LG 49SM8600 Protective Film or ? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By artseattle
post #1 of 9 Old 02-11-2020, 12:30 PM - Thread Starter
artseattle's Avatar
Quoted: 17 Post(s)
I just set up a LG 49SM8600PUA for someone. I removed some protective film on the side but didn't find anything on the front. However, when I looked closely, I saw a very smooth, perfectly adhered with no bubbles, film on the screen. At the very edge of the corner, I can see that it is stuck on since there is a tiny gap between the film and the edge. I cannot remove it and when I tried to dig at it on the corner it didn't seem like it should be removed. When I went back to the store, they had a 65 inch which actually has a completely different bezel frame. It did not have a film but it also did not have a raised edge like the 49 inch.
Does someone have a 49 inch 8600 that they can check? If you look very closely at the upper corner can you see that a film is applied over the screen? I'm thinking that it is some type of anti-reflection film. I'm curious because I don't want the film to be a problem in the future.
Art in Seattle
artseattle is offline
post #2 of 9 Old 02-14-2020, 10:32 AM
Liked: 0
I may be swinging by a BestBuy tonite where they have one on display, plus possibly an 'open-box' - that was there this mon nite last, if it's still there. But will definitely be @ BB by tomorrow, and will check. Btw, in mid-west now, but from Seattle ;-)
Ilga is offline
post #3 of 9 Old 02-14-2020, 10:41 AM - Thread Starter
artseattle's Avatar
Quoted: 17 Post(s)
Thank you in advance! The BB in Seattle had the 65inch but the bezel design was clearly different from the 49. There was no film on the 65. The film on the 49 looks like a professionally applied screen protector like the ones that were put on our phones by people at booths in the malls. Remember those days?
Art
Ilga likes this.
Art in Seattle
post #4 of 9 Old 02-17-2020, 11:13 AM
Liked: 0
Yes I do remember ! But I remember my bumbling attempted screen protector applications even more.
So sorry about nothing to report, as we never did make it over to BB. After Fri thought we'd go Sat, then Sun, but no joy.
Hoping to finally make it there this afternoon. If I do I'll take a look-see.
That seems odd that your 49 'looks like a professionally applied screen protector' or 'protective film' is applied to it. Did you ask BB sales people about it?
"I said I just dropped in, to see what condition my condition was in." ~ The Dude
Ilga is offline
post #5 of 9 Old 02-17-2020, 11:26 AM - Thread Starter
artseattle's Avatar
Quoted: 17 Post(s)
Yes, BB told me to peel it off. LG via phone said to keep it on. Neither seemed to be referencing the 49 inch. The 49 inch has a raised bezel with the screen inset. The other sizes have a smoother transition from bezel to screen. Thanks again!
Art in Seattle
post #6 of 9 Old 02-17-2020, 11:33 AM
Liked: 0
I'll look for that. Our local BB has the 49 on display.
Ilga is offline
post #7 of 9 Old 02-17-2020, 04:04 PM
Liked: 0
Does someone have a 49 inch 8600 that they can check? If you look very closely at the upper corner can you see that a film is applied over the screen? I'm thinking that it is some type of anti-reflection film. I'm curious because I don't want the film to be a problem in the future. Thanks!
Looked at the 49SM8600PUA, although I couldn't look very closely as the display was up high, so I didn't/couldn't see the protective or (anti-glare?) film, but talked to a couple BB salesmen and they both said it's a protective film that's supposed to be permanent and NOT peeled off.
Ilga is offline
post #8 of 9 Old 02-17-2020, 04:09 PM - Thread Starter
artseattle's Avatar
Quoted: 17 Post(s)
Thanks! I'm going with that answer. I set this TV up for my sister and she's very happy with it, I'll check it periodically to make sure that the film doesn't bubble.
Thanks again for the effort and info! Art
Art in Seattle
post #9 of 9 Old Yesterday, 07:34 AM
Liked: 0
Glad to have helped.
Ilga is offline
Reply LCD Flat Panel Displays
