Kuro Tables Program - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By makaveddie81
  • 1 Post By makaveddie81
post #1 of 4 Old 11-16-2018, 05:54 PM - Thread Starter
makaveddie81's Avatar
Quoted: 649 Post(s)
Liked: 355
Kuro Tables Program
This program allows you to offset the white balance shift that occurs after resetting the pulse meter on a Kuro, allowing you to reset the pulse meter without having to calibrate the TV again.
Keep in mind this program gets your post reset white balance back to it's pre-reset state, so if your pre-reset white balance was already off (either by calibration drift over time or any other factor), it will simply restore the pre-reset white balance that was already off in the first place.
Keep in mind, you will need the below items in order to use the program:
https://www.amazon.com/dp/B0007T27H8..._RbJqCbEM03W66
https://www.amazon.com/dp/B00066HP2E..._3dJqCbWMNCC58
Download link:
https://drive.google.com/open?id=0By...W9qWFhkQWFEc3M
Instructions:
1. Connect USB to serial adapter to your PC and install its drivers.
2. Connect serial cable to adapter and Kuro service port.
3. Launch program.
4. Select COM port.
5. Click Connect.
6. Click Acquire Values. Screen will flash as program obtains settings from all drive modes.
7. Click Calculate Post Reset Values.
8. Click Disconnect and DO NOT CLOSE THE PROGRAM.
9. Reset your Kuro's pulse meter.
10. Back in Kuro Tables, click Connect.
11. Click Apply Post Reset Values to Configured Values. Screen will flash as program applies settings to all drive modes.
tpaxadpom and 8mile13 like this.
Sharp Elite PRO-70X5FD (Kuro PRO-171FD) x 2
Pioneer Kuro KRP-500M
Pioneer Kuro PRO-111FD
Pioneer Kuro PDP-5020
makaveddie81 is offline
post #2 of 4 Old 11-29-2018, 09:08 PM
saprano's Avatar
Quoted: 582 Post(s)
Liked: 603
Do you still not recommend resetting a 60" even with this option? Not that i need to. Just wondering in case i might have too later on.
home theater addict
saprano is offline
post #3 of 4 Old 11-30-2018, 02:30 PM - Thread Starter
Quoted: 649 Post(s)
Liked: 355
No. This simply preserves your white balance after reset but does nothing to mitigate the negative effects of resetting a 60 inch set.
saprano likes this.
post #4 of 4 Old 01-18-2019, 12:07 PM - Thread Starter
Quoted: 649 Post(s)
Liked: 355
Updated links to serial cable and serial to USB adapter
