Going Crazy - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #31 of 53 Old 11-21-2019, 11:03 AM
Stuntman_Mike's Avatar
Quoted: 899 Post(s)
Liked: 737
Originally Posted by Cwbcss View Post
An 85 is definitely too big, 65-75 is the sweet spot. Regarding the OLED good info on the sports ticker not causing any issues and my news channel of choice is usually Fox, so not sure if that has as great or equal an impact as the CNN logo
Check what color the Fox logo is (white?). If it's not Red or Yellow, and even if it is, if it's transparent, it will likely not be an issue.
Stuntman_Mike is offline
post #32 of 53 Old 11-21-2019, 11:09 AM
Audioguy1's Avatar
Quoted: 64 Post(s)
Liked: 54
Originally Posted by Darren Chan View Post
Blasphemy!...Unless your viewing distance is under 8 feet.
Sounds like you've been told Cw.
Why not just get a bigger house. You could always knock a wall or two down.
Joking aside the burn in issues keep me away from oled's. I'm particularly susceptible to motion blur, so I'd go the 950 route; but that's me. I don't look for it, it finds me. 950 is a marginal improvement over the 900, so if it's worth the extra quid to you, go for it.
85, you know you want it. Just sayin'
Cheers
lucacow likes this.
Audioguy1 is offline
post #33 of 53 Old 11-21-2019, 11:53 AM - Thread Starter
Quoted: 22 Post(s)
Liked: 4
You guys are killing me lol.... this is why I’m going crazy. So OLED could be a possibility since I don’t think I watch anything with static red logo. And because motion is important to me I think that mean the 950 over the Samsung Q90R. And sadly I have to say the 85 is too big for the finished basement. Go ahead and mock 😉
Cwbcss is offline
post #34 of 53 Old 11-21-2019, 01:13 PM
Darren Chan's Avatar
Quoted: 116 Post(s)
Liked: 34
So 77" OLED? That is a gorgeous panel! 🤤
Marantz SR7013, Polk Signature S60s/S30/S15s/HTS12s, Polk MC80 (x4), AC Infinity T9/S9, AAB4 HTPC, Panasonic DP-UB420K...still to come - 82"-85" 4K QLED or eqv.
Darren Chan is offline
post #35 of 53 Old 11-26-2019, 07:27 PM - Thread Starter
Quoted: 22 Post(s)
Liked: 4
So after pondering all your suggestions I’m debating the 75inch Sony 950......... or just going for the LG C9 OLED but only in the 65 inch, the 77 inch is too expensive
Matt2026 likes this.
Cwbcss is offline
post #36 of 53 Old 11-26-2019, 08:01 PM
ray0414's Avatar
Quoted: 12883 Post(s)
Liked: 12256
Originally Posted by picturequality View Post
Here we go again you should try and give accurate statements when trying to help someone. Saying the 950g has limitations with HDR is not true it has the most accurate colors out of the box when you compare it to Samsung or other lcd tvs. And for people who dont understand FLAD its not the amount of dimming zones its the algorithms, you can have a tv with 100 dimming zones and another with 50 zones and the 50 count looks better.
LOL if number of zones don't matter then why has no Sony full array tv come even a fraction close to the dimming performance of the Z9D that had 650 zones on the 65" and 800 on the 75"? Sonys 100 zone tvs are terrible. And no, wide angle tech doesnt cause blooming, so guess again.
Dimming zones don't matter... Yet the 42" Dolby Pulsar has 6000 zones in order to control the brightness.
Sure, 50 zones might not make or Break a TV. But 500 zone difference definitely can.
82Q90R*75Q9FN(RIP)*55C8OLED*Galaxy Note10+*Ub820 fed into Oppo 203*XB1X*4k DenonX4200
MASTER LIST OF HDR CONTENT THREAD HERE, UPDATED OFTEN
ray0414 is offline
post #37 of 53 Old 11-26-2019, 08:13 PM - Thread Starter
Quoted: 22 Post(s)
Liked: 4
So are you suggesting the Sony 75 inch is not worth consideration and I should just go for the smaller 65 inch LG ?
Cwbcss is offline
post #38 of 53 Old 11-26-2019, 08:36 PM
ray0414's Avatar
Liked: 12256
Based on prices of all 3,and what you're coming from... I'd go with the Sony 950g and save the money over the Q90 if what you care about most is sports.
ray0414 is offline
post #39 of 53 Old 11-26-2019, 09:19 PM - Thread Starter
Quoted: 22 Post(s)
Liked: 4
They 75 inch Sony 950 is $2500 at Best Buy and the 65 LG OLED is $2100. And while I do watch a lot of cable sports I also enjoy movies.
Thanks for the info
Cwbcss is offline
post #40 of 53 Old 11-27-2019, 05:28 AM
Quoted: 153 Post(s)
Liked: 84
If what you are saying was true then ask yourself why is Samsung, Sony and LG not increasing the dimming zones every year instead they are focusing on fine tuning the algorithms.
picturequality is offline
post #41 of 53 Old 11-27-2019, 07:56 AM
getbigg21's Avatar
Quoted: 132 Post(s)
Thanks for the info
I don't think you could go wrong with either tv. I like the Sony 950 for the larger screen and b/c it gets brighter. Since you are in a basement that really would matter there. I come from a Plasma tv so it's hard for me to go with an LED. I like the idea of them, but I always find something "wrong" with them lol. I think at this point you will be fine "burn-in" wise on an OLED. If it were 4-5 years ago I would say it may be a problem. I'm still rocking a Panansonic 65 inch VT30 plasma and I just really like that great picture that I get from it. When I purchase a house next year I will probably go to an OLED b/c of it.
getbigg21 is online now
post #42 of 53 Old 11-27-2019, 10:53 AM - Thread Starter
Quoted: 22 Post(s)
Liked: 4
Did you mean that a bright screen WOULD OR WOULDNT matter in the basement?
Cwbcss is offline
post #43 of 53 Old 11-27-2019, 11:02 AM - Thread Starter
Quoted: 22 Post(s)
Liked: 4
Sorry one last question, if I was to skip the OLED 65 and go LCD in a 75 does the Sony in your opinion beat out a 75 inch Samsung q80 and/or the Q90
Cwbcss is offline
post #44 of 53 Old 11-27-2019, 12:50 PM
getbigg21's Avatar
Quoted: 132 Post(s)
the bright screen wouldn't matter in the basement b/c you do not have a lot of light coming in. My living room currently has a lot of light that comes in through the windows.
post #45 of 53 Old 11-27-2019, 12:53 PM
getbigg21's Avatar
Quoted: 132 Post(s)
that i'm not sure. I had the Q80 for awhile in a 65 inch but returned it. It was a good tv, but at the $2k price that it was I didn't think it was worth it. My goal right now is to milk the plasma that i have for another year and then jump to an OLED. I have been tempted already b/c of the prices that I have seen, but my wife keeps telling me to wait.
post #46 of 53 Old 11-27-2019, 01:21 PM
Audioguy1's Avatar
Quoted: 64 Post(s)
Liked: 54
Sounds like my first wife what's her name...oh yeah, plaintiff.
Cheers
post #47 of 53 Old 11-27-2019, 01:25 PM
Audioguy1's Avatar
Quoted: 64 Post(s)
Liked: 54
Beauty is in the eye of the beholder, they both have strengths. As for me, I vote for the Sony.
So easy spending other people's money.
Best
post #48 of 53 Old 11-27-2019, 07:11 PM
lucacow's Avatar
Quoted: 78 Post(s)
Liked: 53
Going Crazy
I love Sony, and I love my 940E. And the 950, Q9, and C9 are great sets. However, have you looked at the 75” Vizio PQX? At the current price it is worth considering.
That would be the only other set that would be worth taking a look at.
lucacow is offline
post #49 of 53 Old 11-27-2019, 07:48 PM
electronleaker's Avatar
I'm in a similar situation. Coming from a 70" 1080 Sharp, I picked up a 65" Sony A8G OLED. Quickly I realized the size drop was a bad choice. So I've been reading these forums daily trying to figure out a better choice.
I ordered a 85" 950G but ended up cancelling the order because it would take over a month to deliver it. Also, with the blacks I'm seeing on this A8G, I won't be able to deal with the blooming. I do love the Sony's for everything else they bring to the table though.
I was looking at the 77" C9 but having an OLED in my house now has shown me they are absolute mirrors. I have a single lamp to the left of my screen about 7 feet away. I see reflections in dark areas of the screen from the wall behind my seating position, that wall behind me is a good 25 feet back. So I find myself looking at dark areas thinking there's something there to see only to find it's a wall or picture frame.
Now, I think I've decided on the 82" Q90. It's got one of the best anti reflecting screens and really good blacks with little to no blooming. It's flaw however is that its brightness can get overly high watching HDR content. I think I can live with turning down the backlight a notch or two if needed.
It's a hard choice for sure. Everything has its flaw(s). I really wanted to love OLED but the reflections are truly that bad. I wish sony would have done better with the 950G. Looks like Samsung wins in this round.
electronleaker is offline
post #50 of 53 Old 11-27-2019, 08:48 PM - Thread Starter
Quoted: 22 Post(s)
Liked: 4
I did look at that set, a rep from the store said I would regret going from my current Sony 900 to Vizio
Cwbcss is offline
post #51 of 53 Old 11-27-2019, 08:52 PM - Thread Starter
Quoted: 22 Post(s)
Liked: 4
Heard some mixed reviews about motion/sports on the Q90 but other then that it seems to get good reviews, but since I’m trying to go bigger then my 65 the 75 in the Q90 is a little too much for me. That would push me to with staying at 65 for the Q90 or go down to a75 Q80.
I keep going around and around lol
Cwbcss is offline
post #52 of 53 Old 11-27-2019, 08:59 PM
I don't watch sports really. Maybe a couple games a year so I can't attest to that on any set. I will say that the forum sponsors here have incredible prices and impeccable reputations for customer service. My A8G OLED will be going back to BB once I order its replacement from one of them. Chris at Cleveland Plasma has been very good to deal with.
post #53 of 53 Old 11-28-2019, 01:42 PM
Quoted: 76 Post(s)
Just get the Q80R. For your viewing you wouldn't notice any difference from the Q90R.
lucacow likes this.
cb86 is offline
Reply LCD Flat Panel Displays
