Has anyone been able to 'sync' their Samsung Galaxy cell phone to their Samsung PDP? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-12-2015, 02:26 PM - Thread Starter
JCUMV's Avatar
Guys,
I have a Samsung Galaxy S5 and I'd love to be able to push my pics and vids to my Samsung C8000 PDP. I know in the PDP menu there is a Any-net (or some other name) feature that links up my Samsung Blue Ray to the panel. Kinda of an integration tool that allows you to use one remote. Or something like that.
I know you can do this kind of thing with Apple devices using the Airplay mirroring feature. I'm looking for something like that between my Sammy phone and Sammy TV. Any help or ideas would be appreciated.
JCUMV is offline
post #2 of 3 Old 11-16-2015, 11:59 AM - Thread Starter
JCUMV's Avatar
Guys, I thought I'd let you know that I found the answer, and wanted to share the info with you. Assuming your Sammy PDP is on the same Wifi network that your Sammy cell phone is, you can use a feature on the mobile device called "Mirror Image" which presents you with a list of devices on the same Network. Select the PDP from the list and your mobile device desktop is now showing on your plasma display! Very cool. Watch YouTube, play Videos, scroll through pics, etc. It works great.
Just an FYI.
JCUMV is offline
post #3 of 3 Old 11-22-2015, 11:56 PM
PhilipsPhanatic's Avatar
Quoted: 428 Post(s)
Liked: 61
Does the 5300 have this capability ? I don't think it's a smart TV.
PhilipsPhanatic is offline
