Plasma tv matte vs glossy ? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By fierce_gt
  • 1 Post By RandyWalters
post #1 of 8 Old 01-30-2018, 06:31 PM - Thread Starter
Liked: 0
I am sure this may be a silly question but I am in the market for a used plasma and I don't have much experience with them, so not sure if they are all glossy or matte, which is my question.
Rod K is offline
post #2 of 8 Old 01-31-2018, 05:27 AM
Quoted: 231 Post(s)
Liked: 40
Matte will generally be less reflective and glossy could give you more glare. You will be hard pressed to find a plasma now though given that they have been EOL since ~2014
Michael Vincent Praino is offline
post #3 of 8 Old 01-31-2018, 06:37 AM
Bruce2019's Avatar
Quoted: 510 Post(s)
Liked: 274
Most of theme are glossy. But I would call it reflective..
The higher models had on top of the reflective glass a black filter, that reduced reflections and reduced washed out colours in a bright light environment. These are also glossy. On daytime it is easy to spot.. when you see a black screen then there is a good black filter. When you see a grey screen like a CRT.. the filter is not so good.
Matte plasmas are very rare.
https://www.rtings.com/tv/learn/what...i-glare-filter
For what model/brand are you looking for? The more budget, the more reflective..
Panasonic 42inch ST60 owner
Panasonic 42inch S10 ES (Europe/Silver) owner
Bruce2019 is online now
post #4 of 8 Old 01-31-2018, 07:43 AM
markg35's Avatar
Quoted: 336 Post(s)
Liked: 261
You can find plenty of used ones.You do have to look around for decent deals though.
markg35 is offline
post #5 of 8 Old 01-31-2018, 06:12 PM
fierce_gt's Avatar
Quoted: 1981 Post(s)
Liked: 1881
my thoughts on matte vs glossy(which is really just for fun, since it's unlikely you can find a matte screen plasma anyway)
i'd much much much rather have 3% of the screen completely blown out, than 97% of the screen mostly washed out
and one shot without reflections just to prove its not entirely an unfair comparison
on top of that, 'glossy' screens are generally clearer and look more sharp. i'd take a 'glossy' screen over matte anyday, every day, and for every situation. but it's my preference only.
whipit likes this.
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC, PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
post #6 of 8 Old 02-02-2018, 06:28 AM
Bruce2019's Avatar
Quoted: 510 Post(s)
Liked: 274
Exactly! Glossy is the way to go.. In lcd world they sadly stopped producing them. Only some top end lcd tvs are glossy.. Almost all of the lcd are semi glossy and I dont like it..
Back in 2010 there where alot of glossy (samsung clear panel) lcds.. you can see the nice picture qualities on those pictures..
https://www.flatpanelshd.com/article...&id=1267184615
post #7 of 8 Old 02-09-2018, 06:58 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 660 Post(s)
Liked: 882
It wholly depends on the particular brand and model number - the type of AR Filter used on various models through the years varies widely.
Early models had a fairly non-reflective AR Filter, but later some brands/models were glossy/reflective with no AR Filter at all, some were semi-matte, a few were fully LCD-like matte, and some the later models have a somewhat reflective "Louver Filter" that rejects light from above while still having decent anti-reflective qualities.
If you are considering a particular model, post the specific model number here and we can tell you what the AR Filter is like.
Also let us know what your room environment is like, what kind of content you watch, and if you want the TV optimized for say movies at night or sports during the day, and if there are any windows located Behind your couch that would be reflected in the screen.
Dave in Green likes this.
Randy
Sony XBR-55X900E, Panasonic TC-P55ST60, TiVo Roamio Pro, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - https://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #8 of 8 Old 02-10-2018, 07:37 AM
Dave in Green's Avatar
Quoted: 3522 Post(s)
Liked: 2702
@RandyWalters did a great job of expressing what I arrived at after much research before buying my two plasmas. My final analysis was that simple matte screens (not high quality filters) were the equivalent of smearing vaseline on camera lenses as they did in the old Hollywood days to produce a soft, dreamy look. Glossy clear glass screens were more like looking out my windows into the real world. Sure, I had to deal with screen reflections, same as when I look out my windows. But I ultimately decided I would rather deal with reflections at certain times of the day than with a smeared image all the time. In the daytime I simply max out screen brightness to help fight reflections and do all of my serious viewing at night either in the dark or with carefully positioned lighting that doesn't cause reflections. I basically treat serious viewing with my plasmas in a similar way to how I view my front projection setup. For casual viewing minor reflections are easy enough for me to ignore. If I wasn't serious about wanting the clearest and best image I would have just bought LCD TVs instead of plasmas.
Dave in Green is offline
