Do LG plasma's have a limiter on them or...? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 03-14-2019, 05:10 PM - Thread Starter
seikon's Avatar
Quoted: 27 Post(s)
I'm not officially at home right now to check but I'm pretty confident the TV I have is an LG 60PB5600. I bought it about 5 years ago.
Anyway, for a low end TV, the plasma picture is still pretty sharp BUT...
Why is it that when I first turn the TV on the picture looks nice, crisp and dark (like vivid good dark), then after probably a minute or so it's like it hits some sort of threshold and the TV brightens at least 20%. The picture is still nice, but not like it was when I first turned it on.
This doesn't seem to be a flaw in the TV, as it has done that from day 1. I think I remember reading something about the LG plasma's having some sort of limiter and that's why it does that.
Can anyone shed light on this?
seikon is offline
post #2 of 11 Old 03-15-2019, 02:29 PM
RWetmore's Avatar
Quoted: 654 Post(s)
Liked: 393
If I understand you, what you mean is rising black level -- not getting brighter (higher contrast). Is this correct?
RWetmore is offline
post #3 of 11 Old 03-15-2019, 02:52 PM - Thread Starter
seikon's Avatar
Quoted: 27 Post(s)
No actually. I would say the whole screen just brightens 20-30%.
seikon is offline
post #4 of 11 Old 03-15-2019, 04:13 PM
RWetmore's Avatar
Quoted: 654 Post(s)
Liked: 393
So why is this a negative or problem?
RWetmore is offline
post #5 of 11 Old 03-15-2019, 04:17 PM - Thread Starter
seikon's Avatar
Quoted: 27 Post(s)
I've lived with it, so I mean it's not a huge issue. It's almost a curiosity at this point.
When first turned on the picture is outstanding. When it brightens, it's only very good.
seikon is offline
post #6 of 11 Old 03-15-2019, 05:38 PM
Bruce2019's Avatar
Quoted: 549 Post(s)
Liked: 312
This is a very unusual thing...
Does this also happen without a video source?.. Plug your video source off, and see if it still happens.. Does it show up on every channel/input? What source are you using? What picture setting? Can you make a picture from your screen that shows the problem?
Can you make the picture darker with lowering the brightness setting? Maybe the tv is fed with a RGB full video signal vs. a RGB limited signal.. (I explain later) But in that case you could just reduce the brightness and black level should be perfect again..
2013 Panasonic TX-P42STW60 PDP
2009 Panasonic TX-P42S10E PDP
Bruce2019 is online now
post #7 of 11 Old 03-16-2019, 07:45 AM
RWetmore's Avatar
Quoted: 654 Post(s)
Liked: 393
I think the issue here is rising black level, not rising contrast.
RWetmore is offline
post #8 of 11 Old 04-04-2019, 01:02 PM - Thread Starter
seikon's Avatar
Quoted: 27 Post(s)
Maybe it is just rising black levels.
Is there any good explanation on why it always happens after first having the TV on for a minute or so? It's always been like that.
seikon is offline
post #9 of 11 Old 04-04-2019, 01:49 PM
RWetmore's Avatar
Quoted: 654 Post(s)
Liked: 393
Not that I know of, no. And there's probably nothing that can be done about it, unfortunately.
RWetmore is offline
post #10 of 11 Old 05-29-2019, 09:09 AM
Liked: 0
I have the same LG 5600 as you and it does the same thing. It has done it from day 1 when I bought it new. It must be something built in from LG. I don't think you can turn it off or defeat it in any way.
monty4 is offline
post #11 of 11 Old 05-29-2019, 09:15 AM
Jawaburger's Avatar
Quoted: 206 Post(s)
Liked: 201
I fail to see why you can't just calibrate the image to look like it does when it first turns on. Of course you will need to wait a minute before you start the calibration.
Sharp LC-80LE844U | Marantz BD8002 | Marantz AV8003 | Marsh Sound Design A400s (FL/FR) | Marantz MM7055 (C/SL/SR) | Phase Tech PC 9.1 (FL/FR) | Phase Tech PC 3.1 (C/SL/SR) | Dual PSA S1811 Subs
Jawaburger is online now
blacklevel , lgplasma , plasma
