Samsung F8500 died today - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 4 Post By comtech5
post #1 of 8 Old 08-27-2017, 01:54 PM - Thread Starter
comtech5's Avatar
Have power all way to panel input, panel cold, input signal present, no display, no red light, remote unresponsive. Anything I can do to troubleshoot?
comtech5 is offline
post #2 of 8 Old 08-27-2017, 07:02 PM
germanplumber's Avatar
So no red status light when plugging in points to a power or main board issue.
First things first, have you measured STBY voltage from power to main? That red status light gets power from the main, but that get power from the power board obviously.
Do you hear a relay click when you first plug the TV into the wall? If you don't, its a power board more than likely. Simple fix, either replace the board or pull the board out and send it off to be fixed. Verify which board is the problem though.
EDIT: http://www.ebay.com/itm/Repair-Servi...oAAOSwbdpWYxDs
There is a link to ebay for the 51" F8500 power supply. You send it in and they repair it.
Last edited by germanplumber; 08-27-2017 at 07:11 PM. Reason: Link for Ebay repair service
germanplumber is offline
post #3 of 8 Old 08-27-2017, 08:22 PM - Thread Starter
comtech5's Avatar
Mine is 64". Are there any fuses or reset buttons on the power board that I can check first? Are there any links on how to access the board?
comtech5 is offline
post #4 of 8 Old 08-28-2017, 05:03 AM
Yes there is a fuse on the power board. I doubt it will solve your issue. Normally more than a fuse gets damaged when it fries. No reset switch. Be careful when you open this thing and work on it. It can seriously hurt or kill yourself.
post #5 of 8 Old 08-28-2017, 09:38 AM - Thread Starter
comtech5's Avatar
Both fuses are good on power supply board. No signs of bulging capacitors. I forgot to mention that I have both no sound and no pic. Maybe a bad MOS-FET on P/S ? What connector and pin will I find Vs?
comtech5 is offline
post #6 of 8 Old 08-28-2017, 08:12 PM - Thread Starter
comtech5's Avatar
Bought a reasonably priced replacement power supply board on eBay from a reputable dealer. We'll see what happens when I swap it out.
comtech5 is offline
post #7 of 8 Old 08-31-2017, 11:10 AM - Thread Starter
comtech5's Avatar
Swapped out power supply board. All is working fine now! Thanks to all.
comtech5 is offline
post #8 of 8 Old 08-31-2017, 06:22 PM
Quoted: 467 Post(s)
Liked: 228
Good job!
Test Ickles is offline
