I'm putting makaveddie's threads in one location since it's easier to locate this way. And for possible future use for me.
Kuro Kapture https://www.avsforum.com/forum/167-plasma-flat-panel-displays/3026294-kuro-kapture-program.html
Kuro Tables https://www.avsforum.com/forum/167-plasma-flat-panel-displays/3026300-kuro-tables-program.html
Kuro Command https://www.avsforum.com/forum/167-plasma-flat-panel-displays/3026292-kuro-command-program.html
KuroCal https://www.avsforum.com/forum/167-plasma-flat-panel-displays/3026296-kurocal-program.html
If i already have access to the service menu with a remote, do i still need to get the software to change settings? Not talking about voltages as that's already available to change with the remote, other settings?
@makaveddie81 you posted a way to undo a reset before. Can you post that here?
