Panasonic TC-65PS64, blank white screen. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-07-2019, 01:45 PM - Thread Starter
CardinalDub's Avatar
My TC-65PS64 is only showing a blank white screen. No sound, no video, no on-screen menu, no error blink codes, just white. Any ideas? I called a couple TV repair shops, and they had no idea without bringing it in.
If its the main board, I think I'm screwed, because I can't find the part in stock anywhere. Interestingly, the PS64 was supposed to be identical to the S60, just with the ST60's AR filter added, but, the main boards have different part numbers between the two.
s60: https://www.shopjimmy.com/panasonic-...-tc-p65s60.htm
ps64: https://www.shopjimmy.com/panasonic-...-tc-65ps60.htm
Any help?
CardinalDub is offline
post #2 of 4 Old 07-09-2019, 03:25 PM
mailiang's Avatar
Quoted: 1190 Post(s)
Liked: 766
Any help?
Looks like a power supply problem. Maybe time to say bye bye.
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #3 of 4 Old 07-10-2019, 08:41 PM
Quoted: 451 Post(s)
Liked: 221
Never seen this problem before. First time.
Test Ickles is online now
post #4 of 4 Old 07-11-2019, 04:27 AM
whipit's Avatar
Quoted: 124 Post(s)
Liked: 96
You can try the service mode. Be forewarned that a wrong press can brick the tv so the A board would have to be replaced.
Press Volume on the tv and Info on the remote 3 times. This will get you in. The go to Aging to get a test pattern. Then use the 3 and 4 buttons to scroll through them. To exit use the power button or unplug it.
If you get nothing you have a bad A board or panel.
Source: ST50 troubleshooting manual.
whipit is offline
