Looking for a 43' - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-04-2019, 11:36 AM - Thread Starter
ArieS1204's Avatar
Quoted: 60 Post(s)
Liked: 24
Looking for a 43'
Hello all,
I'm looking to buy a 43' for my bedroom.
Right now I'm thinking TCL unless you would recommend something better.
But if I was to go the TCL road... There's the 43S423 at Costco which gives me 90 days to return it if I don't like it and it gives me an extra year of warranty.
And there's the 43S525 at Amazon but only 30 days and 1 year of warranty.
It's also a bit more expensive.
I'm not gaming so it will only be used for Netflix, Prime and the likes.
Is there a big improvement in the PQ or HDR between the 4 Series and the 5 Series to justify going with the latter?
Thanks in advance for any input I can get
ArieS1204 is offline
post #2 of 3 Old 11-05-2019, 12:36 AM - Thread Starter
ArieS1204's Avatar
Quoted: 60 Post(s)
Liked: 24
Hmm, no one?
post #3 of 3 Old 11-07-2019, 08:34 PM
Placid666's Avatar
Quoted: 28 Post(s)
Hi,
Look at
https://www.rtings.com/tv/reviews/be.../40-42-43-inch
They have a ton of info.
I ended up getting the LG UM7300 43in on sale.
I plan to use it for a pc monitor more than TV.
If I was more into using it for Movies/TV I would have got the Vizio M437-g0
Placid666 is offline
Reply LCD Flat Panel Displays
