How many hours do you have on your F8500? Any issues? - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #1 of 46 Old 10-03-2015, 11:55 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 3
I'm at ~800 on my 64" F8500. No issues and I have a small fan mounted behind it keeping air circulating.
Video: Samsung PN50C550 & PN64F8500
Audio: Infinity Kappa 8.1's powered by a Yamaha HTR-5590
wfarrell4 is offline
post #2 of 46 Old 10-03-2015, 01:07 PM
AMartin56's Avatar
Quoted: 2166 Post(s)
Liked: 1150
500ish hours on my fourth panel. No obvious issues with this one. Previous ones had dead pixels, banding or electrical issues. Not sure I'll buy Samsung again. I let my 'need' to get a plasma before they are gone over ride my previous bad experiences with them.
AMartin56 is offline
post #3 of 46 Old 10-03-2015, 02:13 PM
muffinmcfluffin's Avatar
Quoted: 320 Post(s)
Liked: 196
I'll check on hours when I get home, but no issues yet and owned since July 2013.
Unless you count its 3D issue as an issue.
muffinmcfluffin is offline
post #4 of 46 Old 10-03-2015, 02:42 PM
RodK's Avatar
I'm not sure of my hours. I have never checked. I have had mine since June 2013. I had to have my power supply board rebuilt last month. Cost me $200 cdn.
RodK is offline
post #5 of 46 Old 10-04-2015, 05:37 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
There's a counter in one of the menus?
psgcdn is offline
post #6 of 46 Old 10-04-2015, 06:19 AM
Xpcgamer's Avatar
Had mine since 2013. Two main boards and one power supply. Now the entire panel is getting replaced due to 3 red lines. I guess I should have invested in a fan .
Xpcgamer is offline
post #7 of 46 Old 10-04-2015, 07:06 AM
AMartin56's Avatar
Liked: 1150
Press Mute 7 3 7 Enter on the remote with the TV on (You might have to try a few times to get the timing down). MRT is panel time in hours. Turn the TV off to exit the menu.
psgcdn and roman schepis like this.
post #8 of 46 Old 10-04-2015, 08:52 AM
RWetmore's Avatar
Quoted: 625 Post(s)
Liked: 388
It does seem this set is prone to a lot of issues and failures. It was new tech. by Samsung back in 2013, whose implementation, I suspect, had not yet been fully perfected (or the bugs had not been fully worked out). It's too bad they didn't have a couple more years to refine the tech. and make it more reliable.
RWetmore is offline
post #9 of 46 Old 10-04-2015, 09:25 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
I don 't have the extended remote (Canadian model) and my Harmony remote doesn't seem to do it (using central button 'ok' for enter). When I press Mute, the TV displays that the TV is set to use external speakers and that's as far as it goes. Ah well.
psgcdn is offline
post #10 of 46 Old 10-04-2015, 10:51 AM
AMartin56's Avatar
Liked: 1150
You might try doing it faster. It took me a few times.
post #11 of 46 Old 10-04-2015, 03:50 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 3
I wonder if the earlier releases are more prone to failure.
post #12 of 46 Old 10-05-2015, 04:34 AM
Quoted: 231 Post(s)
Liked: 40
PN51F8500, Nov 2014 Manufacture date with ~1500 hours. No issues.
Michael Vincent Praino is offline
post #13 of 46 Old 10-05-2015, 04:45 AM
Quoted: 1708 Post(s)
Liked: 738
5,934 hours with no fan modifications and no major problems. On rare occasion, it'll reboot itself but I'm not sure that isn't some app updating itself. 64F8500 sits on stand open all the way around. Room temperature averages around 74 degrees...wife likes to keep it cool.
JimP is offline
post #14 of 46 Old 10-05-2015, 05:07 PM
Xpcgamer's Avatar
Sorry and I hope it does not start with you but that is how my issue's started. It went from that to actual loosing audio to the TV locking up. Only way to fix it would be to unplug it.
Xpcgamer is offline
post #15 of 46 Old 10-05-2015, 05:25 PM
Quoted: 320 Post(s)
Liked: 196
5,592 hours. No known issues.
post #16 of 46 Old 10-06-2015, 11:05 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Worked! Only 470 hours over 1 year.
psgcdn is offline
post #17 of 46 Old 10-06-2015, 04:55 PM
PhilipsPhanatic's Avatar
Quoted: 428 Post(s)
Liked: 61
Can you change the title of this thread to reference ANY of the 2013-15 Samsung plasmas: the 8500, 5300, 5000, etc. ?
Should get more posts and activity that way and avoid the need for separate threads for those models.
PhilipsPhanatic is offline
post #18 of 46 Old 10-06-2015, 08:19 PM
roman schepis's Avatar
F8500 Mine is at 5,924 hours. No issues at all. No mods, mounted to wall unit with good ventilation behind it.
roman schepis is offline
post #19 of 46 Old 11-29-2015, 04:17 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 3
Bump. Anyone else?
PhilipsPhanatic likes this.
post #20 of 46 Old 11-29-2015, 09:11 PM
Quoted: 428 Post(s)
Liked: 61
Guys, when you post your hours, please tell us when you got your 8500 or other Samsung plasma.
post #21 of 46 Old 11-29-2015, 09:14 PM
Quoted: 428 Post(s)
Liked: 61
Samsung 60" 5300B: I have a Samsung 5300 B; got mine in Mid-May 2015, and just hit 2,258 hours today. Works out to about 80 hours a week, which has been pretty constant since I got it (a slight tick up for football season the last few months).
Couldn't afford the 8500 but very happy with this TV.
post #22 of 46 Old 12-01-2015, 06:49 PM
fierce_gt's Avatar
Quoted: 1992 Post(s)
Liked: 1896
got mine in apr 2013 (3170hrs), no issues with the display at all, but the software has always been buggy. if i'm calibrating, i usually have to restart it a few times as it'll lock up the menus if i'm in there a lot. i never used the smart features until i moved, and i've had them freeze up on me twice in the last two weeks.
still, i'd much rather spend a couple hundred bux on another htpc than buy one of the tv's currently on the market. nothing's perfect i suppose, so i'll choose picture quality over features whenever i can
EDIT: i seem to be having issues with the tv disconnecting from my network now too. when the htpc was sitting in front of the tv, it was working great. that's why i decided i'd move it into the basement and clean up the living room set up(it's just the tv hanging on the wall now), but it seems after about 20mins or so, it'll say 'check network connection' and then stop playback. i'm going to try hooking up the htpc to a wired connection, and i still need to unpack and setup my router instead of using the one the ISP provided. my plan was run everything with cat6 cable on the network, as i've never had consistent wifi when trying to stream video.
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC, PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
post #23 of 46 Old 12-02-2015, 12:09 AM
Quoted: 428 Post(s)
Liked: 61
Hours, Fierce ????
post #24 of 46 Old 12-02-2015, 11:12 AM
Liked: 1
Fall 2014 51F8500 - 1250 hours, no issues at all. On a stand with no fan.
rdk914 is offline
post #25 of 46 Old 12-05-2015, 08:01 PM
Ice That Jaw's Avatar
I had mine of about 20months watching at least 4 hours a day and no issues with PQ although the TV tends to freeze up at least once a week when using the apps.
Ice That Jaw is offline
post #26 of 46 Old 12-07-2015, 06:41 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 3
I'll m at ~865 hours since 10/14 on my 64". I have recently installed a rather loud fan for the back. It's mounted on a stand approximately 18" from the wall.
post #27 of 46 Old 12-07-2015, 11:18 PM
Quoted: 428 Post(s)
Liked: 61
Only about 15 hours per week on the TV ? Do you have others you use in the house as well ?
post #28 of 46 Old 12-27-2015, 03:58 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 3
Not really. I don't have a lot of time to watch TV....not sure why that is so surprising.
post #29 of 46 Old 01-02-2016, 06:26 PM
jeremola's Avatar
A bit under 1500 hours on a panel purchased in June 2013. Lines on the left side. Not happy.
https://www.avsforum.com/forum/166-lc...l#post40255338
I like stuff.  And things.
jeremola is offline
post #30 of 46 Old 01-07-2016, 09:32 AM
docopfw's Avatar
no problems here. then again apparently i didn't use it as much as the rest did in this thread.
PN60F8500
firmware 1204.4
154 hours
manufacturing date nov 2014
bought it in december 2014
docopfw is offline
