Samsung RU 7100 owner's thread - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 55 Old 12-03-2019, 06:43 AM
Quoted: 24 Post(s)
Liked: 3
Originally Posted by PogueSquadron View Post
Hmm, thanks for that. I feel like I do have some more research to do though, since the HDR images on Disney + are quite dark, and I never seemed to have this issue in games. Will definitely have to spend a bit more time with it. Maybe it just needs to be more properly calibrated in HDR mode, as it's currently super dark.
You can try my HDR settings from a few posts earlier and see how that looks. As for the "UHD color" setting to enable HDR from each HDMI input, I think that terminology has changed to "input signal plus", still in the external device manager menu.
brygalt_hdr is offline
post #32 of 55 Old 12-03-2019, 03:36 PM
PogueSquadron's Avatar
Liked: 26
Thanks again. You know, I did fire up Master Chief Collection tonight in anticipation of playing some Halo Reach, and I did see that this game offers some HDR settings that definitely alleviated some of the dim picture I am seeing with Disney+. I was able to get D+ looking better but it's still fairly dim compared to HDR10 disabled. I can definitely tell because even the XBox menu is darker when it switches over. I've tried turning contrast and gamma up, but the whole image still feels a little dark, almost like the backlight isn't maxed out. I'm contemplating just keeping HDR10 off, as I'm not sure if this TV will even show many of the benefits of HDR anyway.
PogueSquadron is offline
post #33 of 55 Old 12-04-2019, 04:19 AM
Quoted: 24 Post(s)
Liked: 3
Can anyone on this thread comment on the most recent firmware update (1290.4). Any observations on color, brightness, or anything else regarding picture quality? Did anything change for the worse, or better?
post #34 of 55 Old 12-04-2019, 04:41 PM
atkirkp's Avatar
Quoted: 14 Post(s)
Liked: 25
You are in the RU 7100 Owner's thread which is on Firmware ver1335.0.
I guessing you have a NU 7100 and are posting in the wrong thread?
atkirkp is offline
post #35 of 55 Old 12-05-2019, 12:29 PM
Liked: 0
Have a Samsung 43" RU7100. Just used the calibration settings at RTINGS......my tv has both 2.2 and BT1886 gamma. Which is the one to use?
gregoryh325 is offline
post #36 of 55 Old 12-05-2019, 04:36 PM
atkirkp's Avatar
Quoted: 14 Post(s)
Liked: 25
Typically 2.2 in Bight/well lit room. BT1886 in an average to dark room.
atkirkp is offline
post #37 of 55 Old 12-06-2019, 09:38 AM
Liked: 0
But do the other calibration settings (from the NRTINGS website) in white balance and color space settings have to be adjusted if switching to BT1886?
post #38 of 55 Old 12-06-2019, 02:56 PM
atkirkp's Avatar
Quoted: 14 Post(s)
Liked: 25
Probably but you should run that question by RTINGS.
This post from Mr Fujisawa I've found to be a simple summary of what benefits of the 2 are.
"I use both, My bright preset is 2.2 and my dark preset is BT1886 (basically 2.4). That way I get to see more shadow detail when its bright in the room and when its nice and dark, I have much punchier shadow detail."
RTINGS used 2.2 with the reasoning that it was closest to their calibration target.
atkirkp is offline
post #39 of 55 Old 12-09-2019, 07:14 AM
Liked: 0
Originally Posted by roland6465 View Post
When you adjust picture settings when an HDR source is fed to the TV and it goes into HDR mode, the settings you adjust are saved to HDR mode. When you switch to an HD source, it will go back to your original settings.
I am trying to adjust HDR settings on this model. I have enabled Input Signal Plus on the HDMI port. Adjusting while purported HDR content is playing from Amazon Prime app. Is there any way to tell when the display has switched to HDR mode?
First post for me. Thanks.
Aggie60 is offline
post #40 of 55 Old 12-09-2019, 10:00 AM
Liked: 0
Hello all,
I bought a couple months ago a Samsung UN43RU7100FXZ in an offer that included a UHD Video Pack CY-SUC05SJ/XS. When tryed to watch the movies in there, the TV do not recognize them, showing like there were no movies in there.
I searched a bit and realized that the *.UM4 files were made for an older samsung TV models to be played, but not by the new ones. So, I complained to Samsung and the store of purchase, but either way I had no solution, they just tell me that I should formatt the HDD to use it like a storage device.
In searching for solutions, I found on AVSFORUM that some guys, in 2014, changed the type of file just by typing mp4 instead of um4. I tryed but it didn´t worked for me.
So now I am trying to find out if after these years a solution was found, or maybe I should just quit and formatt the HDD.
Any info you can share with me? advices?
Thanks...!!!
Mike Mke is offline
post #41 of 55 Old 12-21-2019, 09:10 AM
Liked: 0
I have a 43" RU7100. Was wondering what is the default setting for the "fit to screen" picture setting? On or Off?
post #42 of 55 Old 02-18-2020, 07:22 PM
jamieh1's Avatar
Quoted: 44 Post(s)
Netflix shows in HDR is very dark on this tv
Directv HD
Samsung UN50H6350 50" LED Smart TV
Channel Master 4228 antenna
Greenville NC, Ral-Durham NC ota market
jamieh1 is offline
post #43 of 55 Old 02-25-2020, 12:46 PM
bodean's Avatar
Quoted: 437 Post(s)
Liked: 74
Just got this tv
Those rtings settings the only calibration settings posted on here for the 7100?
Room 1 Samsung Q8FN 75" TV || Denon X2400H Receiver || Triad InWall/4 Satellites || Triad InRoom Silver/4 Satellites || Triad OmniSub 12
Room 2 Sony X900F 65" TV  || Sony HT-X9000F sound bar
Xbox Live : BoDEAN
bodean is offline
post #44 of 55 Old 03-02-2020, 04:52 PM
jamieh1's Avatar
Quoted: 44 Post(s)
how do i get the colors from being over brightened, reds light blues yellows oranges look really bright.
Directv HD
jamieh1 is offline
post #45 of 55 Old 03-03-2020, 06:04 AM
Dom Di Stroia's Avatar
Quoted: 225 Post(s)
Liked: 127
Maybe attenuating the backlight and/or white levels (brightness).
To meet HDR criteria, the manufacturer may have pre-set the backlight to an artificially high level.
A/VR: Sony STR-DE598; front: 2x Polk Audio (1x RTi6 + 1x TSx220B)
subs: 1x JBL PSW-1200 + 1x BIC RtR RtR-12S
rear: 1x Boston Acoustics CS 26 II + 1x Klipsch Reference R-15M
monitor: LG 24EA53V-P (panel: LG Display AH-IPS)
display: Sony BRAVIA KDL-48W600B (panel: S-LCD S-PVA)
Dom Di Stroia is offline
post #46 of 55 Old 03-03-2020, 07:07 AM
jamieh1's Avatar
Quoted: 44 Post(s)
When watching 4K picture looks great. But watching regular HD it’s not at crisp as my previous Samsung led HD tv.
Directv HD
jamieh1 is offline
post #47 of 55 Old 03-03-2020, 07:08 AM
jamieh1's Avatar
Quoted: 44 Post(s)
Colors are bright and over exposed
Directv HD
jamieh1 is offline
post #48 of 55 Old 03-06-2020, 06:04 AM
Quoted: 225 Post(s)
Liked: 127
What do you have the "sharpness" set at?
post #49 of 55 Old 03-06-2020, 06:08 AM
Quoted: 225 Post(s)
Liked: 127
What action(s) have you taken to correct this issue?
post #50 of 55 Old 03-06-2020, 03:28 PM
jamieh1's Avatar
Quoted: 44 Post(s)
im using the Dynamic mode
sharpness is at 12 which is what tv automatically has it set to
ive dropped contrast down to 35 from 50 and color down to 23 from 30
I also went in the service menu and changed the following
pw max to 100
pwm in 2d to 100
pwm movie to 100
pwm mid 100
and pwm min to 0
this takes the auto dimming out, has helped a lot with the very over saturated colors and the auto dimming
Directv HD
jamieh1 is offline
post #51 of 55 Old 03-06-2020, 04:29 PM
Quoted: 225 Post(s)
Liked: 127
pw max to 100
pwm in 2d to 100
pwm movie to 100
pwm mid 100
and pwm min to 0
"Dynamic" mode could be raising artificially the white and backlight levels, and attentuating the black levels (aka "picture" or "contrast") may exacerbate the effective "brightness". You may be better off reverting to "Standard" mode, and re-configuring from there.
And you should be able to disable the "auto dimming" feature with one (or more) of the "Eco Solution" settings.
post #52 of 55 Old 03-06-2020, 05:17 PM
gimpy's Avatar
Quoted: 25 Post(s)
I have a picture problem on my new RU7100 TV. I bought the TV about a week or so before Christmas at Best Buy when my 6 year old Sharp bit the dust. I did not buy an extended warranty.
Anyway, the TV screen sometimes gets "splotchey" (right word?) areas. These areas are in different locations, are different sizes, generally appear in darker scenes and areas. It doesn't appear in every show, so I am not sure if it is something wrong with the TV screen or something else. I watch only Direct TV programming. I do watch blue ray DVD's occasionally, but don't recall if it had these splotches/blotches or not. Someone suggested trying new cables (hdmi). I have not changed new cables, yet.
I took a couple of pictures to post on here, but have not been able to do so. If someone can tell me how, I will try it.
When I first got the TV, I did originally try a couple of different settings, but eventually went back to default with one or two minor changes. I don't know if that has anything to do with it or not. The picture mode I am using is "natural". I'm not sure if I am describing it (splotches or blotches) correctly (I've tried Google searches).
Any one have suggestions I could try before I call Samsung?
Thx.
https://www.avsforum.com/forum/attac...1&d=1583544665
Somehow I finally was able to attach a picture, but it is sideways. What I am trying to show is that dark splotch (pretty big splotch in the corner).
gimpy is offline
post #53 of 55 Old 03-08-2020, 01:38 PM
jamieh1's Avatar
Quoted: 44 Post(s)
Have tv perfect now, no more color saturation and picture is great,
got the service menu PWM settings as follows
pw max 100
pwm ini 2d 100
pwm movie ini 100
pwm mid 5
pwm min 0
Expert settings Dynamic mode
back light 50
brightness -1
contrast 50
sharpness 12
color 22
tint 0
digital clean view Auto
auto motion plus Custom - judder reduction 3- led clear off
contrast enhancer high
color tone cool
Eco Solution
ambient light detection on
minimum back light 20
power saving off
motion lighting on
Directv HD
jamieh1 is offline
post #54 of 55 Old 03-08-2020, 04:48 PM
Quoted: 225 Post(s)
Liked: 127
pw max 100
pwm ini 2d 100
pwm movie ini 100
pwm mid 5
pwm min 0
back light 50
brightness -1
contrast 50
sharpness 12
color 22
tint 0
color tone cool
Eco Solution
power saving off
motion lighting on
Looks good - except for the "motion lighting" feature. It is a form of auto dimming that attenuates the backlight during fast-moving scenes. It's also a feature that Samsung has used to meet (? cheat) energy-efficiency standards:
https://www.pcworld.com/article/2988...ion-tests.html
https://www.forbes.com/sites/johnarc...-energy-tests/
Also: you may find more info regarding the PWM settings here:
https://www.avforums.com/threads/sam...e-fix.2170862/
post #55 of 55 Old 04-22-2020, 02:49 PM
Liked: 0
Hi all,
I have had my RU7100 for about a month now. However, while testing some game consoles hooked up to the unit, I started to notice some strange artifacts that appear similar to screen tearing, but somewhat different.
The specifics:
- The "tearing" is best described as a "region of lag" that is a few frames behind the rest of the image. The image within the region exhibits some discoloration.
- Unlike typical screen tearing, the artifact is not perfectly straight and rectangular across the whole display; it instead follows an irregular pattern that always appears in the same region at the top of the TV. I threw together an example, along with the artifact captured during gameplay, both attached below.
- The screen tearing only seems to affect component video sources, in this case, my original Xbox and my Wii. Both use their respective OEM component cables, securely fastened to the TV.
- The tearing only occurs when the consoles output 480p. Setting them to output interlaced 480i removes the tearing, though this is not ideal as input lag is introduced and image quality takes a hit.
- The effect is not always present. It typically appears for less than a second a few times per minute though it can occasionally last for much longer.
- Game Mode is set to ON on the TV.
I'm not sure if this is a usual flaw of modern televisions. I'm hoping to find out what causes this and if it can be easily fixed, so I thought I'd hop on the forums to hopefully get some input from experts on this TV.
ID:	2714320   Click image for larger version
GD46 is offline
Reply LCD Flat Panel Displays
