TV w/built-in GOOD OTA tuner? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By DrDon
  • 1 Post By Jawaburger
  • 1 Post By sjm817
post #1 of 13 Old 11-09-2019, 08:55 AM - Thread Starter
Intheswamp's Avatar
Quoted: 130 Post(s)
Liked: 55
I'm looking for an inexpensive ~40" television that has a good, sensitive built-in OTA tuner. Currently I'm leaning toward's either a low-end 43" LG or Samsung.
Anybody using one for mostly OTA that will share their experience with me?
Ed
Intheswamp, but on a hill...
www.BeeWeather.com
Intheswamp is offline
post #2 of 13 Old 11-09-2019, 09:10 AM
Ratman's Avatar
Quoted: 2445 Post(s)
Liked: 2283
Essentially... they're all good.
Mostly... it depends where you live and the terrain, distance, direction(s), antenna, mounting, etc.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #3 of 13 Old 11-09-2019, 09:43 AM
Super Moderator
DrDon's Avatar
Quoted: 2341 Post(s)
Liked: 4467
Moving to Displays. HDTV Technical is largely broadcasters. I would imagine most of the people there are familiar with only what they own, not various makes and models.
Doc
Ratman likes this.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #4 of 13 Old 11-09-2019, 09:56 AM
Jawaburger's Avatar
Quoted: 214 Post(s)
Liked: 210
More important than the tuner is the quality of your antenna and your antenna location. The antenna and location will affect tuning in your stations significantly more than the tuner in the TV.
DrDon likes this.
Sharp LC-80LE844U | Marantz BD8002 | Marantz AV8003 | Marsh Sound Design A400s (FL/FR) | Marantz MM7055 (C/SL/SR) | Phase Tech PC 9.1 (FL/FR) | Phase Tech PC 3.1 (C/SL/SR) | Dual PSA S1811 Subs
Jawaburger is offline
post #5 of 13 Old 11-09-2019, 02:59 PM
jjeff's Avatar
Quoted: 888 Post(s)
Liked: 341
There may be differences but I just don't know. Back in the day when CECBs were available the Zenith or Insignia clone definitely had a better more sensitive tuner than all the others and would routinely get channels the others didn't. The Channel Master CECB was a close second and actually had slightly better multipath rejection. As Zenith or Channel Master doesn't really make TVs anymore I'm not sure what to suggest. Samsung and LG do make nice TVs along with probably the more expensive Sony so I guess you're on the right track.
jjeff is offline
post #6 of 13 Old 11-10-2019, 08:20 AM
Javelin's Avatar
Quoted: 100 Post(s)
Liked: 83
I have a cheap TCL that does very well with OTA signals. With an SD card you can even pause the live feed!
Javelin is offline
post #7 of 13 Old 11-10-2019, 08:28 AM - Thread Starter
Intheswamp's Avatar
Quoted: 130 Post(s)
Liked: 55
Thanks for the responses regarding antennas. And thank you, Doc, for moving the thread to a more appropriate forum.
I understand the need for a good antenna system. When I was actively operating my HAM radio station my passion was building wire antennas and verticals.
I talked to a guy in Slovenia one day (CW) using a section of chicken house waterpipe for a vertical antenna.<grin> I was no antenna genius, but I had fun tinkering with them. I primarily worked QRP, reduced power (usually 1.5 watts, less than a CB radio) and had people tell me I was lying when I told them that was my power level...of course I was pushing that 1.5 watts through a full-wave wire loop supported by a big pecan tree. Antennas make a big difference!
Currently, here at the house, I'm employing an Antennas Direct DB8e, an Antennacraft 4-bay bowtie, and a VHF-Kit. These are all combined and feeding into a Juice amplifier. I live between 20-50 miles from the stations and have rolling, forested land between me and the transmitters. I think multi-path interference is one of my biggest foes. My Frankintenna is what I had to do to pull in the major OTA networks and it has worked well, though since the repack I may need to tweak it a bit (get more height on it). We're using a Tivo Roamio OTA for the receiver (four different internal tuners) which is sending signals to our old Panny plasma pro panel and to a Tivo Mini feeding a small LG television in the kitchen.
The television that I'm looking to buy will be going to a different location, though, but only about 200' from our house. Currently, there is an old 32" CRT at that location being fed by a large VHF/UHF directional antenna with some type of mast-top preamp (RCA maybe, it's been a while since I installed it). The antenna signal is fed into a "Digital Stream" set-top box, converted to analog and sent to the CRT. The flat panel will go in a different room there.
Besides the Digital Stream STB, I've got a Samsung that was our primary OTA tuner before dumping DISH (H260F, I think it is) and an iView box that I used for a while in a shop. Out of these three boxes the Samsung is the strongest tuner. It's been a while since I've tinkered with them, though. We've had the Roamio OTA up and running for two years now after dumping DISH and the boxes have mostly been sitting idle in their boxes. Chipsets, filters, quality of integration among other things all come into play with radio signal reception.
I've got no argument about needing a good antenna system. But, from my own experience, I believe that there has been differences in tuner sensitivities. The sad thing is that you can get two identical-looking tuners/tvs and their reception strength can be very different. Maybe things have evolved enough that the built-in tuners are an after-thought for manufacturers being as many displays no longer have them. Maybe they're all putting in a similar generic tuner card...I dunno. I was hoping to find a brand/model that users have had mostly good OTA experiences with...moving the odds closer to getting a decent tuner. I've looked at online reviews but few of them mention OTA reception, but rather concentrate on "Smart TV" aspects along with comments on number of HDMI ports, audio ports, etc., or simply the picture quality.
The little LG tv in our kitchen also has a direct antenna connection and it pulls in more stations than the Tivo does, so I'm happy with that LG tuner. And, the Samsung STB proved to be good along with a Samsung plasma I had in the past. With this past experience I think I'll continue on the LG/Samsung path.
www.BeeWeather.com
post #8 of 13 Old 11-10-2019, 10:08 AM
sjm817's Avatar
Quoted: 819 Post(s)
Liked: 335
TCL/Roku TVs have a good tuner and a good guide. They also allow you to use a USB stick for pausing live TV which is a nice bonus.
ncsercs likes this.
sjm817 is offline
post #9 of 13 Old 11-11-2019, 01:03 PM - Thread Starter
Intheswamp's Avatar
Quoted: 130 Post(s)
Liked: 55
Thanks for the votes for the TCL. I'll have to take a look at'em!
www.BeeWeather.com
post #10 of 13 Old 11-12-2019, 07:13 AM
Javelin's Avatar
Quoted: 100 Post(s)
Liked: 83
Just make sure you look at the 6 series. It's hard to beat in that price range!
Javelin is offline
post #11 of 13 Old 11-12-2019, 08:28 AM - Thread Starter
Intheswamp's Avatar
Quoted: 130 Post(s)
Liked: 55
Looks like the 6 series would be their top of the line, at the moment. Thanks for the heads'up.
www.BeeWeather.com
post #12 of 13 Old 11-13-2019, 02:51 PM
Red MC's Avatar
Quoted: 310 Post(s)
Liked: 245
I suspect tuner performance is becoming an afterthought to TV manufacturers. They don't have to touch RF themselves anymore. They just need to pick from one of the available tuner and demodulator on-a-chip offerings, and they are probably going to choose the one that is cheapest and/or easiest for them to integrate. After all, most cord cutters I know don't even bother trying to get OTA broadcasts. And a lot of those who do switched to using networked tuners.
If you live in a house where most/every room is wired for CATV, then I suppose it makes sense to put a distribution amp where the coax runs all come together, and connect the antenna feed there. But in my case, I only had two rooms with coax, so buying an HDHomeRun and distributing OTA TV broadcasts as MPEG2 streams over Ethernet & wifi made things a lot easier and more flexible. Plus it makes OTA broadcasts available to watch on computers, tablets, and phones. I think this is the way most people are going to go in the future.
HT: Dynaudio C2, Contour S CX, 2x BM14S, Aperion surrounds, Simaudio Titan, Marantz AV8801, Oppo 103, Linn Majik DS, and a Pioneer Kuro
Stereo: Dynaudio Focus 160, Simaudio W-5 LE or Luxman M-600A, Linn Akurate DSM, 2x Rythmik F12G
Other interests: motorcycling, skiing, being active
Red MC is offline
post #13 of 13 Old 11-16-2019, 09:08 AM
Keizer's Avatar
Quoted: 56 Post(s)
Liked: 58
Another vote for the TCL Roku TV's. I love mine. The free TV guide is awesome and looks very nice. Can't believe people actually pay a monthly fee just so they can have a guide. And yes the tuner in the TCL brand TV's are very good.
Keizer is online now
Reply LCD Flat Panel Displays
