Kuro Kapture Program - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 3 Post By makaveddie81
  • 1 Post By barncii
post #1 of 23 Old 11-16-2018, 05:29 PM - Thread Starter
makaveddie81's Avatar
Quoted: 649 Post(s)
Liked: 355
This program allows you to obtain a comprehensive report of your Kuro, which includes usage hours, voltage settings, pulse meter stats, error codes and more! Think of it as a CarFax for your Kuro.
Been getting a lot of requests for this program and decided to open it up for the public. Enjoy!
Keep in mind, you will need the below items in order to use the program:
https://www.amazon.com/dp/B0007T27H8..._RbJqCbEM03W66
https://www.amazon.com/dp/B00066HP2E..._3dJqCbWMNCC58
Download link:
https://drive.google.com/open?id=0By...Xl0c05qX2tmdVE
Instructions:
1. Connect USB to serial adapter to your PC and install its drivers.
2. Connect serial cable to adapter and Kuro service port.
3. Unzip program.
3. Launch program.
4. Enter COM port that your PC assigned to the USB to serial adapter. You can get it from Device Manager > Ports.
5. Select Kuro model.
5. Once program connects to your Kuro, it will establish a connection and query it.
6. Program will output the file name of the report file.
7. Open report with notepad.
tpaxadpom, 8mile13 and MKIII like this.
Sharp Elite PRO-70X5FD (Kuro PRO-171FD) x 2
Pioneer Kuro KRP-500M
Pioneer Kuro PRO-111FD
Pioneer Kuro PDP-5020
makaveddie81 is offline
post #2 of 23 Old 01-07-2019, 12:41 PM
nuraman00's Avatar
Quoted: 191 Post(s)
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Download link:
Instructions:
3. Unzip program.
3. Launch program.
The Amazon links don't work anymore.
Can you repost?
I think you posted links to a USB to serial adapter, but am not sure. Just guessing.
nuraman00 is offline
post #3 of 23 Old 01-07-2019, 12:42 PM
nuraman00's Avatar
Quoted: 191 Post(s)
I really want to try this soon and see how many hours my TV has been in use.
post #4 of 23 Old 01-10-2019, 12:40 AM
nuraman00's Avatar
Quoted: 191 Post(s)
Bump, @makaveddie81? Can you repost the links so I know what to get?
post #5 of 23 Old 01-12-2019, 04:43 AM
jowicrt's Avatar
Quoted: 705 Post(s)
Liked: 209
Why not also over IP?
Arcam AVR850 • Pioneer KURO KRP-600M • KEF Reference Model 4/2/200c •• Velodyne DD15 •• HDI Dune 4K Solo • Logitech Squeezebox Radio/Duet • Wyrewizard Dreamcaster & Spellbinder (by Nordost) • JVC D-ILA-X7500 • HDFury Vertex
jowicrt is offline
post #6 of 23 Old 01-13-2019, 01:26 AM
HDTV EAT CASH's Avatar
Quoted: 33 Post(s)
For LX609A what mode plasma should I use when prompted to select one?
HDTV EAT CASH is offline
post #7 of 23 Old 01-13-2019, 01:25 PM
barncii's Avatar
Liked: 2
Can you repost?
thanks for posting this! question. when you get the hour meter are the last 2 digits minutes? HOUR METER: 01209836 I have a 151fd panel
barncii is offline
post #8 of 23 Old 01-14-2019, 08:26 PM
nuraman00's Avatar
Quoted: 191 Post(s)
That seems to be a good guess.
Can you do a test? Use your TV for 1 hour, then check the reading again?
Also, since it seems like you installed the program, can you post what cables we need to buy, to make this work? Since the links don't work in the OP anymore.
post #9 of 23 Old 01-14-2019, 09:19 PM
barncii's Avatar
Liked: 2
and
Stickgs likes this.
barncii is offline
post #10 of 23 Old 01-14-2019, 10:31 PM
nuraman00's Avatar
Quoted: 191 Post(s)
Purchased the cables, thanks.
Will try to install Kuro Kapture after I get them.
post #11 of 23 Old 01-18-2019, 12:04 PM - Thread Starter
Quoted: 649 Post(s)
Liked: 355
Updated links to serial cable and serial to USB adapter
post #12 of 23 Old 01-18-2019, 03:57 PM
nuraman00's Avatar
Quoted: 191 Post(s)
Can you help with post #7 ?
post #13 of 23 Old 01-18-2019, 11:11 PM - Thread Starter
Quoted: 649 Post(s)
Liked: 355
Yes, so that particular set has 12,098 hours and 36 minutes of total usage.
post #14 of 23 Old 01-19-2019, 09:07 AM
Daffypuck's Avatar
Quoted: 60 Post(s)
I saw mwntioned that it would show error codes and whatnot. My 5020FD seems to have lost all but 1 HDMI output. Is that something that would show up in the report? Im just curious if something happened that deactivated those outputs that I could resolve myself before taking into a repair shop. Are there any things of note that we should look for in the report?
Daffypuck is offline
post #15 of 23 Old 01-19-2019, 12:20 PM
nuraman00's Avatar
Quoted: 191 Post(s)
Download link:
Instructions:
3. Unzip program.
3. Launch program.
There were 2 programs, a Kuro Kapture Automatic, and Kuro Kapture Manual.
I ran the Automatic one.
It didn't produce very much information. And the Hour Meter was blank.
What's wrong? Did I have to turn on my TV? Was there something I was supposed to look at on the TV?
I tried it again with the TV on. Still very little in the file.
I attached the file.
post #16 of 23 Old 01-21-2019, 02:46 PM
Daffypuck's Avatar
Quoted: 60 Post(s)
For some reason, I do not know why, but I did one tv thats next to my PC and had no issues. I did the other TV with a laptop and had the same results as you. So, I then actually installed the drivers on the laptop that came on a disc with the serial to RGB (whatever it is) cable and that solved the problem. You are running the right app also. I cant recall if I had to turn the tv on, but i did anyways and it worked. I think it doesnt matter though if its in standby or on.
post #17 of 23 Old 01-22-2019, 02:28 PM
nuraman00's Avatar
Quoted: 191 Post(s)
My cables didn't come with a driver.
Did you mean you had drivers for the Serial to USB cable? Or the 6 foot female to female serial cable?
I'm running it on a desktop.
Can you try to find the same drivers online, and post a link?
When I plugged in the Serial to USB cable, it didn't say it needed any drivers. And based on how it does communicate and establish the connection, it seems to do something. For example, it produces the Plant where it was manufactured.
But that's about the only thing it produces.
post #18 of 23 Old 01-24-2019, 04:51 PM
Daffypuck's Avatar
Quoted: 60 Post(s)
Yeh, the serial to USB cable came with drivers. I dont know if it was a coincidence, or if installing the drivers was the difference. I was using the app from a thumbdrive the first few times I tried and then actually moved the app to the laptop and installed the drivers and it worked right of the bat. I cant find the disc with the drivers, I think my buddy accidentally took it home in his laptop. Im awaiting a reply from him so I can see what brand the drivers were.
post #19 of 23 Old 01-24-2019, 06:54 PM - Thread Starter
Quoted: 649 Post(s)
Liked: 355
Not sure if you're using the USB to serial adapter that's recommended in the first post, but here's a link to the drivers for it:
https://www.trendnet.com/support/sup...prod=265_TU-S9
The program produces a file regardless of whether or not it successfully established a connection with the Kuro - there was really no way for me to verify it when developing the program. In instances where the program is unable to establish a connection, the file will contain the settings / status names but no information.
post #20 of 23 Old 01-25-2019, 01:46 PM
nuraman00's Avatar
Quoted: 191 Post(s)
Yes, I have the same cable.
I'll download the driver file and try it this weekend.
post #21 of 23 Old 01-26-2019, 12:37 PM
nuraman00's Avatar
Quoted: 191 Post(s)
I installed the driver file and ran the automatic program.
I still don't see much info in the output file, and I don't see any "hour meter" information.
What else can be the problem?
Since it says "50 inch 1st PLANT" in the file, does that mean it's made a successful connection?
post #22 of 23 Old 01-27-2019, 04:24 PM
nuraman00's Avatar
Quoted: 191 Post(s)
I found the CD that came with the cables.
I uninstalled the driver that I had downloaded, and tried it with the driver from the CD instead.
Didn't make a difference.
post #23 of 23 Old 01-30-2019, 07:00 PM - Thread Starter
Quoted: 649 Post(s)
Liked: 355
Yeah not sure man.
Either you're entering the wrong COM port, there's an issue with your computer's serial port, the adapter, the cable or the service port on your Kuro doesn't work. The latter is a long shot but it happened to me once.
