HDMI Bypass - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-26-2019, 10:26 AM - Thread Starter
yobil's Avatar
HDMI Bypass
We have a six year old Panasonic Plasma that has dysfunctional HDMI ports. The component ports still work. The TV is currently connected via coaxial cable directly from the cable box. It works but, it is not HD. There are on the market adapters that convert an HDMI signal to component. Can anyone tell me if one of these converters is a good solution to getting and HD signal. I'm told that there may be copyright protections involved and it may not work. I don't understand why that would be and issue but,...
yobil is offline
post #2 of 5 Old 09-26-2019, 07:17 PM
RandyWalters's Avatar
Quoted: 696 Post(s)
Liked: 916
I posted some HDMI-to-Component Converter info in the following thread that may be helpful:
https://www.avsforum.com/forum/167-p...l#post57374992
___
Randy
Sony XBR-55X900E, Panasonic TC-P55ST60, TiVo Roamio Pro, TWC Arris DCX3600-M 6-Tuner DVR, Darbee DVP-5000S, Onkyo TX-SR333 AVR, URC MX-890 Remote.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - https://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 5 Old 09-28-2019, 01:15 PM - Thread Starter
yobil's Avatar
I ordered a converter unit through Amazon. It was not the cheapest unit but, I followed some recommendations I found on an internet search. I received it today and hooked it up with no problems. It works great! I am very pleased that I don't have to ditch my beautiful plasma TV. The unit also has an optical port for my sound bar. I would have been happy at twice the price. Thanks for your reply.
yobil is offline
post #4 of 5 Old 09-30-2019, 07:53 AM
Quoted: 696 Post(s)
Liked: 916
Nice. Do you have a link to the exact one you chose?
________________
Randy
post #5 of 5 Old 01-11-2020, 08:43 AM - Thread Starter
yobil's Avatar
HDMI Bypass
As I mentioned above, I got this converter unit a few months ago and it has generally worked very well. I say "generally" because 2-3 times a day, the picture will go black for about 2 seconds then come back on and then go black for 2 more seconds. The timing of this seems to be random and I can't associate it with any particular event. I contacted the company and they tried to explain that it was some sort of signalling issue between the box and the TV and there was nothing defective about the bypass unit. However, at my request, they did replace it. The replacement does the same thing.
Has anyone else experienced this and is there a known solution? There are quite a number of these types of units on the market at different prices. Is this typical of all of them?
yobil is offline
