Should I Fix or Replace My Pioneer Kuro PDP-5020FD? Ask the Editors - AVS Forum | Home Theater Discussions And Reviews
 61Likes
post #1 of 79 Old 10-16-2017, 05:24 PM - Thread Starter
Scott Wilkinson's Avatar
Quoted: 1881 Post(s)
Liked: 4905
Jim's Pioneer Kuro is really showing its age, especially after the power fluctuations during Hurricane Irma. Should he get it fixed or replace it?
https://www.avsforum.com/ask-editors-...ro-pdp-5020fd/
freeman4 likes this.
Scott Wilkinson is offline
post #2 of 79 Old 10-16-2017, 05:56 PM
Quoted: 437 Post(s)
Liked: 209
The sparkles and Red Tint can be fixed by entering the service menu and changing some values. Is it worth fixing? Yes because the fix is basically free. All he will need to buy is a cable. He will need to do his research. All the info is available right here on AVS.
Test Ickles is offline
post #3 of 79 Old 10-16-2017, 07:39 PM - Thread Starter
Liked: 4905
Well, I didn't know that! Can you point to a thread in which this is discussed? Thanks!
post #4 of 79 Old 10-16-2017, 08:14 PM
jjv238's Avatar
Quoted: 49 Post(s)
No way I could have gone from replacing my Kuros with anything other than OLEDs due to the black levels. It is tough to even watch a lot of these new LCD LED backlit crap.
TheBrandon likes this.
jjv238 is offline
post #5 of 79 Old 10-16-2017, 08:42 PM
jjv238's Avatar
Quoted: 49 Post(s)
This is the thread I used a few years ago, it worked for me.
https://www.avsforum.com/forum/#/topics/1532421
jjv238 is offline
post #6 of 79 Old 10-17-2017, 06:57 AM
ll Viper ll's Avatar
Quoted: 217 Post(s)
Liked: 138
yup, don't toss that kuro until you've tried the black level/red tint tweaks in those threads (you can find them by just searching red tint kuro thread or red tint fix I think).
Worked to optimize/return black levels to factory level or better all while ridding the unit of the dreaded magenta sparkles. Granted these aren't forever fixes but they should be good for much longer than he intends to keep the unit, I'm guessing.
User makaveddie81 was immensely helpful with this, as he's a real kuro buyer/fixer. For a nominal fee, he will assist in accessing or even performing the fixes remotely for you. He sells software that can assist in this as well.
Well worth the cost imo. EDIT: I should note that this was a year + ago when he helped me, not sure if he's still active but it's probably worth a shot.
biliam1982 and freeman4 like this.
ll Viper ll is offline
post #7 of 79 Old 10-17-2017, 08:13 AM
p5browne's Avatar
Quoted: 3991 Post(s)
Liked: 3166
Also, with there having been a storm, and if the Kuro wasn't protected with a UPS, he may need to take the back cover off, and replace swollen capacitors. You can either replace them yourself, or usually a competent electronics repair guy will probably do it for less than $100. Normally it's just unclipping connections to the PS board, and taking it into the repair guy. Note, while in there you may find the screws holding down the PS and other boards have worked loose over the years, so, if no swollen capacitors, tighten ALL mounting screws to improve grounding. See if that works.
UN65KS9800 - Mine
UN65HU9000 + SEK-3500U / UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN40J5200AF / HiSense 40H5507 - Wife's
UN55NU8000 X 2 - my 2 kids families (or should I say adults?)
p5browne is offline
post #8 of 79 Old 10-17-2017, 08:30 AM
Fizban19's Avatar
Quoted: 204 Post(s)
Liked: 103
I thought the same thing until the OP mentioned that he uses his Kuro as a computer monitor . If that is his main use, I would get an LCD. Using an expensive OLED TV as a computer monitor is sacrilege....hell, using the Kuro as a computer monitor is sacrilege!
My 9 year old KRP 500M Kuro displays a better HD cable broadcast then my 4K LG OLED. 4K discs are another story though .
Fizban19 is offline
post #9 of 79 Old 10-17-2017, 09:40 AM
Ozymandis's Avatar
Quoted: 222 Post(s)
Liked: 224
Smile
https://www.avsforum.com/forum/167-pl...set-guide.html
The steps are a little different for the 5020FD- you only need to enter the "FAY" command to enter the service menu, then hit the "Mute" button on your remote to get to the adjustment menu. I just bought a used 5020FD from Craigslist and the resources in that thread, plus makaveddie81's awesome advice, got my display sorted out. These Kuro plasmas still look gorgeous, and when tweaked the black levels are only beaten by OLED.
LG OLED65B7 | Yamaha v661 | Aperion 5.1 w/ SVS sub | PS4 Pro | Xbox One X | HTPC (i7-7700K, 1080 Ti, Define Nano S)
Pioneer 5020FD | Panasonic 46S30 | Hitachi P50V701
Ozymandis is offline
post #10 of 79 Old 10-17-2017, 10:40 AM - Thread Starter
Liked: 4905
https://www.avsforum.com/forum/#/topics/1532421?page=1
Unfortunately, that link takes me to the main forum index, not to a particular thread. Can you provide any other links to relevant threads? Thanks!
post #11 of 79 Old 10-17-2017, 10:46 AM - Thread Starter
Liked: 4905
I searched for "red tint kuro" and "red tint fix" and got a l long list of irrelevant threads, apparently because some of the words in the search string are too common. Any other ideas of word strings to search for?
post #12 of 79 Old 10-17-2017, 10:47 AM
jjv238's Avatar
Quoted: 49 Post(s)
Scott, that is bizarre, I just clicked on the link from my iPhone and it takes me to the Pioneer Kuro Post Reset Recovery Guide. I don?t quite know what else to link because it works fine on my end. Maybe try googling Pioneer Kuro Post Reset Recovery Guide avs and it should show up I would think.
jjv238 is offline
post #13 of 79 Old 10-17-2017, 10:48 AM - Thread Starter
Liked: 4905
Now we're talking! That procedure looks pretty daunting! Also, I couldn't find anything in the OP of that thread that mentions magenta sparklies, but maybe I just missed it. I'll add this link to the original article. Thanks!
post #14 of 79 Old 10-17-2017, 10:58 AM
TheZoof's Avatar
Quoted: 149 Post(s)
Liked: 54
Great thread.
Love my Kuro. It really was the best electronic purchase I have ever made.
I still get people comment on how good the picture looks on the TV and then they always ask "why is the tv so thick"?
Hope you get it sorted. I will be buying a new TV soon however will try and put my Kuro somewhere in the home.
Ozymandis and freeman4 like this.
Zoof
Theater || 82NU8000 | Pioneer SC-LX901 | Paradigm 85F - 55C - 15B - E80R | Syzygy SLF870
Rec || Pioneer KRP 500m | Pioneer SC-25 | PSB B25
Casual || LC-65LBU591C
TheZoof is offline
post #15 of 79 Old 10-17-2017, 11:02 AM - Thread Starter
Liked: 4905
You're right, that is bizarre! I found the thread you're referring to, and I added it to the article. Thanks!
post #16 of 79 Old 10-17-2017, 11:03 AM
Quoted: 217 Post(s)
Liked: 138
https://www.avsforum.com/forum/167-pl...et-panels.html
A lot of what's in there is relevant to non-500m models with minor tweaks. This and the reset guide combined are a great resource. Props again to everyone who contributed.
Edit: The 500m thread has a really hand, concise guide. The below thread has a lot more in depth discussion (toward the end) from users on what worked on their various models...even if you weren't going to keep the Kuro for more than another year, this stuff is just fun to me so I didn't mind digging through the threads when I was first considering tweaking my original 5020. It was so rewarding I bought a second 5020 with a bad mainboard off CL for $50, used an eBay repair service for the bum mainboard for $100, and put it back together myself (and then did the red tint removal/black level tweaking).
https://www.avsforum.com/forum/167-pl...thread-99.html
post #17 of 79 Old 10-17-2017, 11:10 AM
Quoted: 79 Post(s)
Like what others said above, git down 'n dirty by adjusting voltage tweaks.
And get a APC Liner R 1200 voltage regulator for just $50
34-hfx-83 is offline
post #18 of 79 Old 10-17-2017, 11:15 AM
freeman4's Avatar
Quoted: 70 Post(s)
Liked: 1057
Scott,
Thank you for posting my issue.
In the meantime, I discovered, read, and obtained the help I needed in the thread referenced in a few of the above posts, the Pioneer 8G 9G Kuro Reset Guide thread.
The link to the page where I received my help is: https://www.avsforum.com/forum/167-pl...l#post54962828
It was just a matter of connecting a null modem cable to the tv, establishing communications with a terminal program, and issuing some commands. Now my tv is practically perfect again. I may do some further tweaking, but I am very pleased with the results.
Big thanks to user, makaveddie81 who really knows how to tweak Kuros!
Thanks again for posting my issue and for all the helpful comments!
BTW, although I use my Kuro as a computer monitor, I mainly use my computer as a media center. Also in the chain are an Onkyo TX-NR807 and some Paradigm speakers. I also have an Oppo BDP-80 for blu-ray viewing as well as DVD-A and SACD listening. In addition, I am now protecting my tv and avr with a ups.
Ozymandis and Mashie Saldana like this.
freeman4 is offline
post #19 of 79 Old 10-17-2017, 12:56 PM
fierce_gt's Avatar
Quoted: 1996 Post(s)
Liked: 1896
the only thing that gets me is the 'using as a computer monitor' part.
for that particular use, it may be completely acceptable(even better) to use a newer 4k lcd screen. for tv/movie/gaming i would definitely steer the owner towards an oled if it can't be fixed through the service menu.
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC, PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
post #20 of 79 Old 10-17-2017, 02:46 PM
Lurker123's Avatar
Quoted: 56 Post(s)
Liked: 25
Originally Posted by freeman4 View Post
Scott,
Well, in that case I'm using my 65" ZT60 as a computer monitor....
But yes, I have 1300 to 1500 kVa UPSes for all my electronic equipment, except my AVR and subs, which are only on the surge protection side of their respective UPS or surge protectors (pulls too much current)
Lurker123 is offline
post #21 of 79 Old 10-17-2017, 03:10 PM
phxrider's Avatar
I was stuck on my Panasonic plasma and thought I needed a really expensive OLED to replace it and conventional LED wouldn't do, but now I have a Vizio P75 and couldn't be happier. Just replace it with one of the author's recommendations, you won't be sorry.
phxrider is offline
post #22 of 79 Old 10-17-2017, 03:20 PM
hhowards's Avatar
Quoted: 95 Post(s)
Liked: 73
"As good as the Kuro was, it was 1080p SDR (standard dynamic range), and the video world has moved on to 2160p HDR"
I would amend that statement to say "some of the video world has moved on..." Finding full 2160p HDR programming can still be hit-or-miss, especially on cable TV, where it is all but non-existent. I will keep my 1080p plasma TV as long as I possibly can, because it displays a beautiful, realistic picture (live broadcast sports -- even in 720p -- can look amazing on plasma) and the vast majority of the media available to me is still not UHD/HDR, including my entire Blu-ray collection. The fact that my plasma TV is 1080p/SDR would be one of the least important factors I'd personally take into consideration when trying to decide whether to replace my set with a newer model. I'm also rather averse to junking good technology that is still performing perfectly well for me.
I'm really glad to hear that Jim has found the solution for his Kuro, restoring its ability to display a gorgeous image, hopefully for years to come...
Routinely stumbling down rabbit holes...
hhowards is offline
post #23 of 79 Old 10-17-2017, 03:52 PM
Yog
Yog's Avatar
Never ever get rid of your KURO, you still not gonna get any TV to that level.
I still enjoy my KURO PRO151FD and Elite Signature PRO141FD both calibrated. The other day we were out to get the best 4K options but my wife comments were that she doesn't notice any difference.
Glad your issue is resolved.
Yog is offline
post #24 of 79 Old 10-17-2017, 06:30 PM
Mr.SoftDome's Avatar
Quoted: 665 Post(s)
Liked: 528
What a load of crap
Mr.SoftDome is online now
post #25 of 79 Old 10-17-2017, 07:20 PM
Quoted: 437 Post(s)
Liked: 209
He's right. My KRP-600M is my favorite TV and I have a VT60 and an LGB6 OLED. Can the Kuro do HDR and is it's black as good as the OLED? No but on HD programming and Blu Ray's (95% of what I watch) it's great.
post #26 of 79 Old 10-17-2017, 07:31 PM
Quoted: 437 Post(s)
Liked: 209
I use a Panasonic TC-50GT30 as my computer monitor. It's great. What I do to avoid image retention is to vary the size of the image. I go into the catalyst control center (CCC) of the computer and change up the image size once in awhile. 100% is too big on a 50" sitting at a desk. Making it about 42" to 45" is perfect. Then after every session I run the image scroll in the TV menu for 5 minutes or so to clear up the black bar retention that goes around the edges. If I wind up with a little burn I don't care. Bought this set broken and fixed it.
post #27 of 79 Old 10-17-2017, 07:35 PM
Quoted: 437 Post(s)
Liked: 209
Scott,
Yes makaveddie81 is the guru of Kuro's.
post #28 of 79 Old 10-18-2017, 05:17 AM
ntstambo2's Avatar
Quoted: 83 Post(s)
I can't believe anyone would even consider repairing these now unless they're going to be a collector's item.
ntstambo2 is offline
post #29 of 79 Old 10-18-2017, 08:39 AM
TheBrandon's Avatar
Quoted: 555 Post(s)
Liked: 220
I certainly would. Depending on cost I'd probably just move to a 65 inch OLED. Isn't motion resolution on Kuros like 1080 lines compared to most 2160p devices at 300-700? @ .003 blacks, they are flat out hard to beat and the motion is incredible. I am sure this would depend on seating distance on the jump to 4k. My Kuro lives in a rec room so we are seated maybe 10 feet or so from a 50 inch. I have never seen a better picture all things considered and that includes OLED (factoring I've never seen on calibrated correctly and I also factor in motion resolution). For movies, we are in a dedicated theater room but its really hard to let a good plasma go.
TheBrandon is offline
post #30 of 79 Old 10-18-2017, 08:41 AM
Ozymandis's Avatar
Quoted: 222 Post(s)
Liked: 224
The cables are like $12, and it takes an hour or two of your time. What you get is a display that:
-has the absolute best black level available outside of the LG/Sony OLEDs
-handles motion better than anything currently on the market
-is more uniform than anything currently on the market
-handles 720p and 480p sources well compared to 4K TVs
I think that plasma still displays a beautiful picture that feels natural and pleasing. I'm with @Test Ickles , I actually prefer the quality of the image to my OLED, if I'm being honest, even though the OLED has better black levels. Where the OLED shines is with HDR, but for SDR like my Blu-ray collection, I'll watch that all day on my Kuro or Panny plasma
ask the editors , kuro , PDP-5020FD , tcl 55" p-series , vizio 2016/2017 p-series & m-series displays
