Official Panasonic TC-PxxST60 Series thread - Page 470 - AVS Forum | Home Theater Discussions And Reviews
 199Likes
post #14071 of 14104 Old 11-24-2019, 06:52 PM
Davenlr's Avatar
Quoted: 47 Post(s)
Liked: 38
Originally Posted by snidely View Post
I am a news junkie also. On hours at a time, often in the background as I work from home. Never have had a burn-in problem w. this or an even older Panny. The main "problem" with a plasma is that they burn a lot of electricity.
So what was your secret to keep the CNN logo or the MSNBC logo (the worst, BRIGHT WHITE) from burning in? I found image retention after only two hours. Did you have the brightness and contrast turned way down? I kept mine pretty bright, as the sun shines in that room.
N5GGG
Davenlr is offline
post #14072 of 14104 Old 11-25-2019, 09:03 AM
snidely's Avatar
Quoted: 381 Post(s)
Liked: 91
Originally Posted by Test Ickles View Post
About 60 bucks a year. Lcd about half that.
5 hours day - 30/mo. 392 watt draw = 2+ KW/day 60KW/mo times avg. PGE electric rate of 17 cents/kw = $10+/mo. or $120/year!!! No. Calif pays high rates.
snidely is offline
post #14073 of 14104 Old 11-25-2019, 11:12 AM
dfree86's Avatar
Quoted: 14 Post(s)
Hi Guys,
Happy ST60 owner here since 2013. One question - how's everyone doing on settings this many years later? Back when I first set it up, the go-to setting was "Cinema" with a few tweaks down the each of the menus. I don't remember where I got the original settings.
These days I find the that Cinema is really dark with the blacks - the Battle of Winterfell ep was unwatchable.
On "Home Theater" however, it seemed a lot better.
I don't think my colors have changed a lot throughout and the TV has been extremely solid.
Anyone willing to share or point me in the direction of Settings you're using these days?
*I keep thinking I might replace this ST60 with an OLED or and LCD/LED but I keep liking this picture a lot better...
dfree86 is offline
post #14074 of 14104 Old 11-25-2019, 11:21 AM
Davenlr's Avatar
Quoted: 47 Post(s)
Liked: 38
P55st60
--Picture menu
Picture mode: Cinema
Contrast: 81
Brightness: 0
Color: 50
Tint: 0
Sharpness: 0
Color temp: Warm 2
Vivid Color: Off
C.A.T.S.: Off
Video NR: Off
MPEG NR: Off
Motion Smoother: Off
-- Pro settings submenu
Panel brightness: Low
AGC: 0
Black extension: 0
Color Gamut: Normal
W/B detail adjustment menu:
W/B high R: 6
W/B high G: -1
W/B high B: 1
W/B low R: 1
W/B low G: -1
W/B low B: 0
More detail adjustment menu:[listed as Red, Green and Blue gain, respectively]
100 IRE: -4, 0, 3
90 IRE: -1, 1, 2
80 IRE: 0, 0, 0
70 IRE: 0, 0, 0
60 IRE: 0, 0, 0
50 IRE: 0, 0, 0
40 IRE: -3, -4, -1
30 IRE: 0, 0, 0
20 IRE: 3, -4, 0
10 IRE: -10, -10, 10
Color detail adjustment menu:
Red hue: -8
Red Saturation: 4
Red luminance: -3
Green hue: 3
Green Saturation: 12
Green luminance: 10
Blue hue: 10
Blue Saturation: 10
Blue luminance: -10
Gamma detail adjustment menu:
Gamma: 2.2
100 IRE: 0
90 IRE: 2
80 IRE: 0
70 IRE: 0
60 IRE: 0
50 IRE: -6
40 IRE: -10
30 IRE: -20
20 IRE: -20
10 IRE: -10
--Advanced picture submenu
Game mode: Off
24p Direct in: 60Hz
3:2 pulldown: Auto [often grayed out depending on source]
1080p pixel direct: Off [often grayed out depending on source]
HDMI content type: [all Off]
HDMI/DVI RGB range: [all Standard (16-235)]
Black level: Light
N5GGG
Davenlr is offline
post #14075 of 14104 Old 11-25-2019, 11:23 AM
MrEmoto's Avatar
Quoted: 367 Post(s)
Liked: 306
Hi Guys,
My starting point was D-Nice's settings from a thread on high d e f junkies, a forum that may have gone away. Over time, I tweaked a couple of the parameters very slightly, but i can't recall which. This was done to the "Custom" settings.
But, it seems they are here too: https://www.avsforum.com/forum/167-p...es-thread.html
Panasonic VIERA TC-P55ST30 55-Inch 1080p 3D Plasma HDTV TV
Panasonic DMP-BDT360 3D Blu-ray Disc Player
Panasonic DMP-BDT215 3D Blu-ray Disc Player
Yamaha RX-V757 Receiver, Cambridge Soundworks Towers, JBL center, and assorted other speakers for 7.1
MrEmoto is offline
post #14076 of 14104 Old 11-25-2019, 11:26 AM
Davenlr's Avatar
Quoted: 47 Post(s)
Liked: 38
My 65" Vizio draws 200 Watts according to the specs, but only ~100W measured on a UPS
N5GGG
Davenlr is offline
post #14077 of 14104 Old 11-26-2019, 09:04 AM
zeuspaul's Avatar
Quoted: 253 Post(s)
Liked: 372
Wow! That's a bargain. Here in San Diego we pay 36+ cents per KWH once we get by a tiny base line. I still like my plasma. My heating bill is close to zero this time of year because I don't turn on any heaters and instead rely on waste heat from appliances, TVs and the like. I have a second smaller LCD TV for daytime viewing and only fire up the 65 in plasma for evening (fewer bright banners) viewing.
Spoiler!
zeuspaul is offline
post #14078 of 14104 Old 11-26-2019, 10:30 AM
Process_Theology's Avatar
Quoted: 120 Post(s)
Liked: 25
Do you run the image retention scrolling bar? I have 4 Pannny Plasmas from 768P to the G series, never had any burn in. That is OLED's issue now as far as I can see. This plagued early plasmas but they fixed it, at least on my end. My 2002 CRT rear projection had burn in as I had to replace the blue gun.
(2 1 Parlor 1 Bedroom) Samsung QLED 55 Q80
Pioneer Kuro PDP-6020FD
Panasonic TC-P50G20
Panasonic TC-P55S2
Panasonic TC-P42S2
Process_Theology is offline
post #14079 of 14104 Old 11-27-2019, 12:15 AM
zeuspaul's Avatar
Quoted: 253 Post(s)
Liked: 372
I tried the image retention scrolling bar several years ago as well as running slides. I recall only marginal results and considered it a waste of time. If I look closely when there is a light solid screen in the lower right where logos usually appear I can see some retention. It is not noticeable with normal viewing and you have to know what you are looking for. I think it is image retention and not burn in. I am careful to not display CNN or MSNBC or other serious offenders for extended periods of time. Image retention and power consumption are the primary reasons I have a smaller LCD adjacent to the plasma for daytime viewing.
Spoiler!
zeuspaul is offline
post #14080 of 14104 Old 11-28-2019, 03:58 AM
Quoted: 120 Post(s)
Liked: 25
Humm, the scrolling bar seemed to rid image retention on my end, but I never ran slides, I may have screen burn if I look for it that way, I wouldn't know, I'm not going to look for it that intensely.
Panasonic TC-P50G20
Panasonic TC-P55S2
Panasonic TC-P42S2
post #14081 of 14104 Old 11-28-2019, 10:14 AM
RandyWalters's Avatar
Quoted: 709 Post(s)
Liked: 926
Here's my methods that have worked to remove IR (HD wallpaper images and/or pixel jogger):
https://www.avsforum.com/forum/167-p...l#post56408846
This has worked for myself, and others who've tried it reported it worked for them as well. Worth a shot.
______________
Randy
Sony XBR-55X900E, Panasonic TC-P55ST60, TiVo Roamio Pro, TWC Arris DCX3600-M 6-Tuner DVR, Darbee DVP-5000S, Onkyo TX-SR333 AVR, URC MX-890 Remote.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - https://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #14082 of 14104 Old 11-28-2019, 10:37 AM
zeuspaul's Avatar
Quoted: 253 Post(s)
Liked: 372
Agreed. If I have to look for it I am not going to worry about it. There are probably a lot of other imperfections that I could find if I look for them. Mostly I just am in awe about how beautiful the picture is.
Spoiler!
zeuspaul is offline
post #14083 of 14104 Old 11-30-2019, 03:20 PM
samijubal's Avatar
Quoted: 44 Post(s)
Liked: 99
Just watch the TV without any static images. If it's IR it will eventually go away. If it's burn-in it's hopeless no matter what you do.
samijubal is offline
post #14084 of 14104 Old 12-06-2019, 06:03 PM
fullmetal22's Avatar
Hi guys picked one these bad boys up for a great price. I was curious if anyone had thiers professionally calibrated and how they like it? And if you know of one in the Savannah GA area?
Steve544 likes this.
fullmetal22 is offline
post #14085 of 14104 Old 12-06-2019, 09:42 PM
Steve544's Avatar
Quoted: 185 Post(s)
Liked: 168
It is a somewhat older model but still very good. I believe it was a model below the Panny ZT 65" plasma which had the best blacks of any display on the market at the time. I have had that model and my current display both professionally calibrated. I do believe it is well worth the time and price....however, I would not ask the Best Buy Geek Squad to do it for a number of reasons I won't go into. Find a good certified calibrator who either works independently ,as many do, or one who works out of a high end shop and will not be watching the clock.
Steve Douglas, McIntosh 8207 amp, Anthem AVM-60, Anthem MCA 50 amp, Aerial Acoustics 10T, CC3 center, 5s and SR3 dipole/bipole, 18"Velodyne Sub
Sony 85" 950G, 4 Paradigm Cinema 100 2.0 System and OPPO 203 Blu-ray deck
Steve544 is offline
post #14086 of 14104 Old 12-14-2019, 04:20 PM
samijubal's Avatar
Quoted: 44 Post(s)
Liked: 99
Two below the ZT.
ZT>VT>ST.
post #14087 of 14104 Old 12-14-2019, 04:22 PM
Steve544's Avatar
Quoted: 185 Post(s)
Liked: 168
Nope, the ZT blew everything out of the water at the time. While I sold mine, it still is a fantastic display.
Steve544 is offline
post #14088 of 14104 Old 12-25-2019, 06:50 PM
What's everyone using for gamma? This set is really tricky. The whites are really blown out on these sets. Seems difficult to tame them without killing shadow detail.
post #14089 of 14104 Old 04-20-2020, 09:25 AM
kbuzz's Avatar
Quoted: 115 Post(s)
Liked: 26
anyone know if the I can use bluetooth headphones with the Panasonic TC-P55ST60? And more importantly, how to set this up. Cant seem to find anything in the manual. Thanks
kbuzz is offline
post #14090 of 14104 Old 04-21-2020, 05:08 AM
snidely's Avatar
Quoted: 381 Post(s)
Liked: 91
There is no BT built-in. Since we cut the cord almost 3 years ago, have used one of the many streaming services available (YouTubeTVLive) and use a Roku model (Premiere+) to control it. That model had (has?) a built in headphone jack in the remote control unit.
What is the source of your TV programming? Cable? Internet?
snidely is offline
post #14091 of 14104 Old 04-22-2020, 04:16 PM
Leafs17's Avatar
Is there any way to stop line bleed? It's making watching close ups of people's face near-unwatchable for me.
Leafs17 is offline
post #14092 of 14104 Old 04-22-2020, 08:00 PM
Davenlr's Avatar
Quoted: 47 Post(s)
Liked: 38
Not sure what you are talking about. Are you referring to the vertical lines showing up on some of the news channels on interviews? If so, that is caused by their webcams, and the conversion to broadcast TV, not the set itself.
N5GGG
Davenlr is offline
post #14093 of 14104 Old 04-23-2020, 05:31 AM
Leafs17's Avatar
It's horizontal, across all content. Been happening for months unfortunately.
Leafs17 is offline
post #14094 of 14104 Old 04-23-2020, 08:15 AM
Davenlr's Avatar
Quoted: 47 Post(s)
Liked: 38
Can you post a picture?
N5GGG
Davenlr is offline
post #14095 of 14104 Old 05-23-2020, 12:24 PM
Bruce2019's Avatar
Quoted: 618 Post(s)
Liked: 339
Picture time
Pictures look a bit blown out.. Camera cant handle the contrast
ID:	2731288   Click image for larger version
ID:	2731290   Click image for larger version
ID:	2731292   Click image for larger version
ID:	2731294   Click image for larger version
ID:	2731298   Click image for larger version
ID:	2731300   Click image for larger version
whipit likes this.
2013 Panasonic TX-P42X60E PDP
2013 Panasonic TX-P42STW60 PDP
ST60 Settings: Custom Mode, Contrast 60 = 100nits peak brightness aka Filmmaker Mode, Panel Brightness Medium
Gamma 2.4, Gamma settings: 10% -30, 80% +3
Bruce2019 is offline
post #14096 of 14104 Old 05-23-2020, 01:22 PM
Davenlr's Avatar
Quoted: 47 Post(s)
Liked: 38
Originally Posted by Bruce2019 View Post
Picture time
I must be blind. I cannot see anything wrong with those pictures except the one of Will that looks like light bleed from the center top.
N5GGG
Davenlr is offline
post #14097 of 14104 Old 05-23-2020, 01:42 PM
Bruce2019's Avatar
Quoted: 618 Post(s)
Liked: 339
The light bleed is actually a lens flare effect..
In reality the picture is richer and darker..
Ah Now I understand.. Ok, my pictures have nothing to do with the "line bleed" comment..
But it is true.. The 60 series is well known for Line bleeding..
And No, you cant do anything about that.. Panel lottery.. some models will have it more, some less..
post #14098 of 14104 Old 05-23-2020, 01:44 PM
Bruce2019's Avatar
Quoted: 618 Post(s)
Liked: 339
This is an example of line bleeding:
(found it on the internet)
post #14099 of 14104 Old 05-23-2020, 02:37 PM
Davenlr's Avatar
Quoted: 47 Post(s)
Liked: 38
Ah OK. None of my sets have that issue luckily. That would annoy the hell out of me.
N5GGG
Davenlr is offline
post #14100 of 14104 Old 05-24-2020, 03:52 AM
Quoted: 90 Post(s)
Liked: 45
Just curious but what sets do you have? All the Panasonic's I ever owned exhibited the line bleed but it was only noticeable in special circumstances like the one presented in the photo above. So it never really bothered me.
Majcric is offline
Panasonic Tc P55st60 55 Inch 1080p 600hz 3d Smart Plasma Hdtv , Panasonic Tc P60st60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P65st60 65 Inch 3d Smart Plasma Hdtv , Panasonic Viera Tc P55vt50 , Sony Bravia Xbr52hx909 52 Lcd Tv Direct Led
