Panasonic Viera Plasma starting to show green lines over people's faces - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-28-2018, 11:14 AM - Thread Starter
GAMESHARQ's Avatar
Question Panasonic Viera Plasma starting to show green lines over people's faces
I have a Panasonic Viera Plasma 3D HDTV which is several years old - not entirely sure which model exactly at this point.
For the past month or two, I've been noticing these vein-shaped green lines appearing over the faces of people. They are thin, veiny lines as opposed to straight or thick bars.
Is this a bad sign? Does this mean my TV is on its last legs or is there an easy fix?
GAMESHARQ is offline
post #2 of 5 Old 04-29-2018, 08:14 AM
whipit's Avatar
Quoted: 136 Post(s)
Liked: 97
Does it look like any of these?
whipit is offline
post #3 of 5 Old 04-29-2018, 09:00 AM - Thread Starter
GAMESHARQ's Avatar
Excuse my ignorance, but how do I view the attached image? As it is, it's too small for me to see properly.
post #4 of 5 Old 04-29-2018, 10:46 AM
RandyWalters's Avatar
Quoted: 697 Post(s)
Liked: 918
The attached image isn't opening for me either.
The TV's model number may be important. It's on a little white sticker either along one of the sides or somewhere on the back panel. Find that.
It's also listed in the user manual, or on the original receipt.
EDIT - i checked your Post History and found a post by you from Sept 2011 in a headphone thread:
"My TV model is TC-P42GT25. It's last year's Panasonic Viera 3D model."
For the past month or two, I've been noticing these vein-shaped green lines appearing over the faces of people. They are thin, veiny lines as opposed to straight or thick bars. Is this a bad sign? Does this mean my TV is on its last legs or is there an easy fix?
Are you able to see the lines from a normal viewing distance (like more than 6 ft)? Or only when you're abnormally close to the screen?
Are you seeing this on cable or antenna or DVD or Blu-Ray etc? Are the lines there on some sources but not on others?
Are the affected source devices connected via HDMI or Component? Have you tried different cables?
________________________________________________
Randy
Sony XBR-55X900E, Panasonic TC-P55ST60, TiVo Roamio Pro, TWC Arris DCX3600-M 6-Tuner DVR, Darbee DVP-5000S, Onkyo TX-SR333 AVR, URC MX-890 Remote.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - https://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #5 of 5 Old 04-30-2018, 04:30 AM
whipit's Avatar
Quoted: 136 Post(s)
Liked: 97
Hopefully this works better!
Name:	Screenshot-2018-4-30 Slide 1 - PANASONIC_2012_15th_Plasma_TV_ST_Series_Troublesh_Guide pdf.png
whipit is offline
