Sitting about 10 feet away.
Mainly watching movies and TV series.
I’m all for “the bigger the better”.
Biting myself trying to decide between the 75X950G and the 85X950G.
I know that based on the TV-distance-charts, 85 should be OK for that distance but when I visualize the 85 in my living room, it scares me.
I don’t want to buy the 75 and regret not going bigger.
I don’t want to buy the 85 and find out it isn't practical.
Is there any chance the 85 would feel too big?
No....I do not believe it will feel too big. Went from 65 to 80, initially afraid the same thing....would never go smaller. The number 1 regret is not going larger!
^honestly I don't think their are many sets larger than 85 that aren't astronomically priced...I think you would be in projector territory there...I mean as long as you can manage a TV that size without interrupting your space you should be good to go.
I sit 7 feet from a 135" screen. 10 feet from 85" may not even be close enough to tell the difference between 4K resolution and 1080p resolution. It's definitely not too big. At 4K you need to be very close to see the differences. At minimum I'd try to be within 1 width of the screen.
I'm not concern about telling the difference.
I'm concern about the large field of view. I afraid I will constantly need t move my head/eyes around (like a tennis match )
From what I experienced, "as big as it gets" is great for movies, but I also use my TV as main computer monitor, which I wouldn't like any bigger.
I'm sitting about 5' from my 55" TV and when I reduced that to 4', I felt it was too big for regular computer duty.
Maybe sitting 5' from a 65" TV is better than sitting 4' from a 55" TV, even thou it's the same apparent size. I can't tell
Should be a good distance for immersion. I'd have the same concerns about eye fatigue but all calculators have it in the acceptable range. I personally view this as you do and would go watch an 85 an 75 from that distance at a shop for a few minutes each to make certain.
I sit 9' - 10’ from my 75” 900E (they did not have the 85” yet). It felt really big going from 60” to 75”. After a few months I wished I had a 85”. I plan on upgrading as soon as I can justify spending the money so soon. Only problem is the only place I can use my 75” after I replace it with an 85” is in the bedroom (have a built-in in the family room and 75” is too big).
Re field of view, when I did my calculations for my room at 10' a 75” would give you 30.5 degrees and 85” 34.3 degrees (37.9 degrees at 9' and 85"). The reference field of view width from SMTPE is 43.3 degrees and 20th Century Fox is slightly closer at 45 degrees so you should be fine and not have to move your head at all.
Not at all, the THX calculator for viewing distance: https://myhometheater.homestead.com/viewingdistancecalculator.html
It makes sure you can take in the entire scene without having to move your head, some people like a slightly larger viewing angle (40 degrees) for more immersion but your 10 feet is spot on, not too close. I'm 8 feet away and am tempted to go 85" just because I can I can always move the chairs back 2 feet, right?
That's an interesting calculator. I've been wanting a bigger screen for my media room, where we sit 8 feet from a 75-inch display that I still love. According to the calculator, that's the right size and distance.
In our living room downstairs, where we watch most of our programming, we sit 12 feet away from a 65-inch display. The calculator says we should have a 100-inch screen at that distance. Maybe I've been looking at this backwards and should get something bigger downstairs.
TL;DR
If it was possible/available, I would have even gone larger to 95 or 105.
I’ve been using this TV for a week now.
After the initial 60-second-shock from its sheer size, it feels really natural in my living room.
First, the TV, as an electronic rectangle device mounted on the wall, looks very neat. It almost complete the surrounding furniture. So natural, that some guests don’t even notice I got a new TV at first glance.
The TV itself is spectacular in all contents. But I already knew that in advance after investing many hours reviewing it in the stores.
The size feels natural and as the time passes on, I’m certain I could have accommodated a larger set.
So, to validate the arguments you kind people have made – you were right. Buying the 75 would have definitely made me regretful. Had a 95 set been available, I might have even been regretful buying my 85.
I’m extremely happy with this purchase. Wish my TV a long and meaningful life.
I have pondered if this makes a difference for gamers, is there a point of diminishing returns where the screen is big enough to see all the little details (a far away target etc), but then gets too big where you are at a disadvantage because your eyes, or where they are focused at least, have to move a bigger distance to look from one side of the screen to the other? Like trying to watch two targets at opposite sides of the screen, that would both be in your primary vision on a 65" might be in your peripheral vision on an 85", at close enough distances?
You're already at a big disadvantage in a multiplayer game unless you're playing on a monitor while getting getting 240fps+ the whole time. The bigger the screen and less fps, The worse you will be.. 24-27 inch monitors is the sweet spot for this... Anything smaller than 24 is too small, anything over 27, is too big.. There is no limit to size for single player, unless you want to play fps games on a high difficulty level, but a 65 inch is way too big too.. You should only be playing on a 24-27 inch monitor while getting 240fps+ if you want to be the best at a game.....You get it yet pimpin??
An 85" at 10ft is fine if it is a 4k set. It will be borderline or ok if 1080p.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
