Bubbles in corners of screen f8500 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-17-2019, 11:53 AM - Thread Starter
hove131's Avatar
Quoted: 38 Post(s)
I have bubbles in all 4 corners or my screen on the black border strip. Does anybody else have this ? Will it spread? Is it just from the heat of the tv?
ID:	2655196   Click image for larger version
hove131 is offline
post #2 of 8 Old 12-17-2019, 02:55 PM
Clesarie's Avatar
Quoted: 60 Post(s)
I've tried loading the picture multiple times and they wont load past thumb nails. I'd assume its the protective layer separating from the screen. I'd assume it will only get worse as more heat weakens the glue and separates it more. Or it could be the paneling separating from the edges. Again it wont load the pictures for me so im more or less just assuming here.
Clesarie is offline
post #3 of 8 Old 12-17-2019, 09:43 PM - Thread Starter
hove131's Avatar
Quoted: 38 Post(s)
Can you see pics now ?
hove131 is offline
post #4 of 8 Old 12-17-2019, 09:46 PM - Thread Starter
hove131's Avatar
Quoted: 38 Post(s)
hove131 is offline
post #5 of 8 Old 12-17-2019, 09:46 PM - Thread Starter
hove131's Avatar
Quoted: 38 Post(s)
hove131 is offline
post #6 of 8 Old 12-17-2019, 10:09 PM - Thread Starter
hove131's Avatar
Quoted: 38 Post(s)
Here
hove131 is offline
post #7 of 8 Old 12-18-2019, 03:39 AM
RWetmore's Avatar
Quoted: 673 Post(s)
Liked: 411
Yes, that definitely looks like the antiglare sheet starting to coming unglued from the screen, maybe due to heat.
RWetmore is offline
post #8 of 8 Old 12-18-2019, 08:35 AM
Clesarie's Avatar
Quoted: 60 Post(s)
Yeah its like I expected. It will eventually come off and keep getting worse due to the heat. My best suggestion is to leave it alone.
The 2 other choices are try to remove the whole anti reflective sheet which depending on your room conditions may not matter at all. The other much harder choice it pull it off clean the edges and reglue everything back down.
Clesarie is offline
