Acer Predator CG437KP Reviews - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 56 Old 12-04-2019, 02:54 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 4
This looks like it's the only monitor that checks all of the boxes (well, almost all - no HDMI 2.1). I can't find any reviews online so I thought I would start here. Anybody own this? Anybody have any thoughts on the specs? $1500 seems a little on the cheap end. I would use this monitor exclusively for gaming (Xbox One X, PS4 Pro, Switch and PC). Thank you!
DanielPlainv1ew is offline
post #2 of 56 Old 12-04-2019, 03:25 PM
Rolls-Royce's Avatar
Quoted: 1290 Post(s)
Liked: 1370
This really should be in the HTPC/Gaming area, as this section is primarily for Home Theater LCD displays. Mods??
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
post #3 of 56 Old 12-05-2019, 01:09 AM
Liked: 0
Smile
I ordered the CG437KP on Monday and it should be delivered today. After the disappointing ASUS XG438q, i hope this will be the right monitor for me
Shelby78 is offline
post #4 of 56 Old 12-05-2019, 01:33 PM
Liked: 0
The monitor is here. Made some pictures of the box. Had to turn it open upside down to get the covered monitor outside - not very good to handle like it is mentioned on the pictures at the box. The CG437K comes with many cables. 2x displayport, 1x USB-C to USB-C, 1x USB-toPC, 2x Powercords (1xUK / 1xEU), 4x LED-Stripes (2x short / 2x long), 4x LED-Connectcable, a quick-guide and warranty-papers. And a very handy remote (but with no battery... for this price.. yeah, cool..). With the remote i can easy adjust the monitor settings. No fumbling with the little joystick - but also with that, the settings are made quickly and easy. I demounted the foot and put it on the wall - there are VESA mounting holes (last picture).
I run it with a i7 8700K, 32GB RAM and GTX 1080 TI via one displayport cable at 120 Hz. Turned HDR on, which let me then only adjust the brightness. And this monitor shines like the sun - i set it for now at 42 brightness and super sharpness off. HDR fixes the other settings (contrast at 50 / black boost at 5 / blue light off / ACM off / Light Sensor off).
Text looks at scaling 125-150% very sharp. Tested till now only GTA V - had to turn some graphic settings lower. I´ve seen no issues i´ve had with the Asus XG438Q (smearing in dark scenes).
Colors looking good for me. Not oversaturated and pretty natural. But i am not a graphic designer..
Will test more games and movies.
But yeah, could be the monitor i´ve been waiting for Will use it for movies and for PC and PS4 gaming.
ID:	2649888   Click image for larger version
ID:	2649890   Click image for larger version
ID:	2649892   Click image for larger version
ID:	2649896   Click image for larger version
ID:	2649902   Click image for larger version
Shelby78 is offline
post #5 of 56 Old 12-05-2019, 02:42 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 4
Thank you so much for the info and please keep me posted as you continue trying it out with other content. Does it feel pretty responsive?
Shelby78 likes this.
post #6 of 56 Old 12-05-2019, 03:21 PM
Liked: 0
Yes, it feels very responsive. Tested also PUBG at 4K. Fps at 80-90 with my graphic settings. In turning movement or sidesteps, i see for example at buildings with buttress some stair flutter (dunno how to call this in english). With v-sync on the graphics are smoother.
But i can´t change the monitor overdrive settings. It´s greyed out and i cannot change it. Turned also HDR off and other settings, but i never can change overdrive. It is fixed on normal. Must be a way to touch that - and then for sure the stair flutter will change. Maybe i contact the Acer support.
Shelby78 is offline
post #7 of 56 Old 12-06-2019, 07:38 AM
Liked: 0
Overdrive is automatically set to Normal if Adaptive Sync is On. So, no change possible if someone will use Adaptive Sync. Thats bad, cause thats one thing which was possible with the Asus XG438Q - but which helps not at all.
So maybe Freesync or Adaptive Sync is the problem, which causes that Acer could not let users change Overdrive? Will ask Acer.
Cause GTA V looks pretty good and i didnt recognize any issues like the stair flickering on some objects in PUBG (maybe its just PUBG itself, which performs not so well), i will keep the monitor for now. Of course will do furthermore testing in my usual daily usage.
Shelby78 is offline
post #8 of 56 Old 12-06-2019, 09:09 AM - Thread Starter
Quoted: 21 Post(s)
Liked: 4
Do you own a Xbox One X? I'm curious to see how 4k 60hz compares to 120hz 1080p on this monitor.
post #9 of 56 Old 12-06-2019, 02:23 PM
improwise's Avatar
Quoted: 34 Post(s)
Liked: 24
Mine should be here tomorrow, especially interested in how it will handle text at 100% as I intend to use it for productivity as well. BGR has me a bit worried, if it can't handle text well it will most likely go back...
improwise is offline
post #10 of 56 Old 12-06-2019, 02:34 PM
Quoted: 75 Post(s)
Liked: 61
Have you tried G-Sync or Freesync?
NTTD is offline
post #11 of 56 Old 12-06-2019, 02:40 PM
Liked: 0
Yes, but it's in the living room connected to my tv. I haven't played much with it. Maybe I can try it out.
Shelby78 is offline
post #12 of 56 Old 12-06-2019, 02:45 PM
Liked: 0
For me at 100% it looks a little bit less sharper. But so much better than on the Asus BGR display.
In some software or websites the text looks sharp, and at some others it looks greyish and less sharp.
It depends on the text which is used in the software you use for your work.
Shelby78 is offline
post #13 of 56 Old 12-06-2019, 02:47 PM
improwise's Avatar
Quoted: 34 Post(s)
Liked: 24
Thats worrying, especially considering that 43" makes text a bit blocky regardless. Have you tried switching Windows (assuming you use that) to BGR mode?
post #14 of 56 Old 12-06-2019, 02:47 PM
Liked: 0
The monitor runs only adaptive sync.
Shelby78 is offline
post #15 of 56 Old 12-06-2019, 02:54 PM
Liked: 0
I can try it out on Sunday. Then I will be back home. But why should I switch it to BGR?
Shelby78 is offline
post #16 of 56 Old 12-06-2019, 03:03 PM
improwise's Avatar
Quoted: 34 Post(s)
Liked: 24
It has FreeSync and is GSync compatible.
post #17 of 56 Old 12-06-2019, 03:13 PM
Quoted: 75 Post(s)
Liked: 61
You said V-sync made the graphics better.
FreeSync and G-Sync ARE adaptive sync.
While V-sync is not adaptive.
Correct this monitor is listed as compatible with both.
NTTD is offline
post #18 of 56 Old 12-06-2019, 03:19 PM
Liked: 0
Sorry, that's what I mean. Adaptive Sync is so to say the advanced FreeSync. And it works with Nvidia graphic cards.
Shelby78 is offline
post #19 of 56 Old 12-06-2019, 03:24 PM
Liked: 0
Misunderstanding. I mean, I set V-sync On in the graphic settings of the game PUBG.
Shelby78 is offline
post #20 of 56 Old 12-06-2019, 03:38 PM
Quoted: 75 Post(s)
Liked: 61
That's what I figured you meant.
Since you had mentioned that, I wondered if you tested Freesync or G-Sync performance.
It's my understanding that you want to turn off V-sync when using adaptive sync.
NTTD is offline
post #21 of 56 Old 12-07-2019, 02:44 AM
Liked: 0
Yeah, but I changed a lot in the graphic settings of the game and sometimes it can help to turn on V-sync.
Shelby78 is offline
post #22 of 56 Old 12-07-2019, 10:47 AM
RedHarlow's Avatar
Looks like I have found my PS5 monitor.
Can you run a dimming zone test video to verify the amount of dimming zones??
Still waiting for CES2020 neverless.
I would also appreciate a front picture. Dankeschön.😉
RedHarlow is offline
post #23 of 56 Old 12-08-2019, 11:40 AM
Liked: 0
@RedHarlow : I think i can do that have to find a software or how i can run the test.
Front picture follows! Bitte schön
Shelby78 is offline
post #24 of 56 Old 12-08-2019, 11:56 AM
Liked: 0
And surprise, the monitor has a BGR subpixel layout. I was wrong, cause the text looked so much better. Made a macro photo with my Huawei P30.
Also made two screenshots at 125% scaling. First with Windows ClearType activated. Second with Windows ClearType deactivated.
Did they improved the display or software so much? With the regular Windows settings it looks pretty good at 125% scaling.
And at least a screenshot with 100% scaling ClearType on and off.
ID:	2651066   Click image for larger version
ID:	2651068   Click image for larger version
ID:	2651070   Click image for larger version
ID:	2651072   Click image for larger version
Shelby78 is offline
post #25 of 56 Old 12-08-2019, 12:02 PM
RedHarlow's Avatar
@ Shelby
Here is a video for the dimming zones.
post #26 of 56 Old 12-08-2019, 12:54 PM
Liked: 0
Originally Posted by RedHarlow View Post
@ Shelby
Thanks, i also found one from rtings. But i can´t make a useable video to show how it performs. The picture gets always to bright and there is no detail. But i can say, there is very much less glow around the white dots.
How much dimming zones does he have? I can´t find any infos.
Shelby78 is offline
post #27 of 56 Old 12-09-2019, 07:06 AM
kallek's Avatar
Quoted: 14 Post(s)
How does it work with 4k 144 hz? Do you need to use 2 displayport cables or does it use one cable with compression? If it uses two cables, does it work with HDR and gsync?
kallek is offline
post #28 of 56 Old 12-09-2019, 11:50 AM
Liked: 0
Yes, for 4K with 144 Hz you need two displayport cables. Also you have to change the monitor settings to get the overclocked 144 Hz (System -> 4K-144Hz Mode: On).
In that case the manual says:
DP1 + DP2: AMD Gfx card can support max Timing resolution (3840x2160-144Hz), Not Support (AdaptiveSync & HDR).
I also attached the manual for you all.
Shelby78 is offline
post #29 of 56 Old 12-09-2019, 12:10 PM
Liked: 0
As ordered ;-) That suits?
Shelby78 is offline
post #30 of 56 Old 12-09-2019, 12:22 PM
Liked: 0
@shelby Thanks for info, i just registered on forum to thank You
I want to buy it but im not sure. Could You say more about it?
1. What's the blacks?
2. Is there a ghosting?
3. What about motion blur?
Anno Nymus is offline
Reply LCD Flat Panel Displays
