Samsung PN51F5300 ā?? What a little gem! - i1Pro Calibration results inside - Page 63 - AVS Forum | Home Theater Discussions And Reviews
 201Likes
post #1861 of 2013 Old 07-17-2015, 12:42 PM
PhilipsPhanatic's Avatar
Quoted: 434 Post(s)
Liked: 61
Energy Saving Feature: I used the Eco Solutions' Energy Saving feature last night. I watch alot of TV late at night when my eyes are more tired. The sceeen is very bright with the cell brightness set at 20 and I do not have any backlighting system set up yet to reduce the eye strain (used to have it on the Philips with Ambilight).
Anyway...it wasn't bad. I had the HIGH setting on, and it made the viewing a bit more easier and enjoyable. Seems excessive to have the same screen brightness in a dark room that I utilize during the day/early evening when I have sunlight and/or lights on.
Anybody else use the Energy Saving feature to reduce screeen brightness ?
PhilipsPhanatic is offline
post #1862 of 2013 Old 07-17-2015, 04:15 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1961
Yes. I use Low nearly full-time, and High to reduce burn in during other things. That way I never have to change my Cell light setting from 20.
Soulburner is offline
post #1863 of 2013 Old 07-17-2015, 05:01 PM
badmeng's Avatar
Quoted: 12 Post(s)
yes, i also use echo on low with 19-20 cell light, easier on the eyes.
badmeng is offline
post #1864 of 2013 Old 07-17-2015, 10:57 PM
Quoted: 434 Post(s)
Liked: 61
Great...thanks for the feedback.
Aside from gaming, assuming past the break-in threshold, you should be able to avoid using HIGH -- if you want to. 16:9 + Pixel Protect as a backup if you want to play it safe.
post #1865 of 2013 Old 07-17-2015, 10:59 PM
Quoted: 434 Post(s)
Liked: 61
All the time...or just at night ?
It appears that each setting -- LOW, MED, HIGH -- knocks the cell light down by about 5 levels each. Haven't exactly compared actual number changes to the Energy Saving settings, but that's a close ballpark.
post #1866 of 2013 Old 07-17-2015, 11:01 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1961
I use it when I'm playing with speaker setup. A/B comparing, testing different settings, etc. The OSD is up for long periods of time, so the High setting really reduces light output, burn in, and energy use (more than 50%).
post #1867 of 2013 Old 07-18-2015, 12:19 AM
badmeng's Avatar
Quoted: 12 Post(s)
[QUOTE=PhilipsPhanatic;35847698]All the time...or just at night ?
All the time
badmeng is offline
post #1868 of 2013 Old 07-18-2015, 02:17 AM
Quoted: 434 Post(s)
Liked: 61
Really ? How long do you have the OSD on ? I think when I did settings the first time it was maybe 5 minutes or so, if that.
post #1869 of 2013 Old 07-18-2015, 02:30 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1961
An hour or more, if I'm A/Bing speakers with music.
post #1870 of 2013 Old 07-18-2015, 10:31 AM
Quoted: 434 Post(s)
Liked: 61
What is that exactly ? What are you doing ?
Yeah, an hour is long....besides the Energy Saving feature use Pixel Protec 16:9 for extra protection.
post #1871 of 2013 Old 07-18-2015, 01:27 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1961
An easy way to compare speakers is to connect two different ones to your AVR and switch between them while music is playing. It's also useful while positioning speakers or testing different settings. For this, the screen can be on for quite some time.
post #1872 of 2013 Old 07-18-2015, 04:43 PM
Quoted: 434 Post(s)
Liked: 61
OK, got it...I just have a simple soundbar and when I hit MENU, INFO, or TOOLS, they are on for 30 seconds or so, tops.
post #1873 of 2013 Old 09-26-2015, 01:34 PM
Quoted: 434 Post(s)
Liked: 61
SWIVEL ? I have the 60", is the stand made to swivel ? It looks like it moves but I don't want to risk it. I watch the TV during the day from my PC which is about 30-45 degrees in front of the TV to the side, so if I can angle it a bit toward me it's kinda nice.
post #1874 of 2013 Old 09-26-2015, 01:48 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1961
Yes, it can swivel.
I wasn't confident in it as it wobbles a bit, so I replaced it with a solid (but no swivel) stand from Shop Jimmy.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Polk LSiM 702 F/X (2) | Infinity RS152 (4) | Subs TBD (2)
PC: Micca OriGen G2 | Mackie MR624 (2)
post #1875 of 2013 Old 09-26-2015, 01:57 PM
Quoted: 434 Post(s)
Liked: 61
Yes, it can swivel.I wasn't confident in it as it wobbles a bit, so I replaced it with a solid (but no swivel) stand from Shop Jimmy.
Thanks Soul....oh man, I just angled it about 20-25 degrees more towards me and it's SO NICE. BIG DIFFERENCE !! Thanks again !!
I don't have kids and the TV hasn't seemed wobbly to me so I won't worry about it.
post #1876 of 2013 Old 10-24-2015, 02:25 PM
badmeng's Avatar
Quoted: 12 Post(s)
I thought the digital optical output cannot pass thru dd or dts unless its over the air. i have an optical cable from the plasma going into optical in to my sounbar. my dd/dts light on the soundbar never lights up. in the sound menu of the samsung it only gives me PCM. when i turn off the external speakers it gives me the option for dts neo 2.5, i turned that on and now my dd/dts light comes on from my dish receiver or blu ray player and i heard a. vast improvement in sound on the bar, sub, and rear channels, is this the correct setting to have with my setup?
BFJ 96 likes this.
badmeng is offline
post #1877 of 2013 Old 10-24-2015, 03:46 PM
BFJ 96's Avatar
Quoted: 228 Post(s)
Liked: 132
Yes it is.
Sent from My Communication Device...
BFJ 96 is offline
post #1878 of 2013 Old 10-25-2015, 11:45 PM
Liked: 0
Hey guys. I am new here. I really like some of the "settings" suggestion here.
I am sorry if this has been posted, but I didn't have time to read all 65 pages.
I got these setting of plasma tv buying guide. google it. it's still a good site.
Picture Mode: Movie
10p White Balance = ON
Interval Red Green Blue
1 -1 1 -2
2 -2 -2 -2
3 -3 -1 -4
4 -4 0 -3
5 -1 -2 -2
6 -5 -1 -1
7 -7 1 2
8 -1 1 2
9 -5 1 7
10 -3 0 -3
Cell Light 18
Contrast 100
Brightness 48
Sharpness 12
Color 52
Tint G51/R49
Color Tone Warm1
Digital Noise Filter OFF
MPEG Noise Filter OFF
HDMI Black Level Normal
Film Mode OFF
Black Tone OFF
Dynamic Contrast OFF
GAMMA -1 ( I personally prefer gamma on 0 (zero) )
Expert Pattern OFF
RGB Only Mode OFF
Color Space Auto
Flesh Tone 0
Edge Enhancement OFF
Motion Lighting OFF
Energy Saving OFF
ECO Sensor OFF
Auto Power OFF OFF
since using 10 point, leave 2 point alone.
Enjoy. I like the settings from page 1, but I think these are better.
They also give reasons why they chose these settings.
note5 is offline
post #1879 of 2013 Old 10-25-2015, 11:50 PM
Liked: 0
*******************.com is site I was talking about.
They also have an LCD version for your next TV since it can't be plasma.
I will go OLED on my next buy. I got my PN51F5300 for $548 from bestbuy 2 weeks before they stopped carrying plasma.
My bedroom TV is the 42" Panasonic TH PX60U plasma. still incredible at 8-9 years old.
note5 is offline
post #1880 of 2013 Old 10-26-2015, 04:36 AM
34HFX83's Avatar
Quoted: 184 Post(s)
Hello, does this plasma support real 24p playback by changing display refresh rate in multiples of 24 like... 48hz, 72hz, 96hz ?
50 inch Panasonic Viera ST60 (only used for movies)
50 inch Panasonic Viera G20 (only used for sports & gaming)
46 inch Panasonic Viera G10 (retired)
50 inch Pioneer Elite 111FD (ISF-Calibrated by Chad B) http://hdtvbychadb.com/isf-calibration
34HFX83 is offline
post #1881 of 2013 Old 10-26-2015, 12:08 PM
RWetmore's Avatar
Quoted: 686 Post(s)
Liked: 413
Yes, I believe it does. 96khz for 24fps.
RWetmore is offline
post #1882 of 2013 Old 10-26-2015, 01:46 PM
34HFX83's Avatar
Quoted: 184 Post(s)
Also is it true that F5300 is basically the baby F8500 but with no glare/reflection filters, 3D and smaller power supply?
I think I have never watchjed a plasma without a filter. I wonder how does this picture quality look in a pitch black room...
34HFX83 is offline
post #1883 of 2013 Old 10-26-2015, 02:00 PM
RWetmore's Avatar
Quoted: 686 Post(s)
Liked: 413
Yes, and doesn't get nearly as bright.
A set without a filter looks more transparent in pitch black room than in a room with ambient light. I prefer no filter myself, but most people want it to limit reflections during daytime viewing.
RWetmore is offline
post #1884 of 2013 Old 10-26-2015, 07:13 PM
Quoted: 434 Post(s)
Liked: 61
They also have an LCD version for your next TV since it can't be plasma. I will go OLED on my next buy. I got my PN51F5300 for $548 from bestbuy 2 weeks before they stopped carrying plasma.My bedroom TV is the 42" Panasonic TH PX60U plasma. still incredible at 8-9 years old.
Wow, surprised any Best Buys still had a 5300 -- did you track it down, get it from a warehouse, or just get lucky ?
I think my parents have a 42" PX60U in their bedroom -- almost 7 years now. Tried to check the hours a few months ago but couldn't get into the SM.
post #1885 of 2013 Old 10-26-2015, 07:15 PM
Quoted: 434 Post(s)
Liked: 61
How would one know ? I think when I play back Blu-Rays on the Blu-Ray player it converts it because I see 24p when I hit the Samsung INFO function on the remote.
Not sure I have seen anything on cable with 24p.
post #1886 of 2013 Old 10-26-2015, 08:03 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1961
Pop in a Blu-ray and go into the TV settings and turn "Film Mode" to Cinema Smooth.
Find a scene with panning. It's easy to see the difference when switching back and forth.
post #1887 of 2013 Old 10-26-2015, 10:21 PM
Quoted: 434 Post(s)
Liked: 61
Pop in a Blu-ray and go into the TV settings and turn "Film Mode" to Cinema Smooth. Find a scene with panning. It's easy to see the difference when switching back and forth.
What's panning ?
Blu-Ray cartoon or actual film best ?
post #1888 of 2013 Old 10-26-2015, 10:39 PM
Quoted: 434 Post(s)
Liked: 61
More or less, plus the pentile display on the 5300 is a step-down. But not by much.
I just don't think the glare/reflection filters are that big a deal unless you have tons of light or lights in the room. You can always buy a Glarestopper product if glare is a problem.
post #1889 of 2013 Old 10-26-2015, 10:42 PM
Quoted: 434 Post(s)
Liked: 61
Always good to have another reference set, here is the link to Orion's which everybody here swears by. It's Page 28 in another 5300 Thread, I believe others are either a few pages before/after his.
Here's the link:
https://www.avsforum.com/forum/167-pl...l#post27866097
post #1890 of 2013 Old 10-27-2015, 12:31 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1961
Here's the link:
And mine is in my sig.
Samsung Pn51f5300 51 Inch Plasma Hdtv
