Update of current Sony - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-03-2019, 08:04 PM - Thread Starter
49Merc's Avatar
Quoted: 675 Post(s)
Liked: 134
Our Sony 4K XBR55X930E has performed flawlessly. Is there sufficient reason to consider purchase of a newer model? If so what? Everyday use with occasional DVR.
Sony 4K XBR55X930E, Sony 4K UBPX800 Blu-Ray Player, Sony HTST 5000 SoundBar, DirecTV 4K HS17 w/2 Mini Genies, Panamax MR5100 Power Manager, Harmony Elite Remote, Monoprice Cables
49Merc is offline
post #2 of 6 Old 06-04-2019, 06:34 AM
CaptinCrunch's Avatar
Quoted: 337 Post(s)
Liked: 304
Unless your ready for a larger TV 75" , then I see no reason to purchase a new set. The X930E is a great TV!
Sony 75X900F / MediaLight Quad 6500K
Sony X800
Denon X4400H / Outlaw 5000 (5.2.4 Atmos) AIRCOM T9
Klipsch RF-82 II, Klipsch RC-62 II, Klipsch RS-52 II, Klipsch RP-500SA
SVS PB-3000 x2
CaptinCrunch is offline
post #3 of 6 Old 06-04-2019, 06:50 AM
JD23's Avatar
Quoted: 559 Post(s)
Liked: 329
No. I also have an X930E and recently decided to move the X930E to my family room to replace an older plasma, as the X930E is better suited for this room because of its larger size, higher brightness, and burn-in resistance. To replace the X930E, I ordered an A9G (OLED), as I found that there are no LCDs on the market significantly better than the X930E and wanted to try something different. I think you will be disappointed if you replace the X930E with another LCD because the improvement in performance (or potential downgrade) will be far too small to justify the expense.
JD23 is offline
post #4 of 6 Old 06-04-2019, 07:01 AM
enricoclaudio's Avatar
Quoted: 3836 Post(s)
Liked: 4706
I had a X930E that performed really well for 6 months then the screen started flashing. After dealing with Sony CS for about 2 weeks, they sent me a check for the full amount I paid. The set was under warranty. That was on December 2018. Immediately I purchased one of the last 65Z9D from Best Buy. The Z9D is just a bit better than the X930E but the X930E had ZERO DSE. If your X930E is performing well, I would stay put unless you find a Z9D for a reasonable price or go with a Sony A9G OLED.
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik F12SE(x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | Sony 77A9G OLED |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #5 of 6 Old 06-04-2019, 08:22 AM - Thread Starter
49Merc's Avatar
Quoted: 675 Post(s)
Liked: 134
Thank you. We will stay put.
49Merc is offline
post #6 of 6 Old 06-04-2019, 08:37 AM - Thread Starter
49Merc's Avatar
Quoted: 675 Post(s)
Liked: 134
Thank you.
49Merc is offline
Reply LCD Flat Panel Displays
