Buying used, PNF8500 vs. ZT60 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By mbroadus
post #1 of 3 Old 04-25-2019, 05:23 PM - Thread Starter
Quoted: 29 Post(s)
Liked: 4
If I were buying new with a warranty I'd pick the 8500 because I believe it upscales the compressed content that I get from Dish better. PQ is important to me, which is why I'm targeting what I think most agree are among the best plasmas ever made, but the brightness/black level arguments that have been hashed out many times over are less of a factor in my view when buying a TV that rolled off an assembly line more than six years ago. Both are excellent TVs and I believe both would be an upgrade from a motion handling standpoint over the LG C8 that I'm returning. I owned a F8500 and loved it but was having problems with a cluster of stuck pixels (Samsung didn't have a replacement panel, so they bought it back).
I'm leaning towards the ZT60 based on my perception that the Panasonic brand has a better reputation for reliability and durability. That the ZT60 is about 10 pounds heavier (60-inchers, w/out stand) gives me the impression that the build quality is better. Given the risk of buying used, all things being equal, is my perception that the VT60 is a safer bet from a reliability standpoint shared by most on this forum?
Dolby2020 is offline
post #2 of 3 Old 04-25-2019, 05:55 PM
mbroadus's Avatar
Quoted: 1089 Post(s)
Liked: 431
I would always choose the ZT60 over the 8500 for build and picture quality.
Dolby2020 likes this.
Panasonic P60VT60 Calibrated by Chad B
Anthem MRX-720, Oppo UDP-205, Bluesound Node 2i, Focal Aria 936/CC900
MacBook Pro, AppleTV 3 & 4K, Sony PS4 Pro
mbroadus is offline
post #3 of 3 Old 04-26-2019, 03:25 PM
Quoted: 437 Post(s)
Liked: 209
Dolby you are correct. The 8500 has a common failure. The repair is known and easy to fix however failures of the VT60 and ZT60 are very rare on this forum meaning they have been very reliable.
https://www.avsforum.com/forum/167-p...s-turning.html
Test Ickles is offline
