Elements ELCFQ324N USB Port Wont read San Disc SD Card - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-19-2020, 06:35 PM - Thread Starter
Liked: 0
Sorry if this is wrong subtopic, long, long time since I posted.
Have a very old elements tv model ELCFQ324N 32 inch television.
My USB device that plugs into my lap top and trying to use for my television is
Plugable SuperSpeed USB 3.0 Flash Memory Card Reader for Windows, Mac, Linux, and Certain Android Systems - Supports SD, SDHC, SDXC, Micro SD T-Flash, MS, MS Pro Duo, MMC, and More
with San Disc 32 or 16gb
Bottom line I'm trying to purchase something that will allow me to put my SD card into an HDMI port on the back of my television.
Sorry if not formatted properly.
thanks
[email protected] is offline
post #2 of 3 Old 06-19-2020, 06:40 PM - Thread Starter
Liked: 0
Cannot edit my first post after submitting. No USB device or card can be read on this television, the amount space used on card is there, the titles are there but nothing on the other side of the menu to click and play. Just had an eight year old television and it worked find with same equipment, seems Elements UBS port only plays music or shows jpegs so I want something to get HDMI to play the contents on the card.
thanks again. if anyone wants to combine messages, no problem. Sorry.
post #3 of 3 Old 06-29-2020, 06:38 AM
Super Moderator
DrDon's Avatar
Quoted: 2561 Post(s)
Liked: 5019
Moved to displays. You'd have to dig through the manual, but a lot of TVs won't support a card reader such as that. Others are limited as to the filetypes they support and the disc format(FAT, NTFS, etc). Maybe someone in Displays knows.
Doc
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
Reply LCD Flat Panel Displays
