82Q70R vs. 85X850G - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 05-14-2019, 07:59 AM - Thread Starter
Liked: 0
82Q70R vs. 85X850G
Hi guys,
I’m thinking about one of these two sets and want to know your thoughts. They’re both the same price @ €4599,-. I have only seen them in 55”, where the Q70R was playing demo videos and and while the X850G was showing normal content it has a IPS panel in that size. So both not really representative of what the tv’s can really do. Visited many stores and none carry these sizes. I have no idea how the Sony’s contast is, if they’re similar in their color output or if its brightness is similar to the Q70R. Hopefully somebody has seen these irl and can shed some light on it.
I will use the tv mostly for watching 4K blurays, Netflix and for gaming. I rarely watch cable tv. I sit directly in front of the tv @ 4,30m (14.10 feet)
The way I see it right now:
Pro’s of the 82Q70R:
Great native contrast @ 7250:1
FALD tv (boosts contrast to 8056:1)
Gaming features
Its smart platform
Pro’s of the 85X850G
Dolby Vision
3 inches bigger
How Sony usually handles motion and color (so not necessarily a pro of the 85X850G)
Cons of the Q70R:
No Dolby Vision
Cons of the X850G:
No FALD (it’s a Direct LED)
Higher input lag (I assume this)
Ch1mera1989 is offline
post #2 of 15 Old 05-14-2019, 08:45 AM
twinkie57's Avatar
I am in the same boat as you, I am about 15 foot back, but I am looking at the sony 900F or 950G vs the Q90 from samsung.
Interested to hear other peoples opinions as well.
twinkie57 is offline
post #3 of 15 Old 05-14-2019, 12:47 PM
nbarsotti's Avatar
I would go q70r hands down. I’m shopping the 82q70r vs the 85x900f and I can’t make up my mind. I sit 16 feet from my TV so I get that every inch counts, but the q70r just has too many pros. The most important is way better native contrast, plus FALD. Then it gets a faster more intuitive UI, AirPlay 2, FreeSync VRR, plus more native resolutions that don’t need to be forced.
nbarsotti is offline
post #4 of 15 Old 05-14-2019, 01:26 PM
Quoted: 118 Post(s)
Liked: 25
Q70R will be highly superior to X850G, especially for HDR. I have the TV and the black levels and contrast are awesome. Yeah, it could have been a bit more brighter, but to an average viewer, the picture will look outstanding.
Oh and also, the 82Q70R is still at 3499 for Samsung EPP program.
srkmish is offline
post #5 of 15 Old 05-14-2019, 01:40 PM
Quoted: 464 Post(s)
Liked: 1063
From Samsung product, Q90R seems to be impressing most the most. Some even preferring it more than the 8K Q900R.
Q70R is a huge drop-off from Q90R, not in the same ballpark. To answer the OP, I wouldn't consider Q70R or X850G. 2018s Q7FN or X900F would be better considerations.
Panasonic TC65CX850U Yamaha RX-V1079 Technics SU-V650 Panasonic DMP-UB900 Sony UBP-X800 Polk Audio SDA-2B
Panson is offline
post #6 of 15 Old 05-15-2019, 03:55 AM
Quoted: 27 Post(s)
Liked: 1
I just bought the 75 inch Q70 yesterday. Amazing set. I say go for it. It has stellar reviews on this site and rtings.com
https://www.rtings.com/tv/reviews/samsung/q70-q70r-qled
Genomecop is offline
post #7 of 15 Old 05-15-2019, 06:33 AM
BRAC's Avatar
Quoted: 587 Post(s)
Liked: 497
I owned the 85” 900F and now the 82” Q90R. The Q90R is definitely a much better set. Are you in a bright or dark room?
Samsung 82” Q90R * Denon X4500H * 5.2.4 Atmos * Xbox One X * PS4 Pro
BRAC is offline
post #8 of 15 Old 05-15-2019, 08:39 AM - Thread Starter
Liked: 0
Thanks for your reply. I really dislike edge lit tv's and the X900F is not available in 85'' in my country, so these two aren't options.
Thanks for your reply. Have you find any downsides yet?
Thanks for your reply. In what way is it superior with HDR?
B&W 804D3
NAD M17 + NAD M22
post #9 of 15 Old 05-15-2019, 08:51 AM
twinkie57's Avatar
Bright during the day (windows to the left) and then dark at night.
post #10 of 15 Old 05-15-2019, 10:18 AM
BRAC's Avatar
Quoted: 587 Post(s)
Liked: 497
82Q70R vs. 85X850G
The 900F is not too bad for daytime viewing, certainly better than the 950G will be with x-wide angle layer. That being said, the Q90R’s anti-reflection filter is a thing of beauty. I can watch dark content during the day in my very bright room with great results.
BRAC is offline
post #11 of 15 Old 05-15-2019, 03:30 PM
VA_DaveB's Avatar
Quoted: 1363 Post(s)
Liked: 646
The Q70R is superior for HDR because it has FALD. Without local dimming, LCDs like the 850G cannot produce the deep blacks and bright peak highlights required for HDR movies.
VA_DaveB is offline
post #12 of 15 Old 05-15-2019, 04:32 PM
Quoted: 27 Post(s)
Liked: 1
No problem with mine at all...but its been two days. I'm having it calibrated in two weeks. But I love it. I also looked at the 82 inch but It was frankly too big for my space.
post #13 of 15 Old 05-15-2019, 04:36 PM
Dimon.Zorg's Avatar
Quoted: 203 Post(s)
Liked: 81
If you are sensitive to flicker Samsung is not an option. Sony is much better in that regard.
Dimon.Zorg is online now
post #14 of 15 Old 05-16-2019, 02:18 PM - Thread Starter
Liked: 0
Yeah, that's true.
Why do you feel the flicker is bad on the Samsung? Rtings gives the Q70R a 9.9 out of 10 on its flicker as it's flickers at 960hz.
B&W 804D3
NAD M17 + NAD M22
post #15 of 15 Old 05-16-2019, 06:16 PM
Dimon.Zorg's Avatar
Quoted: 203 Post(s)
Liked: 81
I did the same mistake when I bought Q9FN. 960Hz is in Movie mode only. 120Hz in other modes including Game mode. But the most annoying that when you turn Auto Motion Plus on PWM freaquency is 120Hz in ANY mode.
Reply LCD Flat Panel Displays
