TCL 8 Series Roku TV (2019 Model - 65" & 75") *Owner's Thread*(No Price Talk) - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 72Likes
post #91 of 129 Old 11-29-2019, 11:48 AM
Antarius's Avatar
Quoted: 163 Post(s)
Liked: 87
Originally Posted by js950 View Post
There's no reason these can't be fixed with software but the bigger question is whether that will be the case. The lower fald setting should do exactly as you describe, rtings noticed there was increased SW based dynamic contrast as you select higher FALD settings which will increase black crush. Maybe an owner can ignore their recommendation and use one of the lower 2 settings and respond.
Low and medium settings are bad. Black bars are gray in all modes except for high. Rtings review is correct here.
Antarius is offline
post #92 of 129 Old 11-29-2019, 11:51 AM
Antarius's Avatar
Quoted: 163 Post(s)
Liked: 87
Originally Posted by DanielOKeeffe View Post
Daniel from RTINGS here.
We tested the TV last week on the latest firmware at the time (9.1.2 build 6463-88). As of today, the TV has updated to a newer firmware (9.1.2 build 6471-88). The interpolation to 120Hz is currently working correctly, and we'll be updating the review shortly. At the moment we suspect this was just a firmware bug, but we don't know.
My TV updated to 6471 a week ago. Interesting that you had such delay receiving this update.
Antarius is offline
post #93 of 129 Old 11-29-2019, 11:53 AM
Dave in Green's Avatar
Quoted: 3881 Post(s)
Liked: 3066
Thanks for trying to clarify. Interpolation aside, the question has been whether or not the TCL 8 Series has native 120Hz panels. A TCL source told @imagic that they were native 120Hz. You seem to be saying they have interpolation to 120Hz but are native 60Hz. A definitive clarification of native refresh rate would help settle the confusion.
Dave in Green is offline
post #94 of 129 Old 11-29-2019, 11:59 AM
js950's Avatar
Quoted: 451 Post(s)
Liked: 318
Native contrast without any local dimming is 6650 and it will be better with any amount of LD. Here's a no local dimming pic. That's a very dark gray.
I also think this was rushed to Market and will get better with updates and hopefully better LD options in the future. Doesn't count until they do it and they better at this price.
js950 is offline
post #95 of 129 Old 11-29-2019, 12:03 PM
PlanetAVS's Avatar
Quoted: 2173 Post(s)
Liked: 2002
Look forward to your updates. Digital Trends did not mention the black crush in their review (Nov 6th) and I believe that is the single biggest issue that owners and potential owners are concerned with. Could you let us know if the newest firmware improves the black crush? Also some owners mentioned that they only have the black crush on native apps, and external sources are fine. Can you comment on this as well?
Thanks for your great work
PlanetAVS is online now
post #96 of 129 Old 11-29-2019, 12:04 PM
js950's Avatar
Quoted: 451 Post(s)
Liked: 318
I think that's what he's saying. That the FW wasn't allowing the panel to do its thing.
js950 is offline
post #97 of 129 Old 11-29-2019, 12:22 PM
Quoted: 153 Post(s)
Liked: 369
Sorry I wasn't clear - we test the native refresh rate of TVs by getting the panel to display the highest frame rate possible without any frame skipping (and then use a high speed camera to determine the frame rate). To display this high frame rate, there are usually two options:
  • Send a high refresh rate signal (eg. 120Hz). On this TCL, a 120Hz signal experiences frame skipping (only 60Hz is displayed). This is the same before and after the firmware update.
  • Send a lower refresh rate signal (eg. 60Hz) and then apply motion interpolation on the TV to interpolate the output up to the panel's native refresh rate. When we tested this last week (on firmware 6463-88), this consistently went up to a 60Hz maximum. With the latest firmware (6471-88), we are able to interpolate up to 120Hz.
Let me know if you've got any more questions.
We don't know why this is - it might be that it varies between units. We experienced black crush both through native apps and via HDMI, including with the latest firmware. We also re-tested the pre-calibration this morning and found it to be the same (very high gamma, resulting in crushed dark scenes).
DanielOKeeffe is offline
post #98 of 129 Old 11-29-2019, 02:14 PM
Antarius's Avatar
Quoted: 163 Post(s)
Liked: 87
I assume you are referring to some photos I posted before. I used it to demonstrate how broken some apps were especially youtube app. Black crush is there in all modes even after latest update. But fortunately it is fixable by adjusting white balance.
Antarius is offline
post #99 of 129 Old 11-29-2019, 02:30 PM
PlanetAVS's Avatar
Liked: 2002
So you're saying that the black crush problem is only out of the box and can be resolved via adjusting the settings?
Have you tried the Rtngs recommended settings by chance?
Sent from my SM-A205U using Tapatalk
post #100 of 129 Old 11-29-2019, 02:58 PM
Liked: 3066
Let me know if you've got any more questions. ...
Got it. The key point here is that the TCL 8 Series does have native 120Hz panels just as the TCL rep correctly stated to @imagic .
DanielOKeeffe likes this.
post #101 of 129 Old 11-29-2019, 03:09 PM
Antarius's Avatar
Quoted: 163 Post(s)
Liked: 87
Rtings settings will only work on their set. I did my own adjustments.
Out of the box gamma was average ~2.5 with bigger drops in 5%-10% to ~2.9. TCL's poor attempt to reach OLED level blacks may be? I adjusted it down to 2.2. That was immediate improvement in PQ and fixed shadow details. Aggressive dimming is not fixable this way though.
I say their calibration app is useless, because all it does is shows a white screen and you take pictures of it 12 times. I saw numbers change in 60%+, nothing was changed in 5%-50% where that black crush is.
I still don't understand how same settings affect both SDR and HDR10/DV.
It is unacceptable to have such poor accuracy out of the box in my opinion.
js950 likes this.
Antarius is offline
post #102 of 129 Old 11-30-2019, 08:43 PM
JTH182's Avatar
Quoted: 54 Post(s)
Liked: 32
So for a 24p Blu-ray the TV will do 5:5 up to 120hz, but the max signal it can display is 60hz? I guess for now there aren't too many 120hz signals, but that hurts (no pun intended) for the future.
JTH182 is online now
post #103 of 129 Old 12-01-2019, 05:41 PM
Antarius's Avatar
Quoted: 163 Post(s)
Liked: 87
Interesting find, TV accepts dolby truehd with atmos bitstreamed from nvidia shield.
Antarius is offline
post #104 of 129 Old 12-02-2019, 10:17 AM
Stuntman_Mike's Avatar
Quoted: 804 Post(s)
Liked: 638
So you're saying that this is a Native 120hz display, that can't display a signal from a 120hz source, properly? Is that correct?
Stuntman_Mike is offline
post #105 of 129 Old 12-02-2019, 11:14 AM
acefr's Avatar
Quoted: 585 Post(s)
Liked: 532
This is interesting. Is it really Dolby TrueHD or Dolby Digital+ with Atmos? Does it downmix it to stereo to output to TV speakers? Thanks.
acefr is offline
post #106 of 129 Old 12-02-2019, 12:28 PM
Antarius's Avatar
Quoted: 163 Post(s)
Liked: 87
Direct play straight to TV and Dolby Atmos badge shows up.
Antarius is offline
post #107 of 129 Old 12-02-2019, 04:30 PM
PlanetAVS's Avatar
Liked: 2002
You're referring to a ripped True HD file played through the Plex Shield app correct? Does it pass through to a soundbar/AVR as True HD as well?
post #108 of 129 Old 12-02-2019, 04:42 PM
Antarius's Avatar
Quoted: 163 Post(s)
Liked: 87
Yes.
I am using TV speakers. I have no plans to add soundbar to this TV.
Antarius is offline
post #109 of 129 Old 12-02-2019, 05:14 PM
PlanetAVS's Avatar
Liked: 2002
Yes.
Gotcha. On further thought it wouldn't output True HD to a soundbar/AVR anyway, since the TV doesn't support eARC.
post #110 of 129 Old 12-03-2019, 01:02 PM
gardennj's Avatar
Liked: 5
I think somewhere in the RTings review he mentions that the SDR & HDR brightness are set together by TCL. Vincent from HDTV Test mentioned this as well. It's mentioned as a noteworthy shortcoming and Vincent's review didn't leave the impression that it's easily fixable. I think that's what I recall.
It's one of the reasons I'm holding off for now on the R & Q series. Some tweaks after the first generation are definitely needed.
gardennj is offline
post #111 of 129 Old 12-03-2019, 01:53 PM
duvy56's Avatar
Quoted: 32 Post(s)
Can we expect a price drop anytime soon on the 8 series?
$2000 & $3000 is a lot of scratch.
duvy56 is offline
post #112 of 129 Old 12-04-2019, 02:58 AM
JTH182's Avatar
Quoted: 54 Post(s)
Liked: 32
Not soon enough. I went to my local Best Buy yesterday, and they had a 65" 8 series hidden away on a side wall playing the same crappy Best Buy feed as other lower tier TVs. Not exactly the presentation I'd expect from an exclusive sales deal.
post #113 of 129 Old 12-04-2019, 08:23 AM
duvy56's Avatar
Quoted: 32 Post(s)
My BB does the same thing, very disappointing they did that.
It really makes no sense to have an exclusive release and then shove it in the corner. I asked for the remote and they said they didn't have one. I know that's BS.
duvy56 is offline
post #114 of 129 Old 12-04-2019, 10:36 AM
wxman's Avatar
Quoted: 5539 Post(s)
Liked: 3939
wxman is online now
post #115 of 129 Old 12-04-2019, 11:31 AM
Rolls-Royce's Avatar
Quoted: 1207 Post(s)
Liked: 1283
Do keep in mind that "exclusive" doesn't always mean "preferred". Manufacturers can and do pay for preferred display treatment on endcaps, in display rooms, etc.
PlanetAVS likes this.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #116 of 129 Old 12-04-2019, 01:08 PM
12B4A's Avatar
Quoted: 641 Post(s)
Liked: 554
Haven't been in to see if they have the 8 but BB has always crapped on TCL at my store. They had the 6 series mounted 10 feet off the ground on the back wall and that was the only TCL TV on display.
Life is Lambertian
12B4A is offline
post #117 of 129 Old 12-04-2019, 07:51 PM
Reality Bites's Avatar
Liked: 0
Went to my BB to see the 8 Series and was told they won't be putting it on display at all because they didn't want to take sales away from the higher margin Samsung's and Sony's. I'm not even thinking of buying a $2k set without seeing it 1st! If I were TCL I'd be all over them and/or cancel the exclusive deal!
Reality Bites is offline
post #118 of 129 Old 12-04-2019, 07:58 PM
wxman's Avatar
Liked: 3939
I wouldn't be surprised if Samsung came up with that idea for BB, and Samsung gave them a bigger percentage of sales. BB tells TCL they want to be the exclusive seller. TCL falls for it. BB puts them in a back corner, nobody buys them, and Samsung kills off mini-led, and their only real challenge in the LCD TV market.
wxman is online now
post #119 of 129 Old 12-05-2019, 07:07 AM
Liked: 1283
Simply venting here probably won't do any good. Try writing or calling TCL directly. Tell them exactly what you saw and were told.
...Royce...
post #120 of 129 Old 12-05-2019, 07:19 PM
gardennj's Avatar
Liked: 5
Agreed, but posted items from forums like this always seem to end up in the right place. As to BBY if you’re buying there, simply ask them to connect one or leave. Sure other makers are trying to buy up the end caps and preferred space, but $2-3k from any seller adds up if people aren’t buying them. BBY has a sales problem so they’re eventually have to accept that what they do isn’t working at peak.
Not expecting big or regular discounts on these high end models except possibly to move a few units in Feb.
gardennj is offline
Reply LCD Flat Panel Displays
