Master thread for Panasonic plasma not turning on - Page 88 - AVS Forum | Home Theater Discussions And Reviews
 17Likes
post #2611 of 2624 Old 06-10-2019, 02:09 PM
purbeast's Avatar
Quoted: 26 Post(s)
Liked: 27
So my son tossed a bouncy ball at our ST50, not hard, and the TV turned off. Now it won't turn back on. If I hold the power button down a bit then let go, I hear the "click" of turning on, then like 3 seconds later I hear the click again and it's off.
Same thing happens if I unplug it and plug it back in.
Any ideas?
EDIT:
After some more investigation, I realized I had a piece of tape over the red power light on the front, and the tv is actually turning on, and I can see the light respond to remote commands. However, there is no pictures or anything. The light blinks 7 times and then stops. Then it keeps doing that over and over, but it does respond to remote like you can see the light blink when I press volume, etc.
purbeast is offline
post #2612 of 2624 Old 08-14-2019, 04:07 PM
MajorSkeptic's Avatar
Quoted: 12 Post(s)
Originally Posted by MajorSkeptic View Post
Just thought I'd post another update:
Three years now running without the bad capacitor. See my previous posts on this thread. I had done the freeze test, uncovering the bad *very tiny* capacitor, then just heated it up with a low power soldering iron while simultaneously pulling on it with a small "pick" tool until it popped off. Never installed the replacement capacitor, although I *did* buy it. Just didn't think I could solder it in without bridging the contact points.
Haven't had any issues since, and TV is used a LOT!! TV is now 8.5 years old.
FIVE YEARS RUNNING now, and no problems with the plasma running *without* the bad *very tiny* capacitor. So I had just removed the one bad capacitor on the fingernail-sized board, and the other "twin" fingernail-sized board continues to run with the original capacitor still there ... without any problems. I thought by now I would've had to open it up again and remove the same *very tiny* capacitor on the 2nd fingernail-sized board...
MajorSkeptic is offline
post #2613 of 2624 Old 08-15-2019, 03:39 AM
Quoted: 12 Post(s)
John,
Post #2481 : how’s your Panasonic plasma after taking out that capacitor (3 years ago)? Is it still running? Mine’s going on 5 years now without the MC201 capacitor, and the unit is approaching 10 years old total.
But I ran my 27” CRT JVC from Jan 1995 to 2015 every day ... so that’s 20 years ($450 new). This Panasonic plasma was $1200 new and only 10 years now. But at least it’s still working!
post #2614 of 2624 Old 08-15-2019, 03:52 AM
Quoted: 12 Post(s)
Looks like this thread has petered out! The last couple of years (2017 and 2018) far fewer posts. People must’ve given up on these plasmas?
post #2615 of 2624 Old 08-23-2019, 11:37 PM
TAdams's Avatar
Quoted: 28 Post(s)
Liked: 27
Got two blinking reds on my 65VT60. Clicks to turn on, then shuts off and two blinkers.
"I love the smell of racing gas in the morning."
www.timadamsphotography.com
TAdams is offline
post #2616 of 2624 Old 08-24-2019, 03:20 AM
whipit's Avatar
Quoted: 128 Post(s)
Liked: 97
According to the ST 50 series troubleshooting guide it's missing the P15V from the P board. It's either not being generated by the P board or the A board made the wrong diagnostic. They say the P is the #1 suspect and the A is the #2 . The P board is the power supply right in the middle and the A board is the one with the jacks.
whipit is offline
post #2617 of 2624 Old 08-24-2019, 08:29 AM
TAdams's Avatar
Quoted: 28 Post(s)
Liked: 27
I think it's time to replace. I know the fix can be cheap, but I think I'm going to replace it.
TAdams is offline
post #2618 of 2624 Old 08-24-2019, 05:53 PM
Quoted: 467 Post(s)
Liked: 228
One of the very few VT60's I've seen being a blinker. Model has been very reliable. Make sure it goes to a good home because I agree. Most likely P-board which is good because it's not that expensive. A-Board is the most costly.
Test Ickles is online now
post #2619 of 2624 Old 08-24-2019, 09:39 PM
TAdams's Avatar
Quoted: 28 Post(s)
Liked: 27
It's available to anyone in the Chicago area who wants to come and get it. Not shipping it anywhere.
TAdams is offline
post #2620 of 2624 Old 08-25-2019, 11:46 AM
Liked: 0
hi,
hope it's fine i post here.
got TH-P58v10M.
3 weeks ago it sounded a nice pop explosion and died, giving 7 blink code.
looking in it, some transistors exploded on the SC board.
ordered & installed replacement SC + SU + SD boards.
turned on the t.v it worked for 30 seconds and turned off, giving the 6 blink code.
disconnected the SS board and turned it on, t.v stays on, green led, black screen.
does replacing SS board will do it ? or it can be the A board or P board as well?
thank you in advance for any insight.
shai u is offline
post #2621 of 2624 Old 08-25-2019, 11:51 AM
FlyOnTheWall's Avatar
Quoted: 155 Post(s)
Liked: 35
Still rocking my 65vt60 since day 1.
I did replace a board about 5 years ago (13 blinks of death IIRC) but still running strong.
FlyOnTheWall is offline
post #2622 of 2624 Old 09-15-2019, 10:48 PM
morellihugo's Avatar
Quoted: 27 Post(s)
Hi guys, I need some help... my ZT60 was working perfectly this morning, when I finished watching I turn it off as usual. Later when I tried to turn it on again I hear the relay noise (click) as usual but the tv doesn’t turn on and the red light is blinking, 2 red flashing every a few seconds. Any idea what could be the issue?
Thank you!
HT: JVC RS2000 - Panasonic UB900 - SVS PB2000 Sub’s - HD Fury integral 2 - Apple TV 4K - Yamaha YSP-5600. TV Room: Panasonic ZT60\65" - Panasonic BDT500 - Roku Ultra.
Vinyl Listening Room & Stereo System: Technics SE-R1 Stereo Power Amplifier - Technics SB-R1 Ref. Series Speakers - Technics SU-R1 Network Audio Control Player - Technics SL-1200-G TT - Luxman EQ-500 Phono Stage - Phono cartridges: Hana MH/Denon DL-103 & 103R MC - Audio Desk Vinyl Cleaner Pro.
morellihugo is online now
post #2623 of 2624 Old 09-30-2019, 09:50 PM
Imagoing's Avatar
My first post in a great while!
I found a great 2012 TC-P55VT50 in our electronic recycling place and brought it home.
It has the 7 blinks of death.
I think I've isolated the problem to the SC board, but was hoping someone has a link to this particular models troubleshooting guide. I've found similar guides, but want to be sure I've followed the proper procedures before I start buying replacement boards.
Can anyone assist?
Imagoing is offline
post #2624 of 2624 Old Today, 09:52 AM
Liked: 0
Hoping people still paying attention to this thread...
I have a Panasonic TC-P65VT50. It has worked like a champ for just shy of 7 years. A few days ago it started doing something that appears to be pretty unique, at least unique in the few forums I’ve found on-line. Admittedly, I haven’t read all 88 pages of this topic, but I’ve perused quite a bit of it.
When I turn the TV on, it works. If it gets past the 3 to 10 minute mark, it’ll work for as long as I want to watch. However, more often than not, in that 3 to 10 minute timeframe, the screen will suddenly display what can best be described as colorized white noise, and the sound goes out. It will stay in that mode for 30-60 seconds, then one of three things will happen. It will shut itself off. Or, it will shut itself off, power back on, and resume displaying the colorized white noise. Or, it will display the message, “An error has been detected and recovered,” it will reset itself and start showing content properly again. If it resumes showing content normally again, the 3 to 10 minute timer kicks back in. If it gets past that timeframe, It’ll work great for the rest of that session. But normally, it if goes all white noisey again… it’s done. One time it reset itself twice, then continued working properly.
While poking around trying to research this issue, I’ve found a number of troubleshooting guides related to 7, 11, 13, blinking error codes. I’m very willing to troubleshoot, and then hopefully send a board out for repair… but with the issue being intermittent, none of the guides I’ve found seem to apply. So I’m kind of hoping one of you more experienced folk will have a guess about the component most likely to be the culprit in this situation.
Any suggestions?
Tom
Phredrick42 is offline
Panasonic
