Official Samsung PNxxF8500 Owners Thread (No Street Price Talk) - Page 485 - AVS Forum | Home Theater Discussions And Reviews
 1361Likes
post #14521 of 14545 Old 12-18-2019, 12:46 AM
hove131's Avatar
Quoted: 38 Post(s)
I never noticed it until I was up close looking at the panel for any unusual screen issues. It's not noticable at all until you're looking for it. Just curious if anybody else has the same spots in the corners.
Originally Posted by rickardl View Post
Originally Posted by hove131 View Post
I've noticed in the 4 corners of my 64" F8500..there are small bubbles in each corner. They are limited to the blank border strip and not onto the screen. Assuming it's just the filter reacting from the heat of the tv. I have about 2000 hours on the set. Is this normal?
I haven't looked/noticed any on my set and I have never heard about anyone else having this phenomen so I would not call it normal.
hove131 is offline
post #14522 of 14545 Old 12-18-2019, 01:11 AM
rickardl's Avatar
Quoted: 166 Post(s)
Liked: 112
I will take a closer look when I get back home.
rickardl is offline
post #14523 of 14545 Old 12-18-2019, 01:23 PM
rickardl's Avatar
Quoted: 166 Post(s)
Liked: 112
No sign of bubbles or deformation of any kind in any corner.
rickardl is offline
post #14524 of 14545 Old 12-18-2019, 01:25 PM
hove131's Avatar
Quoted: 38 Post(s)
Damn .... guess I just will keep an eye on it
hove131 is offline
post #14525 of 14545 Old 12-26-2019, 04:51 PM
Liked: 0
Hey guys. Not sure if this is the best place to post my question, or if there's a specific thread for troubleshooting, but I'll pay it anyway and you can let me know 😉. I have recently acquired the 60" version of this tv for free, and it is non functional. I'm not very good with electronic circuit boards, but there are no obvious defects (blown caps, burn marks, etc). I have a standby light, and when I turn the tv on, the power light with blink slowly and continuously, and the screen will flicker for a split second, then go blank for a few seconds (10ish), and then it will display HDMI 1 in one corner, and a symbol -:- in the other. At this point, the tv will become unresponsive. Pressing any button on the smart remote, or the spare standard remote I have has no effect. After about 20 or 30 seconds, the tv will power cycle in its own (you can hear a click) , starting the whole process over again. While it's on, the green light on the main board flashes as well. Any suggestions as to what to try/check next?
Thanks in advance.
Aetoc is offline
post #14526 of 14545 Old 12-30-2019, 07:15 PM
Broxin's Avatar
Exclamation
Does anyone know a service man that could get a hold of those logic board files?
Surely it would bother noone as this tv is not sold anymore
Would be very nice
Anyone had this applied and/or know if we can get hold of it anywhere?
SERVICE BULLETIN
PRODUCT:PDP TV
BULLETIN NUMBER: ASC20150408001
BULLETIN DATE: 04/08/2015
MODELS: PN51F8500, PN60F8500, PN64F8500
SUBJECT: Distorted video / flickering in black or dark scenes when Black Optimizer is on
SYMPTOM: The picture gets distorted or displays a ghosting/flickering image in black or dark scenes when the Black Optimizer feature is turned on.
REPAIR: Upgrade the Logic board software. Please follow the steps below.
1. Create a folder named “PDP_LOGIC” in the root directory of a USB thumb drive.
2. Download the proper Logic S/W file. See the below table.
CAUTION: MAKE SURE TO SELECT THE CORRECT FILE FOR EACH MODEL. FAILURE TO DO SO
MAY CAUSE DAMAGE TO THE TV SET.
Model File Name
PN51F8500 Logic_51.bin
PN60F8500 Logic_60.bin
PN64F8500 Logic_64.bin
3. Rename the logic file from LOGIC_xx.bin to LOGIC.bin, and then save it into the PDP_LOGIC folder on the USB drive.
4. Insert the USB thumb drive into the TV’s USB port.
5. Go to Factory Menu → SVC → Upgrade → Logic USB D/L.
6. Press Enter to select Logic USB D/L.
7. Press the right arrow on the remote control to start the upgrade. The value will change to “Upgrading”. Please wait until the process is completely finished. The TV will restart when done.
CAUTION: Do not turn TV off during this process to avoid damage to TV.
8. Note the new logic board version on the top level of the factory menu.
This information is published for experienced repair technicians only and is not intended for use by the public. It does not contain warnings to advise non-technical
individuals of possible dangers in attempting to service a product. Only experienced professional technicians should repair products powered by electricity. Any
attempt to service or repair the product or products dealt with in this information by anyone else could result in serious injury or death. Information provided in this
bulletin is subject to change or update without notice.
File Type: pdf Black%20Optimizer%20ServiceBulletin_ASC20150408001.pdf (192.9 KB, 13 views)
Broxin is offline
post #14527 of 14545 Old 01-05-2020, 04:24 PM
Quoted: 59 Post(s)
Liked: 4
Anybody compared an F8500 to a Panasonic VT60 or ZT60?
avsforumrocks is offline
post #14528 of 14545 Old 01-06-2020, 12:51 AM
rickardl's Avatar
Quoted: 166 Post(s)
Liked: 112
https://www.soundandvision.com/content/value-electronics-hdtv-shootout-and-then-there-were-three-hdtv-scores
avsforumrocks likes this.
rickardl is offline
post #14529 of 14545 Old 01-06-2020, 04:28 AM
Quoted: 59 Post(s)
Liked: 4
Nice. Is the F8500 a lot less reliable than the Panasonics? If so is there a fix?
post #14530 of 14545 Old 01-06-2020, 08:00 AM
Quoted: 494 Post(s)
Liked: 243
https://www.avsforum.com/forum/167-p...s-turning.html
Usually DIY fixable if you can solder.
Test Ickles is offline
post #14531 of 14545 Old 01-10-2020, 05:11 AM
rickardl's Avatar
Quoted: 166 Post(s)
Liked: 112
What is your opinion on leaving the 64F8500 on standby or cutting the power completely while not in use?
Ever since I did the capacitor soldering, my wife insists on pulling the plug after setting it to standby but
I wonder if that could have shortened the life of the power supply board (which died for me two weeks ago)?
rickardl is offline
post #14532 of 14545 Old 01-10-2020, 07:27 PM
shadowspawn's Avatar
Quoted: 207 Post(s)
Liked: 175
I don't know for sure if pulling the plug can shorten the life of anything; I am a bit suspicious that it can, because electronic components don't really like being hard power cycled. But don't take that as truth, because I a not that qualified.
What I am pretty sure of, is that you do NOT need to unplug the TV, ever. My understanding (from this forum) is that the root of the capacitor problem is heat. The F8500 runs really hot, and Samsung used ceramic caps that were not rated for the level of heat that develops inside the unit.
Idling in standby is not hot.
hpp8140 likes this.
shadowspawn is offline
post #14533 of 14545 Old 01-13-2020, 08:54 AM
rickardl's Avatar
Quoted: 166 Post(s)
Liked: 112
Well, since these sets don't have a hard power on/off button, I suspect they are only designed for going to/from standby mode and might not tolerate a hard power cycle each day for 7-8 years.
rickardl is offline
post #14534 of 14545 Old 01-14-2020, 04:44 PM
mesaman's Avatar
Liked: 0
Hey I have firmware 1112
Should I leave it alone. Only connected to net day of setup , but I know black levels decreased, after even the earliest FW updates. Anyone familiar with FW numbers let me know if I'm in a good place, or should I update?
mesaman is offline
post #14535 of 14545 Old 01-14-2020, 04:47 PM
mesaman's Avatar
Liked: 0
BTW I have no issues with buzzing or panel noise. And I mean none. No lighting issues either.
mesaman is offline
post #14536 of 14545 Old 01-15-2020, 05:58 PM
Quoted: 494 Post(s)
Liked: 243
Probably not but be sure to blame it on her.
post #14537 of 14545 Old 01-21-2020, 07:38 PM
Liked: 4
I'll chime in here. I am currently running on 8500 hours on a 51" F8500 plasma that I bought brand new in 2015 for $1100. Mostly watch hockey, football, and Netflix. Zero issues except for the minor buzzing but you can only hear it up close. The picture is still phenomenal to this day and I have no reason to switch until it dies. My brother is a tech snob and he recently had to buy a new OLED because his old LG plasma died. Let's just say he offered to buy my F8500 several times since then and every time some of my friends or family come over to watch the games they are usually saying, "Wow, the picture on this TV looks great." I just chuckle and smirk. I hope it lasts forever.
Skittles005 is offline
post #14538 of 14545 Old 01-21-2020, 08:05 PM
asere's Avatar
Quoted: 1928 Post(s)
Liked: 598
Haha I love it! I'm still enjoying my 60".
Sent from my SM-G935P using Tapatalk
Samsung PN F8500 60'' TV, Denon AVR X4200W, Onkyo TX SR805, Parasound HCA 1500A, SVS Prime Towers and Center, SVS Prime satellites, Proficient Surrounds, Duo Kreisel DXD subs, PSA S3000i sub, Oppo 103D player, Panamax M5300 PM, Monster HTR 3600
asere is offline
post #14539 of 14545 Old 01-22-2020, 07:30 AM
Quoted: 59 Post(s)
Liked: 4
Is there an alternate third-party stand for these like there is for the Kuros? My table is narrow enough that this TV would hang off the sides if its entire width is a stand.
post #14540 of 14545 Old 01-22-2020, 07:36 AM
hpp8140's Avatar
Quoted: 376 Post(s)
Liked: 140
Just search Amazon for universal table TV stand.
Paradigm PW AMP, KEF Q100, Emotiva B1, Rythmik L12
hpp8140 is online now
post #14541 of 14545 Old 02-11-2020, 04:26 PM
Quoted: 59 Post(s)
Liked: 4
Not sure how that works. Is there a VESA bracket on the TV for a universal VESA stand?
post #14542 of 14545 Old 02-11-2020, 04:42 PM
hpp8140's Avatar
Quoted: 376 Post(s)
Liked: 140
Consult the manual. Most TVs are VESA compliant (have VESA holes) It's the same as mounting the TV to the wall, except it comes with a stand as well.
post #14543 of 14545 Old 02-15-2020, 09:11 PM
High Gear's Avatar
Quoted: 29 Post(s)
Samsung F8500
Stopping into the local electronics store today to finally get a look at the 8K TV'S. I was somewhat thrilled at a few although I am still happy with my plasma. My question is can I get a even better quality picture with a Evolution kit? Samsung is offering a SEK-4500. My set is a 2014 model. From reading I see that the SEK-3500 is more of a upgrade, although discontinued. What would be my best option, look on Ebay for a 3500, go for the 4500, or will I not see a true picture quality increase with either?
High Gear is online now
post #14544 of 14545 Old 02-17-2020, 10:02 AM
Bruce2019's Avatar
Quoted: 562 Post(s)
Liked: 322
If you want a better picture quality, nr1 you should invest for a calibration.. Especially Plasma tvs change alot over time..
That said: The new 2018 (SEK-4500) Evolution Kit for a 2013 tv is still a very interesting option.. Picture quality most likely will not improve, but you get for sure newest apps.. I think it is great that Samsung pulled this of after many complaints..
https://www.flatpanelshd.com/news.ph...&id=1537441037
2013 Panasonic TX-P42STW60 PDP
2013 Panasonic TX-P42X60E PDP
Bruce2019 is offline
post #14545 of 14545 Old 02-17-2020, 12:52 PM
thesharkman's Avatar
Quoted: 38 Post(s)
these things are cheap now, albeit used. i originally picked up 60" for my main viewer, but recently picked up a couple of mint 51" versions for $150 and 180 respectively - one for the bedroom and one for a friend who i refused to allow the purchase of a newer (o)led tv.
if you like this model, keep your eyes peeled.
thesharkman
thesharkman is offline
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv , Samsung Pn60f8500 60 Inch 1080p 600hz 3d Smart Plasma Hdtv , Samsung Pn64f8500 64 Inch 3d Smart Plasma Hdtv
