Official Panasonic VT60/VT65 Series Discussion Thread [No Street Price Talk] - Page 579 - AVS Forum | Home Theater Discussions And Reviews
 332Likes
post #17341 of 17350 Old 10-05-2019, 02:31 AM
Chere's Avatar
Quoted: 363 Post(s)
Liked: 192
I just happened to see this thread and was quite surprised to learn that modern newer 4k sets don't have the upscaling quality of our 1080p sets for cable, satellite and other lower quality sources. Another reason to keep mine for just a while longer
Chere is offline
post #17342 of 17350 Old 10-06-2019, 10:46 PM
leiff's Avatar
Quoted: 150 Post(s)
Liked: 26
Does anyone else besides me turn game on for sports? I find sports look smoother with game mode turned on so i turn it on for sports
leiff is offline
post #17343 of 17350 Old 10-07-2019, 08:09 AM
RandyWalters's Avatar
Quoted: 679 Post(s)
Liked: 904
Well having replaced my Panny 55" ST60 (which has the exact same panel as the VT60/ZT60) with a Sony 55" X900E UHD TV i can tell you that my TWC/Spectrum Cable signal, OTA Antenna signal, and Roku Netflix signal all look crisper and more detailed on my Sony than they do on my beloved ST60.
I had them side-by-side for several days and did a lot of comparisons. The ST60 does have a better contrast ratio and better black levels (which i fully expected) but the Sony comes pretty close in these categories.
________________
kamouflage and Chere like this.
Randy
Sony XBR-55X900E, Panasonic TC-P55ST60, TiVo Roamio Pro, TWC Arris DCX3600-M 6-Tuner DVR, Darbee DVP-5000S, Onkyo TX-SR333 AVR, URC MX-890 Remote.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - https://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #17344 of 17350 Old 10-08-2019, 10:16 AM
kamouflage's Avatar
Quoted: 180 Post(s)
Liked: 137
________________
Always nice to get feedback from folks that upgrade from these sets.
Xbox Live: PikturePerfekt
PSN: PikturePerfekt07
kamouflage is online now
post #17345 of 17350 Old 10-13-2019, 03:49 AM
Liked: 0
I have a p55vt60y that I recently bought for a reasonable amount. It had about 13000 hours. After a month I got some problems. It started lagging in everything. Power On can take several minutes before I can do anything. Apps or tuners doesn´t work, picture and sound breaks up. HDMI inputs are working without problems, except that it takes about 5 minutes before you get them running.
I opened up the TV and started checking for measuring points. Noted that the cooling plate on the main board gets really hot fast. Found most measuring points and measured the voltages. Found that the STB 5V was only 4.47 volts in both standby and power on mode. I´m not sure if this would matter for the function of the main board.
Tried to restore the TV. I got "Shipping Failed" but everything was showing "OK". After the restore the TV was actually working for an hour before it started lagging again. See picture.
Has anyone experienced something similar?
Regards
Jocke
Joakim Winck is offline
post #17346 of 17350 Old 10-20-2019, 06:10 AM
Scott Oakley's Avatar
Quoted: 220 Post(s)
Liked: 142
Unhappy TC-P55VT60 Frozen on SmartVierra Screen!
Last night in the middle of watching TV, the TC-P55VT60 suddenly turned off and immediately turned back on but locked on SmartVierra screen. I turned off all power to the system. This morning its still locked. Is there anything I can do to reset the TV?
Thank you,
Scott
Panasonic 2013 55VT60
Marantz SR-5012 AVR
B&W 805 Speakers
Velodyne 10" Sub
TiVO Premiere
Scott Oakley is offline
post #17347 of 17350 Old 10-20-2019, 02:26 PM
maritimer555's Avatar
Quoted: 16 Post(s)
Hi,
I'm pasting a post I made in Feb. the problem persists. I'm hoping someone can help me with more suggestions to fix this.
Originally Posted by maritimer555
Hi folks
My rig lately has been shutting itself off randomly while watching a long movie or tv show. It does come right back on when you click it on.
I’ve checked the auto shut off settings and they are both set to Not shut off.
Has anyone else have this problem?
Hi again.
I’m disappointed that I haven’t seen any replies/comments on my post.
It happened again last night and my wife chucked my harmony remote to me and said get it fixed
So I’m not sure What is causing this nor how to fix it. I’m hoping it’s not a power supply issue.
To clarify - when the unit shuts itself off I am able to quickly turn it back on and it’s good for several hours or more. It’s like the auto shut off (which I have set to not engage) is stuck “on”.
Anyone care to speculate what’s happening here.
Yamaha HTR-6063- receiver (or RX-V667)
Sony Bdp-s590
Panasonic VT60 65
Yamaha R N303 stereo receiver
Pioneer PL-200 turntable
maritimer555 is offline
post #17348 of 17350 Old 10-20-2019, 03:40 PM
eaayoung's Avatar
Quoted: 300 Post(s)
Liked: 184
Originally Posted by maritimer555 View Post
Hi,
Hi folks
Hi again.
Is the red light blinking? If so, count the blinks then Google for the cause.
You could unplug the set, let it sit for a period of then plug back in. Sometimes that will reset a fault. I've had it work from me the past.
eaayoung is offline
post #17349 of 17350 Old 10-21-2019, 05:36 AM
whipit's Avatar
Quoted: 130 Post(s)
Liked: 97
Hi,
Other things hooked to the tv can turn it off if you have the HDMI control on. Maybe try turning off any HDMI CEC items in the tv or other components.
whipit is offline
post #17350 of 17350 Old 10-22-2019, 12:19 PM
Quoted: 16 Post(s)
Hi. Thanks for the suggestion. I cannot seem to find where in settings I can the tv for Hdmi control. The only interface to the tv is navidia sheild for cont3nt and Yamaha receiver for sound.
Sony Bdp-s590
Panasonic VT60 65
Panasonic , Panasonic Tc P55vt60 55 Inch 3d Smart Plasma Hdtv , Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P65vt60 65 Inch 3d Smart Plasma Hdtv , Panasonic Tcp65 65 Inch Vt25 3d Plasma Tv
