Best 32 inch TV? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Wiz4rd
  • 1 Post By Dave in Green
post #1 of 5 Old 08-08-2019, 02:52 AM - Thread Starter
Liked: 2
Best 32 inch TV?
I am looking for a 32 inch flat panel tv for my rv, and am curious what you all think out there has the best picture quality. Not concerned with sound, nor smart features, just an excellent picture. Thoughts? Oh and we sit about 6 feet from it if that helps, I may be able to squeeze a 37 inch in there, not sure.
hot_dots likes this.
Wiz4rd is offline
post #2 of 5 Old 08-08-2019, 04:21 PM
Dave in Green's Avatar
Quoted: 3895 Post(s)
Liked: 3069
The smallest 4K TVs are 40" and can be bought for <$250, so only a few bucks more than the best 1080p 32" TVs. Typical dimensions for a 40" 4K TV are ~36" wide by ~24" high. If you can possibly find a way to squeeze one into your limited space you would really appreciate the added performance for minimal extra cost
Dave in Green is online now
post #3 of 5 Old 08-08-2019, 11:22 PM
Quoted: 25 Post(s)
Liked: 5
I'd be interested in peoples response to this as well. I need a 32 (can't fit a 40) at a holiday house with no internet, so smart features and apps are redundant. Just want something with a good picture that is reliable without having to pay for all the bells and whistles.
hot_dots is offline
post #4 of 5 Old 08-09-2019, 08:47 AM
Liked: 3069
If space only allows a 32" TV I'd just go with one of the top models on rtings.com. Each model has a different balance of pros and cons to suit differ personal preferences and viewing environments. Note in reading the ratings that even if you don't need smart features the smart models tend to produce better overall images than those without smart features. There are even 720p models mentioned if 1080p resolution isn't that important to you.
rtings.com/tv/reviews/best/by-size/32-inch
post #5 of 5 Old 08-09-2019, 10:34 AM
Quoted: 879 Post(s)
Liked: 2091
Toshiba 720p 32", about $130 at Best Buy. Bought one a couple of years ago for my m-i-l. Nice pic. Good luck. Have fun.
Panasonic TC65CX850U Yamaha RX-V1079 Technics SU-V650 Panasonic DMP-UB900 Sony UBP-X800 Polk Audio SDA-2B
"I watch a lot of movies, I know what I'm doing." - Daniel Lugo
Panson is offline
Reply LCD Flat Panel Displays
