Samsung Q90R user settings and links. - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By gimpygod
post #1 of 2 Old 07-11-2019, 08:46 PM - Thread Starter
gimpygod's Avatar
Quoted: 37 Post(s)
Liked: 31
I have combed through the Q90R owners thread and compiled the user settings found there for convenience. I am also going to include links to review sites that have published calibration numbers they are using.
Possible Q90R settings
Links to sites with calibration settings:
Ratings.com
Flatpanelshd.com
General tools & tips for calibrating UHD HDR tv
Reset individual input rather than factory refresh:
HDMI AUTO DETECT TOGGLE
The HDMI Auto Detect feature can be turned off using the remote control by pressing a certain key sequence (either IR or Bluetooth remote works).
1. Make sure TV is updated to latest firmware version
2. Switch TV to TV source – HDMI may not work with BT Smart remotes. TV source works with either remote
3. Using IR Remote: Mute + 7 + 2 + 9 + Exit
4. Using Smart Control: Mute + Vol Down + Ch Down + Mute
PLEASE NOTE: TV does not display any messages after you press the above key combination. This function is a toggle. So if you want to turn HDMI Auto Detect on again, press the same key sequence.
After this is done, you should be able to edit the device type regardless of what the device actually is, and the TV will "believe" the new definition. In the past I've used it to label HDMI A output on a Denon AVR as "Blu-Ray Player", and HDMI B output as "Apple TV", instead of having the TV automatically recognize and label both inputs as an AVR.
Early not professional:
I use these settings for HDR and SDR:
Intelligent Mode Settings ............. Off
Eco Solution ............................... Off
Picture Mode .............................. Movie
Digital Clean View ....................... Off
Auto Motion Plus ......................... Off (I'm sensitive to Soap Opera Effect)
Local Dimming ............................ Standard
Contrast Enhancer ....................... Off
Film Mode .................................. Auto2
Color Tone .................................. Warm2
White Balance ............................. Default
Color Space Settings .................... Auto
Natural setting:
Picture Mode Standard
Backlight 22(can be changed to your preference)
Brightness 0
Contrast 36
Sharpness 2(Personal preference, I wouldn't go higher)
Color 22
Tint 0
Digital Clean and Automotion Off
Local Dimming High
Contrast Enhancer Off
Color Tone Warm2
Gamma BT.1886 -1
Color Space Native
Give these a shot on your set. Color space Auto made teal look like blue so I stick to native there. Gamma -1 gives a slightly punchier image and just looks better to my eyes. Cheers
Game mode settings
I've found the perfect medium for game mode(in my opinion of course). Contrast Enhancer High was a bit too bright and Low looked good but wasn't quite bright enough. The perfect setting to my eyes for game mode HDR is contrast enhancer high BUT with overall gamma brought down 1 click to -1. My full game mode HDR settings are below.
Backlight 50
Brightness 0
Contrast 46
Sharpness 2(Personal Preference)
Color 22
Tint 0
Local Dimming Standard
Color Tone Warm2
Gamma ST.2084 -1
Color Space Native
Ambient mode reset
For those who don't use it and would like to disable it, you need an older remote with numbered buttons. Turn the TV off. Press mute+1+8+2+power. May need to do this a couple of times. Once the service menu comes up, select Options, then MRT options, then scroll all the way to the right. Select Ambient Screen Support the use the right directional button to turn off. Power off the TV then back on and it should now be disabled.
Please note that my picture settings were reset after leaving the service menu so you should note what your current settings are.
Slickman’s settings could need adjustments:
SDR
Backlight 23
Brightness 0
Contrast 41
Sharpness 0
Color 23
Tint 0
Local Dimming High
Contrast Enhancer Low
Color Tone Warm2
BT.1886 0
Color Space Native
White Balance
Red Gain 3
Green Gain 0
Blue Gain 5
Red Offset -1
Green Offset -1
Blue Offset 0
SDR Game Mode
Backlight 30
Brightness 0
Contrast 41
Sharpness 0
Color 23
Tint 0
Local Dimming High
Color Tone Warm2
BT.1886 0
Color Space Native
White Balance
Red Gain 3
Green Gain 0
Blue Gain 5
Red Offset -1
Green Offset -1
Blue Offset 0
HDR
Backlight 50
Brightness 0
Contrast 46
Sharpness 0
Color 20
Tint 0
Color Tone Warm2
ST.2084 0
Color Space Native
HDR Game Mode
Backlight 50
Brightness 0
Contrast 46
Sharpness 0
Color 20
Tint 0
Color Tone Warm2
ST.2084 0
Color Space Native
DUTCH REVIEW SETTINGS
S13 tips: For sdr in a bright room I like standard mode. First rest to default settings. Then change contrast to 45, sharpness to 5, color to 20, digital clean view to low (off if it's sdr Blu Ray disc), motion is subjective you gotta tweak around, local dimming high, contrast enhancer off,.color tone warm2 (warm1 if you prefer cooler. Gamma -2 (-1 or zero if you prefer more shadow detail but less vibrancy), color space native. Start with these and tweak to your liking.
Thoth instrument calibration:
Picture Mode Movie
Picture Size 16:9 Standard
Fit to Screen On
Backlight 15 (101.5 nits)
Brightness 0
Contrast 45
Sharpness 0
Color 25
Tint 0
Digital Clean View Off
Auto Motion Plus Off
Color Tone Warm2
White Balance 2pt
R-Gain 5
G-Gain 3
B-Gain -1
R-Offset -2
G-Offset -1
B-Offset 9
White Balance 20pt On
Red Green Blue
5% 0 0 0
10% 1 0 -1
15% 1 0 -3
20% -1 4 -2
25% 2 5 1
30% 3 4 5
35% 4 5 4
40% 5 5 2
45% 0 4 7
50% 0 4 9
55% 0 3 8
60% 0 3 7
65% -1 2 8
70% -1 2 11
75% -2 1 11
80% -1 2 11
85% -1 1 10
90% -1 0 6
95% -1 0 4
100% 0 0 1
Gamma BT.1886
BT.1886 0
Color Space Custom
Red
Red 60
Green 55
Blue 37
Green
Red 58
Green 54
Blue 30
Blue
Red 50
Green 55
Blue 50
Yellow
Red 50
Green 49
Blue 49
Cyan
Red 75
Green 51
Blue 50
Magenta
Red 50
Green 70
Blue 70
Intelligent Mode Off
Game Mode Off
Eco Solution OffThe
rexrode78 likes this.
gimpygod is offline
post #2 of 2 Old 07-12-2019, 02:44 AM
Liked: 5
Thanks for making this thread!
Elavarasan is offline
Reply LCD Flat Panel Displays
