I have pm turned off
I bought the screen in 2008 for my first projector (Espon 1080UB)
Because it was my very first setup and I had no idea what size to get, aspect ratio
what gain I needed, grey, white, fixed, pull down, acoustically transparent...etc.
I found nothing under $1000 locally so I turned to ebay, and $250 all-in, shipped to my door
sounded like a good temporary screen (instead of a queen size bed sheet) until I figured out what I really wanted/needed.
a few pic's from that initial setup here:
https://www.avsforum.com/forum/19-de...-basement.html
I was told by many here at AVS that the electronics/motor would likely fail,
the edges would curl, the screen would droop and eventually develop waves.
...didn't happen.
It's still as pristine as the day it arrived, the screen material is matt white with a 1.3 gain,
adjustable drop height, came with a wall controller, IR and RF remotes and has never let me down.
A friend spent over $1000 locally for the same material on a fixed screen and on close inspection, it looks no different with his JVC.
I've seen a lot of others in the past decade since and nothing impressed me enough over what I already had to coax me to open my wallet.
I highly doubt I could replace this one for under $1000 if I had to.
I just got lucky I guess, it was supposed to be temporary and disposable and turned into a keeper.
