Kuro Command Program - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 3 Post By makaveddie81
post #1 of 3 Old 11-16-2018, 05:24 PM - Thread Starter
makaveddie81's Avatar
Quoted: 664 Post(s)
Liked: 364
This program allows you to connect your Windows PC to your Kuro via a serial cable (and USB to serial adapter) in order to access the service menu and issue commands. With service menu access, you're able to tweak voltages to lower black level / mitigate red tint, reset the pulse meter for a more drastic approach to lower black level / mitigate red tint, and more!
Been getting a lot of requests for this program and decided to open it up for the public. Enjoy!
Keep in mind, you will need the below items in order to use the program:
https://www.amazon.com/dp/B0007T27H8..._RbJqCbEM03W66
https://www.amazon.com/dp/B00066HP2E..._3dJqCbWMNCC58
Download link:
https://drive.google.com/open?id=0By...UVyV1FTRzlza00
Instructions:
1. Connect USB to serial adapter to your PC and install its drivers.
2. Connect serial cable to adapter and Kuro service port.
3. Launch program.
4. Enter COM port that your PC assigned to the USB to serial adapter. You can get it from Device Manager > Ports.
5. Once program connects to your Kuro, issue desired commands.
tpaxadpom, 8mile13 and Elix like this.
Sharp Elite PRO-70X5FD (Kuro PRO-171FD) x 2
Pioneer Kuro KRP-500M
Pioneer Kuro PRO-111FD
Pioneer Kuro PDP-5020
makaveddie81 is offline
post #2 of 3 Old 11-28-2018, 09:47 AM
Liked: 0
Hey Makaveddie81 - sent you a PM regarding this process, can you please check and reply when you get a chance?
ADuds72 is offline
post #3 of 3 Old 01-18-2019, 12:07 PM - Thread Starter
Quoted: 664 Post(s)
Liked: 364
Updated links to serial cable and serial to USB adapter
