes this.
BlueChris is offline
post #3045 of 5661 Old 10-24-2018, 10:29 AM
Liked: 6700
I certainly agree that it looks like LD is off when the app is loading, but I am not understanding why it is not reflected in the menu.
Why? Should we really care what the loading screen looks like, as long as playing content looks OK? The only real issue is when people who don't understand this behavior get excited that their display isn't performing properly. Other than that, who cares?
shoman94, smurraybhm and jrref like this.
post #3046 of 5661 Old 10-24-2018, 12:01 PM
BlueChris's Avatar
Quoted: 516 Post(s)
Liked: 286
From what i feel maybe and i say maybe when an app is loading some things go off as matter processing like LD and they go on when the app is fully loaded and Sony does that to speed app launching by freeing memory or processing power.
post #3047 of 5661 Old 10-24-2018, 12:23 PM
Liked: 6700
Maybe. But can we all agree that the video quality of start-up screens is not representative of the overall performance of the display, and should not be used as examples of something wrong with the display?
thomasfxlt, BlueChris and jrref like this.
post #3048 of 5661 Old 10-24-2018, 02:53 PM
js950's Avatar
Quoted: 433 Post(s)
Liked: 297
Only if it fits our agenda.
js950 is offline
post #3049 of 5661 Old 10-24-2018, 06:04 PM
marklivia's Avatar
Quoted: 108 Post(s)
Liked: 60
Originally Posted by js950 View Post
only if it fits our agenda.
Good one!!!
Sony 940D 75", Yamaha RX-A3060, Panasonic UB820, Fronts-Gallo Sig 3.1, Center-Gallo StradaII, Sides-Gallo StradaII, Rears-Gallo Adiva Ti SS, (4) DTS-X/Atmos-Gallo Adiva Ti , Custom Made Subs (2)- Sealed 3/4" Baltic Birch w/ Ascendent Audio Avalanche 15" drivers w/ Speaker Power SP1-700-HT Plate amps.
marklivia is offline
post #3050 of 5661 Old 10-24-2018, 08:11 PM
kenmann's Avatar
Quoted: 124 Post(s)
Liked: 43
As dire straits would say, "I want my new TV". Been waiting for 2 months on the 75 z9f, but actually waiting for 2 years for a TV with these features.
iphilologos likes this.
kenmann is offline
post #3051 of 5661 Old 10-24-2018, 10:35 PM
Quoted: 18 Post(s)
Liked: 7
Thomas could you paste your settings for bright and dark environment please? Or point me to post if you already did. Thanks.
tchabada is offline
post #3052 of 5661 Old 10-25-2018, 04:19 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6165
Dark Room: SDR adjustments to Cinema/Custom
Picture Mode: Cinema or custom
Brightness 5 = 120nits (I use this most)
Brightness 8 = 160nits
Turn off the auto brightness adjustment
Contrast @ default
Gamma -2
Black level: 48-50 (your taste)
Black adjust: Off or Low
Adv Contrast Enhance: Off
Auto Local Dimming: Med/High (I see a very small difference)
Xtended Dynamic Range: Low with SDR, OFF with HDR.
High Ambient.
Increases brightness to taste.
Some like a cooler Pic Mode
Use Xtended Dynamic Range to add some punch
mostly everything else the same.
post #3053 of 5661 Old 10-25-2018, 04:40 AM
Quoted: 18 Post(s)
Liked: 7
Contrast @ default
Gamma -2
High Ambient.
Thank you.
tchabada is offline
post #3054 of 5661 Old 10-25-2018, 04:43 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6165
Thank you.
So have you bought one of these? If so, which size?
post #3055 of 5661 Old 10-25-2018, 04:45 AM
Astennu's Avatar
Quoted: 144 Post(s)
Liked: 43
Sometimes i get the idea that app overlay menu's also disable the LD in that section but im not sure. There is quite some blooming when the netflix bar's popup but they are white/grey transparent not really ideal for LD i guess.
Astennu is offline
post #3056 of 5661 Old 10-25-2018, 04:47 AM
Quoted: 18 Post(s)
Liked: 7
I am in Europe, ZF9 75" tomorrow. I upgrading from 2011 Sony Bravia KDL-40W4000 Bright living room.
tchabada is offline
post #3057 of 5661 Old 10-25-2018, 04:50 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6165
Getting closer to certain vendors supposedly getting their belated shipments of 75” Z9F’s. Fingers crossed for those waiting.
post #3058 of 5661 Old 10-25-2018, 04:54 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6165
Congrats #3 ! Let us know how it goes.
post #3059 of 5661 Old 10-25-2018, 05:36 AM
Brahmzy's Avatar
Quoted: 690 Post(s)
Liked: 524
The no local dimming thing on app screens is annoying yes. Also during bootup the Android animation first starts out with LD enabled and it’s got the nice inky blacks, then it turns LD off while the set finishes booting - that’s especially annoying, lol.
It’s a SONY thing. The worst is the Amazon and Netflix loading screens.
Luckily I spend most of my time running of the HTPC and Kodis menus, disc covers etc look gorgeous.
I have this bad feeling my local Magnolia is going to get a 65 hung up and not a 75. I need to swing in there to persuade them. Need to see the 75.
HTPC | NAS | Harmony Elite | DENON X4200W | Sony XBR75X940D
Philips BDP7501 | Klipsch RF7II, RC64II, CDT5650CII | SVS SB2000 x2
Brahmzy is offline
post #3060 of 5661 Old 10-25-2018, 06:48 AM
amblinfan's Avatar
Quoted: 240 Post(s)
Liked: 118
I Finally got some good time in at a Sony event to check out this and the A9F and came away very impressed with the Z9F. They still say the Z9D is brighter but the Z9F was much stronger than i thought it would be. Great depth to the image and just looks fantastic even with challenging content like Ozark on Netflix. Saw such little issues with blooming it wouldn't even bother me but it had such control of the image in it's "Netflix mode" that it more than impressed the crowd.
LIVING ROOM - Sony XBR65Z9D; Marantz SR7011; ATI 1805 amp; Triad Silver 5.1.2 Atmos; Oppo 203; AppleTV4k; Roku Ultra; Panamax M5400PM; Control4 HC800
UPSTAIRS LIVING - Sony XBR65X930E; Sony STRZA2100ES; Sonance SB46L 3.0; Triad InRoom SlimSub; Sony UBPX800; AppleTV4k; Roku Premiere; Panamax M5300PM; Control4 EA1
amblinfan is offline
Reply LCD Flat Panel Displays
