Worth the upgrade for HDR? - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 1 Post By Tree Dude
  • 2 Post By samovies10
  • 1 Post By VA_DaveB
  • 1 Post By lucacow
  • 1 Post By Trixxstrr
post #1 of 8 Old 11-12-2019, 08:01 PM - Thread Starter
Trixxstrr's Avatar
I currently have a 2015 Vizio M series 70" which has 4K but no HDR.
I'm considering buying a 2018 Samsung NU8000 75".
Would the upgrade be worth it to get HDR?
Is it worth worrying about Samsung not supporting Dolby Vision?
I have some 4K blu-rays that I'll be playing through my Xbox One X, as well as gaming at 4K.
I see from reviews it's a decent tv, and has a nice sale which puts it at what I want to spend.
But it has some bad local dimming I see on a review, but not sure if that's enough to say I should stick with my Vizio?
I'm not looking to jump in price, so it's purely a matter of sticking with my Vizio, or upgrading to this?
Trixxstrr is offline
post #2 of 8 Old 11-13-2019, 12:11 PM
Tree Dude's Avatar
Quoted: 36 Post(s)
IMO Dolby Vision is the best reason to upgrade. HDR is ok, but the movies I have in DV have the best color out of all of them. DV is a better standard and I would wait till you can get a TV that supports it.
DrBrFrJr likes this.
TCL 55P605
XBL & Steam: Atomic TreeDude
Tree Dude is offline
post #3 of 8 Old 11-13-2019, 01:35 PM
samovies10's Avatar
Quoted: 82 Post(s)
Liked: 50
You'd be better off buying a TCL 8 Series 65", or a TCL 6 Series 75" from last year. Both will perform better than that Samsung and both also have Dolby Vision. The 8 Series has considerably better local dimming (and the most dimming zones at that size) but the one on the 6 Series is not bad at all (and still definitely better than that Samsung's; even the 65" 6 Series will give you better quality). Both are also around the same price or cheaper than that Samsung.
lucacow and DrBrFrJr like this.
Setup:
Display: ISF Pro Calibrated LG OLED65C7P TV 7.1.4 Sound: Denon AVR-X4400H, Sony Stereo (amp), Klipsch: RP-440C, RP-250F x 2, RP-150M x 4, RP-140SA x 4, R-10SW 4K Disc Players: Oppo UDP-203 (Region Free & Dolby Vision), Panasonic DP-UB820 Streaming Player: Apple TV 4K Video-Game Consoles: Xbox One X & PS4 Remotes: Logitech Harmony Elite Remote Control with Hub and iPad App
samovies10 is offline
post #4 of 8 Old 11-13-2019, 02:19 PM
VA_DaveB's Avatar
Quoted: 1509 Post(s)
Liked: 746
The NU8000 is edge lit with poor local dimming, so IMO that isn't worth it for HDR. What kind of 4K blu-ray movies will you be watching? A lot of HDR is used for special effects on those costumed super hero movies. So if you like those, get a mid to high range FALD VA panel TV. For 4K gaming, Samsung's VRR support might be important so a Q70R might work.
Since you don't give a price, it's hard to understand "I'm not looking to jump in price". Jump in price from what? If you're meaning the 75" NU8000, I saw it listed for $2K, and the 75" Samsung Q70R and 75" Sony 900F are the same price and are much better FALD VA panel TVs.
Panson likes this.
VA_DaveB is online now
post #5 of 8 Old 11-13-2019, 03:01 PM - Thread Starter
Trixxstrr's Avatar
Ok thanks all. I definitely won't get a Samsung. It was priced at $1800 CAD btw - https://www.2001audiovideo.com/en/ca...ung-UN75NU8000
I'll consider the Sony 900F next year maybe or if there is a big sale. It's at $2800 CAD - https://www.amazon.ca/gp/product/B07...09GVH0DE1DX1BN
That TCL 6 series I guess is this one, for $1700 CAD - https://www.amazon.ca/TCL-75R617-CA-...ronics&sr=1-13
But I also have a stand issue, where alot of the tvs where the feet go right to the edge I can't quite fit on my stand, so also looking for one with the feet set either middle or slightly in.
post #6 of 8 Old 11-13-2019, 06:13 PM
lucacow's Avatar
Quoted: 56 Post(s)
Liked: 41
I’d pull the trigger on the TCL and get a universal stand for it. They can be found on amazon for about $25.
samovies10 likes this.
lucacow is online now
post #7 of 8 Old 11-13-2019, 06:16 PM
samovies10's Avatar
Quoted: 82 Post(s)
Liked: 50
I'd still recommend that TCL model.
You can easily overcome the wide feet issue by getting a VESA type stand like this one:
https://www.amazon.ca/PERLESMITH-Uni...xpY2s9dHJ1ZQ==
Or this one:
https://www.amazon.ca/VIVO-Universal...tronics&sr=1-6
Setup:
post #8 of 8 Old 11-13-2019, 07:05 PM - Thread Starter
Trixxstrr's Avatar
Oh wow thanks I actually never knew stands like that existed, never even considered I could get another stand. That opens so many options to me! Thanks so much!
Reply LCD Flat Panel Displays
