AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Plasma Flat Panel Displays (https://www.avsforum.com/forum/167-plasma-flat-panel-displays/)
-   -   TC-P50GT30 Optical Output not PCM (https://www.avsforum.com/forum/167-plasma-flat-panel-displays/3105554-tc-p50gt30-optical-output-not-pcm.html)
davebtw 11-28-2019 12:25 PM
I have been using my TC-P50GT30 in a different part of my house during remodeling. There is no room for my 5.1 system. I am using a 2-ch amp and taking the optical output which goes to the amplifier. The amp can receive SPDIF optical just fine when it is PCM, but many other TVs allow you to set the output to PCM Only.
If I watch from on-air channels, the amplifier just puts out noise as it cannot decode the AC-3 stream from the off air station. I have searched and searched and cannot find a setting in the TV to change the optical output to PCM only. Most other TVs seem to have it.
Am I missing something?
-david BTW
Bruce2019 11-29-2019 08:06 AM
-david BTW
I dont have any digital input speakers so I cant test this.. Maybe a completly different solution is using the analog headphone jack with a cable to your amp.. You can adjust the headphone volume in the sound options, and the DAC of the Panasonic TVs are really good.. Before you cant get it fixed, this might be a solution
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
