Official Panasonic VT60/VT65 Series Discussion Thread [No Street Price Talk] - Page 580 - AVS Forum | Home Theater Discussions And Reviews
 342Likes
post #17371 of 17384 Old 03-23-2020, 05:22 AM
Bruce2019's Avatar
Quoted: 614 Post(s)
Liked: 334
Originally Posted by Chere View Post
IMHO I think overheating seems to be the biggest killer of electronic devices especially our Panny sets usually caused by the build up of dust sucked in from the cooling fans. I just had a look at the rear of my 65VT60 and noticed a large build up of dust and the whole thing seems to be getting quite hot. Those 2 pink spots on the left and the right are starting to be very visible in other contents outside of the normal white scenes. These are all red flags which will most likely lead to other more serious problems in the near future. The TV is on a stand which I plan to move to get access to the fan and plan to 'gently' vacuum the dust away with a soft brush.
Does anyone have any different ways or ideas of getting rid of the dust build up especially from the inside without opening the back cover???? I'm thinking compressed air but I'm not sure if that will damage the inside components in any way.. If this is a viable option should I do this with the set turned on or off?
Pink/purple pixel clouds in white?
You should check your VSUS Setting in the service menu and put it to high..
2013 Panasonic TX-P42X60E PDP
2013 Panasonic TX-P42STW60 PDP
ST60 Settings: Custom Mode, Contrast 60 = 100nits peak brightness aka Filmmaker Mode, Panel Brightness Medium
Gamma 2.2 or 2.4, Gamma settings: 10% -30, 20% -15, 30% -5, 80% +3
Bruce2019 is offline
post #17372 of 17384 Old 03-23-2020, 11:43 AM
Quoted: 17 Post(s)
Liked: 1
We've moved and left our old mount for this tv at the house we moved out of. Now I'm looking for a full motion mount for this tv but almost all the full motion mounts I see only have a max VESA of 400 x 600. But the mounting holes on this tv are about 27 inches (which I guess must be 700 mm or so). Does anyone know of a full motion mount that will hand a VESA wider than 600 mm? I noticed that the SANUS site says they have an "adapter" for VESA over 600 but when I call no one is answering (who knows, they might not answer till the corona virus issue is resolved). So coming here for advice from all you experts.
jwilock1 is offline
post #17373 of 17384 Old 03-24-2020, 02:54 AM
whipit's Avatar
Quoted: 141 Post(s)
Liked: 98
I went to monoprice looking for a full motion mount and ended up with this one. It fits the back of the tv just fine and is more than strong enough for it. It is easy to pull out from the wall, better than I expected.
Here's the mount I bought for my 65"
https://www.monoprice.com/product?p_id=36091
whipit is offline
post #17374 of 17384 Old 03-30-2020, 01:20 PM
Liked: 1
Do we know any calibration settings for 3D ?
The 2d settings from D nice are very very good !
amp829 is offline
post #17375 of 17384 Old 04-13-2020, 12:50 PM
emerson1's Avatar
Quoted: 64 Post(s)
Originally Posted by Trojita View Post
My 65" VT60 is still chugging along, but man is this auto shut off thing still annoying me. I first noticed it with the Nintendo Switch, but I believe it has also happened with the PS4. The TV will turn off give or take every 15 minutes of playing. It never happens with my Nvidia Shield watching shows and movies, so I'm wondering if whatever the problem is only occurs with a 60hz signal.
Been using a One X on mine for years and never ran into this
emerson1 is offline
post #17376 of 17384 Old 05-15-2020, 05:30 PM
Quoted: 120 Post(s)
Liked: 2
hdmi
Does anyone know if what's wrong with my tv? I got vt60, when watching sometimes my tv flickers and always changed to HDMI, a video gone but sounds are okay, then after a few minutes, it will come back. how to fix it any solutions? thank you in advance
parekoy is online now
post #17377 of 17384 Old 05-17-2020, 12:24 PM
B T C's Avatar
Location: Lansing, MI via Kentucky, Georgia & Tennessee
Quoted: 689 Post(s)
Liked: 349
Are you having this issue on all three HDMI ports?
Display - Panasonic TC-P65VT60
Front L&R - Polk LSiM703 : Center - Polk LSiM706c : Surround L&R - Polk LSiM703
Subs - Two Rythmik F18-SEs
AVRs - Denon AVR-X6200W, Yamaha RX-A3040 : Amp - Yamaha M-80
B T C is offline
post #17378 of 17384 Old 05-20-2020, 01:01 PM
Quoted: 120 Post(s)
Liked: 2
Never tried other HDMI port. Only using HDMI 2 arc. I am using avr for other HDMI. Once in awhile it flickers. Come and go.
Sent from my OnePlus 7T using Tapatalk
post #17379 of 17384 Old 05-23-2020, 03:27 AM
Quoted: 17 Post(s)
Liked: 0
When off, does anyone's unit automatically click and sound like it is going to power on then stops?
antikk is offline
post #17380 of 17384 Old 05-23-2020, 05:50 AM
Quoted: 59 Post(s)
Liked: 4
Mine doesn't do that but if it did I would try disconnecting it from the internet.
avsforumrocks is offline
post #17381 of 17384 Old 05-23-2020, 07:12 AM
Quoted: 17 Post(s)
Liked: 0
Mine isn’t connected to the internet. I wonder if it is any other attached devices that are causing it to briefly power on. I’ve got a Bluray player connected via HDMI and speakers via S/PDIF
antikk is offline
post #17382 of 17384 Old 05-23-2020, 07:22 AM
eaayoung's Avatar
Quoted: 352 Post(s)
Liked: 212
My ZT does that occassoinally.
eaayoung is offline
post #17383 of 17384 Old 05-23-2020, 08:48 AM
RandyWalters's Avatar
Quoted: 709 Post(s)
Liked: 921
Both my GT50 and ST60 would do this occasionally for no apparent reason. Many other people here on AVS have reported the same thing on the 2012 and 2013 models in various threads, apparently it's a non-issue. Some thinks it's just a relay inside, dunno.
Randy
Sony XBR-55X900E, Panasonic TC-P55ST60, TiVo Roamio Pro, TWC Arris DCX3600-M 6-Tuner DVR, Darbee DVP-5000S, Onkyo TX-SR333 AVR, URC MX-890 Remote.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - https://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #17384 of 17384 Old 05-23-2020, 11:47 AM
Bruce2019's Avatar
Quoted: 614 Post(s)
Liked: 334
Same with my ST60..
Panasonic , Panasonic Tc P55vt60 55 Inch 3d Smart Plasma Hdtv , Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P65vt60 65 Inch 3d Smart Plasma Hdtv , Panasonic Tcp65 65 Inch Vt25 3d Plasma Tv
