NEW Hue Play accessory/bias light for flat panel displays - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #1 of 45 Old 10-20-2018, 10:49 AM - Thread Starter
thomasfxlt's Avatar
Quoted: 3332 Post(s)
Liked: 6192
My HUE Play 2-pack will arrive Monday. These are flat panel mountable (or independent standing) accessory/bias lights for flat panel televisions. They have both white and 16mm color function and work off the HUE hub that you may already own. I’ll post some pics and impressions after I’ve had a chance to mess with them on Monday evening. I think the nice thing about this solution vs the light strips is that these can migrate to a new television easily. Whether 2 is enough for a 75” display is to be determined.
Here’s a link to the Phillips website for those not aware of this new addition to their lineup. https://www2.meethue.com/en-us/p/hue...pack/7820230U7
SONY Z9F LCD Master Series Owners Thread
Vizio 2016 P series FAQ, general info and Help
Sony Z9F 75, Vizio P75C1 UHD/HDR/DV, Pioneer Elite SC-95, Samsung UHD Bluray K8500, AppleTV 4K, CC Ultra
thomasfxlt is offline
post #2 of 45 Old 10-20-2018, 02:06 PM
js950's Avatar
Quoted: 464 Post(s)
Liked: 325
I suspect one centered might be enough for the blacker bars effect depending on dispersion. Looks a little more directional than a light strip. What interests me is whether you can use the color aspect to offset wall color to something more color neutral and whether it affects the perceived picture quality.
thomasfxlt likes this.
js950 is offline
post #3 of 45 Old 10-20-2018, 02:58 PM - Thread Starter
thomasfxlt's Avatar
Liked: 6192
That’s the first thing I’ll be testing. That will work for sure.
js950 likes this.
post #4 of 45 Old 10-21-2018, 08:04 AM
markg35's Avatar
Quoted: 364 Post(s)
Liked: 289
Very interested.I'm sure my wife wouldn't be up for painting the wall.
markg35 is offline
post #5 of 45 Old 10-22-2018, 01:46 PM - Thread Starter
thomasfxlt's Avatar
Liked: 6192
I received them. I’m a big fan of the HUE product. Not a big fan of the prices. The build quality of these is adequate for how they’re used. They come with 2 sets of mounting stands/plates. One set is designed to stand them vertically and the other horizontally. I tried them vertical on my speaker towers but I found them a little distracting that way. I’ve opted to mount them horizontally on the back-center of my 75” display. You can see from a few of the pics, light coverage is pretty good. I use a wall mount though and I typically have the tv out about 18-24” from the wall. I think the closer it is to the wall, the more likely you’d want a third. This is a 2 light installation. These integrate with the HUE hub so if you have HUE already, you’re set.
They get very dim. Dim enough that it’s just enough power for extremely low APL scenes (which is how I’ll likely use them). You can dial in whatever color you like and that will allow you to offset a wall color.
Mostly I’ll use them for movies but I think they’ll be a fun addition for hockey and football (a more colorful application with brighter settings on the TV).
I’ll post some brighter, color pics later.
ID:	2471932   Click image for larger version
ID:	2471934   Click image for larger version
ID:	2471936   Click image for larger version
ID:	2471940   Click image for larger version
ID:	2471962   Click image for larger version
lucacow likes this.
post #6 of 45 Old 10-22-2018, 03:32 PM
bobbino421's Avatar
Quoted: 1362 Post(s)
Liked: 879
Hey your cinema bars are black! What color and what light percentage did u use in the first pic?
Sony 55 A9F
Panasonic DP-UB820
Sony UBP-X700
Denon X4500H AVR
Klipsch 5.1.4 Dolby Atmos with Martin Logan 1000W SUB
bobbino421 is offline
post #7 of 45 Old 10-22-2018, 04:54 PM - Thread Starter
thomasfxlt's Avatar
Liked: 6192
There are 4 preset white color temps. That one was approx 3500k. I like it a little warmer because my walls (for the time being) are a pale blue. That was set to about 20-25%
post #8 of 45 Old 10-22-2018, 10:48 PM
js950's Avatar
Quoted: 464 Post(s)
Liked: 325
Hard to tell from pics but the 3rd one with the whatever color brownish background that is, is affecting the the way I perceive the color of his face and wood (grayer). May just be the scene or camera but is your personal perception that this may be slightly de-emphasizing whatever color the wall is displaying? Can't see how a 6500K white light that's been recommended would be beneficial with your blue wall color. looks like a keeper once you're settled in with it.
js950 is offline
post #9 of 45 Old 10-23-2018, 04:37 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6192
Tough to get the white balance correct with a phone cam. The warmer white settings neutralize the wall color. Using the near-6500k setting I get blue so I’ll be playing with something in between. In addition, the lamp intensity affects it too so finding a nice compromise will take some fiddling.
Just to give you some idea of how strong these are, here’s a few color pics.
ID:	2472162   Click image for larger version
ID:	2472164   Click image for larger version
js950 likes this.
post #10 of 45 Old 10-23-2018, 04:42 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6192
Again, brighter than I’ll use it but this one shows the wall color neutralized.
js950 likes this.
post #11 of 45 Old 10-23-2018, 04:51 AM
js950's Avatar
Quoted: 464 Post(s)
Liked: 325
Looks good.
js950 is offline
post #12 of 45 Old 10-23-2018, 06:44 AM
bobbino421's Avatar
Liked: 879
Looks like 2 bars are enough then?
Sony 55 A9F
Panasonic DP-UB820
Sony UBP-X700
Denon X4500H AVR
post #13 of 45 Old 10-23-2018, 07:16 AM
helvetica bold's Avatar
Quoted: 1964 Post(s)
Liked: 1276
You can set it to white 6500K correct? Also one has full dimming control? I have a 55” TV with white walls and I’m thinking I might be able to get away with one bar.
I’ve read when viewing HDR content a bias light of 5 nits it’s all that’s needed.
LG65C9, XBOX ONE X, PS4PRO, APPLE 4K, SONY STRDN1070, Q Acoustics: 3010i & 3090Ci
helvetica bold is offline
post #14 of 45 Old 10-23-2018, 07:29 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6192
I think if you are as far out from the wall as I am most of the time, 1 would work. The closer you get to your wall, the more you’ll need.
post #15 of 45 Old 10-23-2018, 07:31 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6192
There are 4 pre-programmed white color temps. The coolest of the 4 is probably 6500k. You can custom set the white point infinitely however.
They go pretty dim. Full dimming control yes, with the HUE hub and app. The hub is not included with these.
post #16 of 45 Old 10-24-2018, 06:22 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 12423 Post(s)
Liked: 7423
You have not mentioned how these are powered off and on. Are they connected to a USB port on the display? If yes, when you power off the display, do the lights power off immediately?
My Ideal-Lume bias lights require 120v power. I have them connected to a special power strip that senses when the TV is powered off, and subsequently powers off the bias lights. However, the behavior is somewhat peculiar. When the TV is powered off using the off button on a remote, the TV actually continues to draw power for 2-3 minutes, and the power strip controlling the bias lights doesn’t turn them off until the TV stops drawing power in the background. I suspect the TV is doing something like checking for updates, which is why it is drawing power. I even plugged something into one of the TV USB ports and verified it was still active for 2-3 minutes after a power off. Kind of strange, but actually handy, because it keeps the room light enough for me to collect my things as I am leaving.
The Phillips lights look nice, but I am not sure whether I would ever use anything but the white lighting. With those colors, all you need now would be a disco ball.
helvetica bold and thomasfxlt like this.
AustinJerry is offline
post #17 of 45 Old 10-24-2018, 06:47 AM
Quoted: 115 Post(s)
Liked: 25
I use the Hue light strip plus with a couple of extenders on My 75" z9d. Have several other hue lights and a hub and have My living room lights and light strip programed with a harmony elite controller. I love the setup. I spent a couple of dollars on an app called Hue Lights that lets you tweak the lights a little more that the stock app.
brianmorris82 is offline
post #18 of 45 Old 10-24-2018, 07:01 AM
bobbino421's Avatar
Liked: 879
The Phillips lights look nice, but I am not sure whether I would ever use anything but the white lighting. With those colors, all you need now would be a disco ball. [IMG class=inlineimg]/forum/images/smilies/wink.gif[/IMG]
Philips HUE works off of WiFi and an app but they have to have an external source for power
Sony 55 A9F
Panasonic DP-UB820
Sony UBP-X700
Denon X4500H AVR
post #19 of 45 Old 10-24-2018, 07:05 AM
bobbino421's Avatar
Liked: 879
It also helps if you already have a current HUE ecosystem
Sony 55 A9F
Panasonic DP-UB820
Sony UBP-X700
Denon X4500H AVR
post #20 of 45 Old 10-24-2018, 09:05 AM
lewlew's Avatar
Quoted: 94 Post(s)
Liked: 26
In your picture #2 below, the light diminishes/fades from the panel outwards very nicely. However it shines brightly on the ceiling. Have you been able to lessen this distraction?
Samsung 75Q7F, ATV4K, Tivo Roamio OTA, RF-20
lewlew is offline
post #21 of 45 Old 10-24-2018, 09:31 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6192
I use a Harmony Elite and hub. You can program the HUE in the Harmony app as a home automation device. After that any scene you’ve created can be used in an Activity you create (watching a movie, watching football, turning off everything etc).
My examples of “color” are extreme for sure. I do find many of the color scenes available for preload are very nice at lower luminance.
post #22 of 45 Old 10-24-2018, 09:36 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6192
Well, that’s the problem with family rooms. They tend to be typical room colors. Honestly, the display itself lightens up the entire room too. I plan on painting the room and will probably use a few shades darker on that back wall and soffit ceiling. Being a multipurpose room, I don’t want to go too dark.
The obvious thing to do would be to darken that soffit ceiling. Another option would be to use a a hinged baffle mounted above the light. My problem is I move my tv around quite often based on who’s sitting and where. Mostly the angle changes which would affect the spill pattern anyway.
post #23 of 45 Old 10-24-2018, 09:42 AM
getbigg21's Avatar
Quoted: 132 Post(s)
Just wish the colors would change depending on the scene of a movie like their tv's did years ago.
getbigg21 is offline
post #24 of 45 Old 10-24-2018, 09:42 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6192
I just wanted to make note again that my display is out quite far from the wall on an articulating wall mount. The closer you are to the wall, the less spill you will have but it will also mean that 1. your lights will have more focused intensity, 2. you will likely need more lights to cover a bigger display.
At low luminance, I have not found the spill onto the ceiling to be a distraction. That would be minimal anyway in most applications as most people don’t have their tv’s 20” away from the wall.
post #25 of 45 Old 10-24-2018, 09:46 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6192
That works with their HUE Sync app but the content has to be coming from a ripped file on a computer (which is impracticle for 4k movies and the application doesn’t support streaming services). I’d be happy if you could simply add a general sensor for luminance that would increase and decrease the brightness inside of a set range at a specific color.
post #26 of 45 Old 10-24-2018, 10:02 AM
kirth's Avatar
Quoted: 31 Post(s)
I use the Hue light strip plus sections with extenders on my 75", as well. I did not peel off the adhesive backing but instead affixed them to the back of the TV with easily removal plastic holders. Command Outdoor Light Clips, Clear, 16-Clips (17017CLR-AWES)
I also have a Bloom behind my stand pointed at the wall that can be color adjusted independently from the bias lighting. The rest of the room is covered with various Hue bulbs and lamps. I control everything with a Harmony Hub, Alexa, Google Home, Siri, or a variety of iOS apps. My wife says its the best thing we've done to our home in the the last ten years.
kirth is offline
post #27 of 45 Old 10-24-2018, 05:41 PM
convexmacrolabs's Avatar
Quoted: 52 Post(s)
Liked: 47
There is a version of the Hue app for computers, and it supports adjusting the color based on any content being output by the computer, including streaming video or games. This requires that you have your computer connected to your TV / AVR, though.
convexmacrolabs is offline
post #28 of 45 Old 10-24-2018, 06:37 PM
JD23's Avatar
Quoted: 874 Post(s)
Liked: 555
Two questions:
1) How do these mount to the back of the TV?
2) Is it possible to control the lights if one does not have a Hue hub? Can they be fully controlled with a smartphone app?
JD23 is online now
post #29 of 45 Old 10-24-2018, 06:41 PM - Thread Starter
thomasfxlt's Avatar
Liked: 6192
Originally Posted by JD23 View Post
Two questions:
1. There's a mount and some double sided mounting pad/tape.
2. No. The hub is required.
post #30 of 45 Old 10-25-2018, 04:41 AM - Thread Starter
thomasfxlt's Avatar
Liked: 6192
I’m going to be using these lots. A little bias light goes a long way with eye fatigue and HDR (not to mention the perceptible enhancement to black level). Even with these set to a low level while watching a DV film, I find myself not being as startled by peak luminance elements. After you get over the novelty of playing with them and just start letting them be a background thing, you get the benefit without really noticing them at all. A perfection of these would be an APL sensor that would raise and lower the luminance of the HUE @ a set color between the lowest setting and a peak setting (set by the user). As they are, I’m setting these to 5 on their power scale (set to a white point that makes my backwall neutral). The only time the light is perceivable is in extremely low APL. The more you use them, the less you notice it and the benefit is awesome.
With normal viewing the backlight is just a nice ambient addition to the room and the subtlety of color variation in finding a good mix for your mood/room/content is outstanding.
js950 likes this.
Reply LCD Flat Panel Displays
