VIZIO XVT553SV No Signal - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old Yesterday, 06:14 PM - Thread Starter
jiteshg's Avatar
Exclamation VIZIO XVT553SV No Signal
Hello, I bought the VIZIO XVT553SV in 2011. Now it is showing no signal but there is sound. There is no signal through the receiver or the side HDMI. I have already tried the soft reset and hard reset path but no luck.
Please advice if there is any solution to this problem. Wondering if it is worth getting it fixed or should I just go ahead a buy a new TV.
Thank you!
jiteshg is offline
Reply LCD Flat Panel Displays
