Section of screen has gone black - Panasonic TC-65PS64 (Costco version of the S60) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-20-2019, 10:32 PM - Thread Starter
mraya77's Avatar
Quoted: 22 Post(s)
Question Section of screen has gone black - Panasonic TC-65PS64 (Costco version of the S60)
Hi Everyone,
I have a plasma Panasonic TC-65PS64 (the Costco version of the S60) and a few days ago, a vertical black section on the right side of the screen appeared. And it has a few multi-colored vertical lines running through it. Does anyone know what is likely causing this? Is it worth fixing?
I have attached a photo of it to this post.
I bought the TV in early 2014.
Thanks very much
mraya77 is offline
post #2 of 3 Old 09-21-2019, 12:43 PM
RWetmore's Avatar
Quoted: 654 Post(s)
Liked: 393
If you're lucky it could just be an internal cable connection issue. You could try re-seating the ribbon cables inside one by one, trying TV again for each one, and see if you have some luck. But if you're not comfortable and unfamiliar with basic safety procedures for going into the back of the set, it might not be a good idea. Hopefully some other AVSers will have some suggestions.
RWetmore is offline
post #3 of 3 Old 09-21-2019, 12:46 PM - Thread Starter
mraya77's Avatar
Quoted: 22 Post(s)
Thank you, RW. Yeah, I have zero experience in repairing or even just opening up a TV but I am open to possibly doing it, if I feel confident enough and know exactly what I should look for and do.
mraya77 is offline
