2019 Samsung Q70R QLED Owner's Thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 299Likes
post #61 of 1552 Old 03-18-2019, 08:37 AM
Quoted: 107 Post(s)
Liked: 42
I pray these have less DSE than Q8FN's because those were unusable with all the dark splotches everywhere.
FantasticGrand is offline
post #62 of 1552 Old 03-19-2019, 10:55 AM
jrumph's Avatar
Originally Posted by CrocD View Post
Note that the 49" Q70 has only a 60Hz panel ("Motion Rate 120"). The 55" and higher have a 120Hz panel ("Motion Rate 240").
Don't be fooled by the "Motion Rate 120" marketing-speak.
I was going to get the 49" as a computer monitor, but I am looking at the 55" now.
How much of a negative is the lower refresh rate on the 49"? The 49" would fit perfectly in the space above our fireplace, which is what has led me to the Q70. The 55" might work, but would have to sit in front of some trim and wouldn't look nearly as nice in the room. I had resigned myself to the 49", but now that I learn it has a lower refresh rate I'm a little concerned it won't be as good of a tv. Any thoughts? Thanks.
jrumph is offline
post #63 of 1552 Old 03-19-2019, 12:57 PM
amintz's Avatar
Originally Posted by dcx4610 View Post
Lots of requests for subtitle performance impressions. I'll try to get to get around to testing that as soon as possible.
Has anyone had a chance to see if this is still an issue. I'm looking to buy mine today, but we watch a lot of TV with the CC on.
amintz is offline
post #64 of 1552 Old 03-19-2019, 03:09 PM - Thread Starter
dcx4610's Avatar
Quoted: 49 Post(s)
Liked: 53
Haven't had a chance to really spend time testing this. Sorry.
dcx4610 is offline
post #65 of 1552 Old 03-19-2019, 03:10 PM - Thread Starter
dcx4610's Avatar
Quoted: 49 Post(s)
Liked: 53
I went to Best Buy and can confirm that several Samsung models (not just the Q series) had the "strip" above the bezel that I keep complaining about. That makes me feel better. I was just hoping I didn't get some kind of B stock. It just looks like what Samsung does on certain displays. I still don't know the logic behind it but I can live with it.
dcx4610 is offline
post #66 of 1552 Old 03-19-2019, 03:48 PM
Quoted: 101 Post(s)
Just schedlued 9-1 on monday with AGS for delivery. Biased lights came in today from amazon
Mike Wheaton is offline
post #67 of 1552 Old 03-21-2019, 07:54 AM
Thrust-Bot's Avatar
Quoted: 79 Post(s)
Liked: 90
Im now proud owner of an 82Q70R.
This tv is replacing a 75Q8FN, I enjoy the larger screen, there is no replacement for displacement. Last evening I was able to sit through an NHL game and enjoy it, very little if any dse on this 82, I cant say that about the Q8 which has terrible dse.
Using an Aptv 4k box I use to stream DTVN, most things look sharper and more clear than they ever have. Colors look good and not to much overblown. Brightness is good as well. Watching Avengers infinity War looked better than ever, bright highlights popped and were not overcooked, great contrast, the dimming works a bit better than the Q8. Also watching lower quality content the noise reduction capabilities are an improvement.
Also there is 2 different positions you can mount the stands, inwards or farther out. I will measure those later.
ID:	2542154   Click image for larger version
cec68 and badcatsclaws like this.
85Q70R
82Q70R
65Q9FN
Thrust-Bot is offline
post #68 of 1552 Old 03-21-2019, 08:19 AM
moodysj's Avatar
Quoted: 49 Post(s)
Liked: 29
Looks like there will soon be available a Q7D (Q75) model at Costco, Sams, BJs, etc.
Sent from my SM-T817V using Tapatalk
moodysj is offline
post #69 of 1552 Old 03-21-2019, 09:01 AM
jhstl's Avatar
Quoted: 14 Post(s)
How is the viewing angle? I noticed the Q70R is described as "wide viewing angle" whereas the Q80R is listed as "ultrawide viewing angle". Does the Q70R seem any better than your Q8FN that you replaced?
I'm currently debating between the 75" Q80R and the 82" Q70R. I watch a ton of hockey and the DSE from my LG Oled has me itching to replace it.
jhstl is offline
post #70 of 1552 Old 03-21-2019, 12:24 PM
Quoted: 107 Post(s)
Liked: 42
Anyone out there with the 55? Could you run some DSE tests/Grey Uniformity slides?
The only thing holding me back from a purchase was just how terrible Q8FN's DSE was which I'm afraid will continue this year.
Cuthalu likes this.
post #71 of 1552 Old 03-21-2019, 12:41 PM - Thread Starter
dcx4610's Avatar
Quoted: 49 Post(s)
Liked: 53
I have the 55 and I have very little DSE. It almost looks edge lit in that regard with a very even looking backlight. The first thing I did was run that hockey DSE test. Nothing jumped out at me so I was happy with it.
It's always a gamble though. DSE party has to do with the actual construction of the panel and the pressure put on the screen. It's always going to be a bit of a lottery. I lucked out. There's another poster that got the Q70R and also mentioned they have very little if any DSE.
If you are on the fence, I'd buy it somewhere where you could easily return it just in case you have any issues.
dcx4610 is offline
post #72 of 1552 Old 03-21-2019, 02:26 PM
Quoted: 18 Post(s)
Liked: 7
Any of the owners seen movies/ tvshows with subtitles? Last years models had issues. Mostly they brighten the whole picture a bit for a second especially during dark scenes.
bartsmit is offline
post #73 of 1552 Old 03-21-2019, 03:55 PM
Thrust-Bot's Avatar
Quoted: 79 Post(s)
Liked: 90
Viewing angles are as good maybe slightly better than q8fn, about 20 degrees off center and do not notice any degradation in the picture. Minimal DSE still there but improved alot over q8fn.
85Q70R
82Q70R
65Q9FN
post #74 of 1552 Old 03-21-2019, 05:43 PM
Quoted: 107 Post(s)
Liked: 42
I bought a 55. Hopefully it is free of the 25 dark splotches all over the 3 Q8FN's I tried.
Cuthalu likes this.
post #75 of 1552 Old 03-21-2019, 09:44 PM
bbj77's Avatar
Ordered a 75” from Samsung and it gets here the 28th. Anyone have a mount recommendation? I usually get one from Monoprice and call it good.
bbj77 is offline
post #76 of 1552 Old 03-21-2019, 10:05 PM - Thread Starter
dcx4610's Avatar
Quoted: 49 Post(s)
Liked: 53
Briefly had a chance to play with subtitles. No change in brightness when subtitles are displayed. With FALD and local dimming, it shouldn't brighten the entire picture at all as long as your settings are correct.
I wouldn't rush out and buy the TV based on that though. I'd probably wait for someone that uses subtitles all of the time for a better impression but I didn't see any issues.
dcx4610 is offline
post #77 of 1552 Old 03-21-2019, 11:23 PM
Quoted: 18 Post(s)
Liked: 7
Thank you for checking this. Hopefully they fixed it for the 2019 models. It was especially noticable on Netflix. To be a bit more clear here is an example of the q9fn with netflix subtitles in a dark scene:
https://youtu.be/YizqGc8b0OY
bartsmit is offline
post #78 of 1552 Old 03-22-2019, 12:07 AM
Quoted: 107 Post(s)
Liked: 42
That was my biggest beef with all FALD Samsung sets last year. They behaved like edge lit TV's and refused to "locally dim"
I really hope they actually put the FALD to use this time around.
post #79 of 1552 Old 03-22-2019, 09:51 AM
Liked: 0
Thanks DCX4610 for checking that subtitle thing.
I am in Denver, CO and none of my Best Buy's have this 55" Q70R. There website for the stores here say not until the end of the month.
Where are you guys at that have them in your local stores?
JT11 is offline
post #80 of 1552 Old 03-22-2019, 02:44 PM - Thread Starter
dcx4610's Avatar
Quoted: 49 Post(s)
Liked: 53
I didn't notice any of that. I'd probably want to find a dark scene and test it again though. Something like that is mostly going to be affected by the number of dimming zones on your FALD. The more the better. If you only have a few dimming zones, entire portions of the picture are going to light up as looks to be the case in this example.
srkmish likes this.
dcx4610 is offline
post #81 of 1552 Old 03-22-2019, 02:45 PM - Thread Starter
dcx4610's Avatar
Quoted: 49 Post(s)
Liked: 53
I just did Amazon since their return policy is good. They'll even pick it up for free.
dcx4610 is offline
post #82 of 1552 Old 03-22-2019, 02:48 PM
Quoted: 123 Post(s)
Liked: 30
Placed an order for 65 inch. Should be here on Apr 2. So excited
srkmish is offline
post #83 of 1552 Old 03-24-2019, 07:45 PM
Quoted: 101 Post(s)
65”q70 eve here for me. Delivery scheduled 9-1 tommarrow, took off work so home no issues in delivery
post #84 of 1552 Old 03-25-2019, 10:25 AM
Quoted: 101 Post(s)
I just hooked up x1x to new samsung q70, then tv to receiver. Now i get horrible audio delay, but only playing games bitstream dd. If i choose stereo its fine. If i choose optical it is fine. If i bitstream from the youtube or netfix apps its fine. But if i play a game it is way off.
post #85 of 1552 Old 03-25-2019, 11:41 AM
Quoted: 123 Post(s)
Liked: 30
How do you find the picture quality apart from the audio delay issue?
srkmish is offline
post #86 of 1552 Old 03-25-2019, 12:04 PM
Quoted: 101 Post(s)
so far im blown away coming from 2014 samsung. Blacks are way better and much more color. Only played a little xbox and reg cable tv.
srkmish likes this.
post #87 of 1552 Old 03-25-2019, 01:17 PM
dlleno's Avatar
Quoted: 45 Post(s)
this is interesting to me as I contemplate purchase of a 75Q8: what makes the Q70 panel itself have better grey uniformity than the Q8 panel? did you just win the VA lottery, or is there something inherent in the panel itself? the latter seems unlikely but hey maybe their production variability is tighter now...
dlleno is offline
post #88 of 1552 Old 03-25-2019, 02:30 PM
Liked: 2
Just got the 82” as a free replacement to my 82” Q6FN because of the horrible ghosting it had. I ran the motion blur for test on this one and it’s a million times better.
gstrub is offline
post #89 of 1552 Old 03-25-2019, 02:39 PM
Quoted: 123 Post(s)
Liked: 30
Can anyone please tell me the stand width of the 65 inch version?
srkmish is offline
post #90 of 1552 Old 03-26-2019, 07:41 AM
Quoted: 101 Post(s)
Anyway to turn power off to usb port when turning tv off? I have led lights plugged in but have to turn on and off seperately
Reply LCD Flat Panel Displays
